Software Archive
Read-only legacy content
prototype
nouira_imen2000
hello,
I want to make a prototype DLNA UPnPAV,using Intel authoring toolkit.
Iwant toknow if it is possible.
and what I must do?
Thanks for help.
BRYAN_R_Intel
Yes it's possible. The easiest way to build a DLNA UPnP AV implementation, is to use the Digital Home Device Code Wizard tool, and select one of the DLNA Device Classes, such as DMS, DMP, etc. It will then generate source code that will help you build a device/cp that isDLNAv1.5 compliant.
