Software Archive
Read-only legacy content
17060 Discussions
project file upload error in intelxdk 3400 version
Muneer_B_
HI,
I'm trying to build my project but unfortunetly I can't do that because the software refuse to upload my project files and gives this error
ERROR (-9) from "client:upload-manager": Error in uploading project files: : Http request failed Error at new ComponentError (D:\Users\Moneer\AppData\Local\Intel\XDK\xdk\core-modules\public\component-error.js:17:1122) at makeError (file:///D:/Users/Moneer/AppData/Local/Intel/XDK/xdk/components/client/upload-manager/upload-manager.js:17:170) at getComponentError (file:///D:/Users/Moneer/AppData/Local/Intel/XDK/xdk/components/client/upload-manager/upload-manager.js:17:265) at file:///D:/Users/Moneer/AppData/Local/Intel/XDK/xdk/components/client/upload-manager/upload-manager.js:17:10229 at _rejected (D:\Users\Moneer\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:844:24) at D:\Users\Moneer\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:870:30 at Promise.when (D:\Users\Moneer\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:1122:31) at Promise.promise.promiseDispatch (D:\Users\Moneer\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:788:41) at D:\Users\Moneer\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:604:44 at runSingle (D:\Users\Moneer\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:137:13)
Also the same problem when I try to test the software and pushing the project files to the server it gives me this error
Error uploading sources: Error in uploading project files: : Error in uploading project files: : Error in uploading project files: : read ECONNRESET
Please Any one ca help me urgently.
Moneer
PaulF_IntelCorp
You should not be running the XDK as administrator, that is why it is installed using that location. It is a "local user" install, administrator rights are not required to install or run the XDK.
Muhammad_Y_Efendi
I use Mac, and got the same problem. Do you have any solution for Mac user?
I am using 3491 version. I could build apps before upgrade.
PaulF_IntelCorp
Muhammad -- we've identified a fix for this issue. It will appear in a hotfix that should be available early next week.
Giovanni_B_1
Hello, I updated to version 3522 and I have a similar error when i build:
ERROR (-9) from "client:upload-manager": Error in uploading project files: : Error in uploading project files: : Error in uploading project files: : tunneling socket could not be established, cause=Parse Error Error at new ComponentError (C:\Users\d6371\AppData\Local\Intel\XDK\xdk\core-modules\public\component-error.js:17:1122) at makeError (file:///C:/Users/d6371/AppData/Local/Intel/XDK/xdk/components/client/upload-manager/upload-manager.js:17:170) at getComponentError (file:///C:/Users/d6371/AppData/Local/Intel/XDK/xdk/components/client/upload-manager/upload-manager.js:17:265) at file:///C:/Users/d6371/AppData/Local/Intel/XDK/xdk/components/client/upload-manager/upload-manager.js:17:12970 at _rejected (C:\Users\d6371\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:844:24) at C:\Users\d6371\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:870:30 at Promise.when (C:\Users\d6371\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:1122:31) at Promise.promise.promiseDispatch (C:\Users\d6371\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:788:41) at C:\Users\d6371\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:604:44 at runSingle (C:\Users\d6371\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:137:13)
PaulF_IntelCorp
Please see this post > https://software.intel.com/en-us/forums/intel-xdk/topic/675906 < for a possible solution and report back if it helped.
Giovanni_B_1
I solved my problem: it depended on my company proxy server.
Thank you very much.
