Software Archive
Read-only legacy content
17060 Discussions
problems regarding Fifa11
supratiksikderju
I installed Fifa11 in my pc, but it didn't run on my pc. when i clck on "PLAY" button, it is shown that "please insert original FIFA11 CD/DVD". plz help.
My system information is given below
System Information
Time of this report: 11/15/2010, 14:43:03
Machine name: LOKNATH
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 08/26/09 21:00:08 Ver: 08.00.12
Processor: Intel Core2 Duo CPU E7500 @ 2.93GHz (2 CPUs)
Memory: 2038MB RAM
Page File: 445MB used, 3485MB available
Windows Dir: C:\\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Previously: Crashed in DirectPlay (stage 1)
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: The file blueletaudio.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 3: The file BlueletSCOAudio.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab:
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel G33/G31 Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Intel GMA 3100
DAC type: Internal
Device Key: Enum\\PCI\\VEN_8086&DEV_29C2&SUBSYS_82B01043&REV_10
Display Memory: 256.0 MB
Current Mode: 1360 x 768 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: igxprd32.dll
Driver Version: 6.14.0010.5009 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 11/4/2008 23:17:20, 57344 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: igxpmp32.sys
Mini VDD Date: 11/4/2008 23:16:34, 6273504 bytes
Device Identifier: {D7B78E66-6A82-11CF-6260-BAA2B1C2CB35}
Vendor ID: 0x8086
Device ID: 0x29C2
SubSys ID: 0x82B01043
Revision ID: 0x0010
Revision ID: 0x0010
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
