Software Archive
Read-only legacy content
17060 Discussions
problem linking
adamzi
Hi
I have installed 30-days evaluation of the Intel C++ compiler. I have managed to modify sources to compile with the Intel C++ but have staked on the linking. I get error
2>ipo : error #11063: Q:\\Periscope\\Development\\lib\\Utilities\\x64\\Release\\Utilities.lib : UTILITIES::TCPIP::SOCKET_BUFF::overflow(?overflow@SOCKET_BUFF@TCPIP@UTILITIES@@QEAA_NI@Z) already defined in Q:\\Periscope\\Development\\lib\\Utilities\\x64\\Release\\Utilities.lib
The text of error is confusing since it implies obvious condition which should not be an error.
The name of the function is changing if i try to build other projects. However the problem is always the same the eror #11063.
Any help?
My Env:Windows server 2003-64bit,VS 2010
Adam Zielinski
Feilong_H_Intel
Hi Adam,
I recommend you to submit an issue at https://premier.intel.com along with the source code, so that our support engineer can reproduce the problem with it in our system.
Feilong
