Software Archive
Read-only legacy content
running the program
agund4
Hello Team,
I have program A which recognises  gestures.
I have program B which catches my speech.
Initially i will run the Program A where it moniters for a particular gesture. When the required gesture is  fired it should Program B.
Kindly help me with the required piece of code. and the location where B.exe should be placed.
MartyG
What are you building your program with please?  (C#, Java, Unity, etc).  That will help people to answer your question.  Thanks!
agund4
!!! Greetings Marty,
Im using C#
agund4
I am getting the below mentioned exception
AndreCarlucci
The problem is that notepad.exe is not on that location.
Try something like:
Process.Start(@"C:\Windows\notepad.exe");
or
Process.Start(@"C:\Windows\System32\notepad.exe");
Cheers!
Felipe_P_Intel
Hi Aravind,
As André said, maybe the notepad is not on that location that you are using. You could check if the file exists or not using the C# API: https://msdn.microsoft.com/en-us/library/system.io.file.exists(v=vs.110).aspx
Felipe
agund4
Hi Felipe & Andre,
!! Greetings
My application file is in .cs format.
When i try to open  with the below line i am getting the  error.(attached in this comment)
  System.Diagnostics.Process.Start(@"C:\Users\USER3\Documents\RSSDK\Samples\DF_SpeechRecognition.cs\bin\x64\Debug\DF_SpeechRecognition.cs");
I am unable to get the .exe file for speech rocognisation in browser sample.
Thanks in advance
