Software Archive
Read-only legacy content
17060 Discussions
responsive jquery image ticker
elias_h_
i have plugged in a responsive image ticker.
at the first when running the app, everything is ok.
but when click on any button to go to show another view and when going back by clicking on the back button the ticker stopped from working.
i have been searching a lot and didn't find any solution.
Chris_P_Intel
What is the base UI framework that you are using?
It sounds like you will need to find some sort of reset or initialization command for your image ticker, and then depending upon the framework you are using, call it on the page change.
The first step is to find that reset/initialization command. You can test it from the console to see if it is working for you.
