Software Archive
Read-only legacy content
17060 Discussions
problem with google maps and image gallery.
nicolas_r_
the problem with maps is  always gat map shown and i have to rotate the screen to fix it, and the galley alwys show fallat error could not extrac hight even using the standar widget.
nicolas_r_
this just happen when the map is on secondary page.
Chris_P_Intel
What version of the XDK are you using?
I tried using both a google map on a secondary page (sub-page and page), and the Image Gallery, and both worked fine.
If the image gallery is giving you trouble, then my first guess is that either the JSON file you've modified has been broken, or the paths in it are not resolving.
nicolas_r_
I use 2727 and even with the demo gallery happen the same.
Chris_P_Intel
What UI framework are you using?
Hmm. Try making a new blank project with App Designer and insert the gallery into that. Is it working?
nicolas_r_
JQuery mobile, tath works for new proyect now how can i add to the old one ?=)
