Software Archive
Read-only legacy content
17060 Discussions
scif0 device missing on host.
Mona_L_
I am setting up a cluster with 8 hosts with 2 MIC's each. I have installed the MPSS 3.4.3 software on Centos 6.6. We have also installed Intel TrueScale Infiniband
Al services start fine with no errors.
I see the following kernel modules loaded:
ibscif                 83313  0
ibp_sa_server          14419  0
ibp_cm_server          15354  0
ibp_server             37843  0
autofs4                26609  4
8021q                  25527  0
garp                    7152  1 8021q
iptable_filter          2793  0
mpt3sas               188001  1
mpt2sas               186095  1
scsi_transport_sas     35588  2 mpt3sas,mpt2sas
raid_class              4388  2 mpt3sas,mpt2sas
mptctl                 31784  1
mptbase                93647  1 mptctl
dell_rbu                9990  0
nfsd                  311702  13
lockd                  73694  1 nfsd
nfs_acl                 2647  1 nfsd
auth_rpcgss            46084  1 nfsd
sunrpc                266363  17 nfsd,lockd,nfs_acl,auth_rpcgss
exportfs                4236  1 nfsd
bridge                 82775  0
stp                     2218  2 garp,bridge
llc                     5578  3 garp,bridge,stp
ipt_MASQUERADE          2466  1
iptable_nat             6051  1
nf_nat                 23316  2 ipt_MASQUERADE,iptable_nat
nf_conntrack_ipv4       9506  3 iptable_nat,nf_nat
nf_defrag_ipv4          1483  1 nf_conntrack_ipv4
ip_tables              17831  2 iptable_filter,iptable_nat
ip6t_REJECT             4628  2
nf_conntrack_ipv6       8337  2
nf_defrag_ipv6         27236  1 nf_conntrack_ipv6
xt_state                1492  2
nf_conntrack           80422  6 ipt_MASQUERADE,iptable_nat,nf_nat,nf_conntrack_ipv4,nf_conntrack_ipv6,xt_state
ip6table_filter         2889  1
ip6_tables             18732  1 ip6table_filter
rdma_ucm               12170  0
ib_sdp                129997  0
rdma_cm                33889  2 rdma_ucm,ib_sdp
iw_cm                   8644  1 rdma_cm
ib_addr                 6225  1 rdma_cm
ib_uverbs              38511  5 rdma_ucm
iw_nes                203503  0
libcrc32c               1246  1 iw_nes
iw_cxgb4              116271  0
cxgb4                 344707  1 iw_cxgb4
iw_cxgb3              131881  0
cxgb3                 193444  1 iw_cxgb3
mlx4_ib                72981  0
mlx4_en                73802  0
mlx4_core             116005  2 mlx4_ib,mlx4_en
ib_mthca              129968  0
ib_umad                12157  6
ib_ipoib               79664  0
ib_cm                  37605  3 ibp_cm_server,rdma_cm,ib_ipoib
ib_sa                  42769  5 ibp_sa_server,rdma_ucm,rdma_cm,ib_ipoib,ib_cm
ipv6                  334740  158 ip6t_REJECT,nf_conntrack_ipv6,nf_defrag_ipv6,ib_sdp,ib_addr,ib_ipoib
ipmi_devintf            7729  2
iTCO_wdt                7115  0
iTCO_vendor_support     3056  1 iTCO_wdt
microcode             112653  0
power_meter             9009  0
acpi_ipmi               3745  1 power_meter
ipmi_si                44751  2 acpi_ipmi
ipmi_msghandler        38701  3 ipmi_devintf,acpi_ipmi,ipmi_si
dcdbas                  8963  0
sg                     29318  0
ib_qib                655991  2
mic                   588936  27 ibscif,ibp_sa_server,ibp_cm_server,ibp_server,ib_qib
ib_mad                 39019  6 mlx4_ib,ib_mthca,ib_umad,ib_cm,ib_sa,ib_qib
ib_core                69987  18 ibscif,ibp_server,rdma_ucm,ib_sdp,rdma_cm,iw_cm,ib_uverbs,iw_nes,iw_cxgb4,iw_cxgb3,mlx4_ib,ib_mthca,ib_umad,ib_ipoib,ib_cm,ib_sa,ib_qib,ib_mad
igb                   199530  0
i2c_algo_bit            5711  1 igb
i2c_core               29964  2 igb,i2c_algo_bit
shpchp                 29130  0
ixgbe                 275900  0
dca                     7101  3 ib_qib,igb,ixgbe
ptp                     9614  2 igb,ixgbe
pps_core               11106  1 ptp
mdio                    4769  1 ixgbe
sb_edac                16976  0
edac_core              46645  3 sb_edac
lpc_ich                12995  0
mfd_core                1895  1 lpc_ich
ext4                  378491  2
jbd2                   93427  1 ext4
mbcache                 8193  1 ext4
sd_mod                 36998  3
crc_t10dif              1305  1 sd_mod
ahci                   41208  0
wmi                     6287  0
megaraid_sas           96205  4
dm_mirror              14384  0
dm_region_hash         12085  1 dm_mirror
dm_log                  9930  2 dm_mirror,dm_region_hash
dm_mod                 95622  2 dm_mirror,dm_log
root@r14n2:~# ibstatus
Infiniband device 'qib0' port 1 status:
    default gid:     fe80:0000:0000:0000:0011:7500:006f:dec4
    base lid:     0x1
    sm lid:         0x1
    state:         4: ACTIVE
    phys state:     5: LinkUp
    rate:         40 Gb/sec (4X QDR)
    link_layer:     InfiniBand
Infiniband device 'scif0' port 1 status:
    default gid:     4c79:ba5c:0129:0000:0000:0000:0000:0000
    base lid:     0x3e8
    sm lid:         0x1
    state:         4: ACTIVE
    link_layer:     Ethernet
but:
root@r14n2:~# ibv_devinfo
libibverbs: Warning: no userspace device-specific driver found for /sys/class/infiniband_verbs/uverbs1
hca_id:    qib0
    transport:            InfiniBand (0)
    fw_ver:                0.0.0
    node_guid:            0011:7500:006f:dec4
    sys_image_guid:            0011:7500:006f:dec4
    vendor_id:            0x1175
    vendor_part_id:            29474
    hw_ver:                0x2
    board_id:            InfiniPath_QLE7340
    phys_port_cnt:            1
        port:    1
            state:            PORT_ACTIVE (4)
            max_mtu:        4096 (5)
            active_mtu:        2048 (4)
            sm_lid:            1
            port_lid:        1
            port_lmc:        0x00
So i miss the userspace device-specific driver that points to scif.
Which package do i miss??
Thanks is advance
-Jaap Dijkshoorn
Frances_R_Intel
Just to be sure I understand - You have an Intel True Scale Fabric Host Channel Adapter on each of your host systems. You installed MPSS 3.4.3 and you installed OFED+ (the version of OFED for the TrueScale adapters) including the additional ofed and psm files that come with the MPSS. Is that correct? I especially want to confirm that you installed the psm files. For a True Scale adapter, it is those files that give you PSM-Direct, which gives you the direct connection between the coprocessors and the adapter.
FYI, even though you installed MPSS 3.4.3, you might want to look at the MPSS User's Guide that comes with MPSS 3.5. In the section on installing OFED, you will find some examples of what the Infiniband network should look like when you  have it up and running.
Mona_L_
Dear Frances Roth,
i have installed
* IntelIB-Basic.RHEL6-x86_64.7.3.1.0.12
* MPSS 3.4.3 / ofed / psm
I will give you a full listing of installed packeges, i hope you don't mind :P
root@r14n2:~# rpm -qa
openssh-clients-5.3p1-104.el6_6.1.x86_64
fipscheck-1.2.0-7.el6.x86_64
samba4-libs-4.0.0-66.el6_6.rc4.x86_64
rpmrebuild-2.11-1.el6.noarch
seekwatcher-0.12-5.el6.noarch
perl-XML-Dumper-0.81-8.el6.noarch
latencytop-common-0.5-9.el6.x86_64
libdrm-devel-2.4.52-4.el6.x86_64
libXdmcp-1.1.1-3.el6.x86_64
glibc-2.12-1.149.el6_6.7.x86_64
zlib-devel-1.2.3-29.el6.x86_64
mailcap-2.1.31-2.el6.noarch
nfs-utils-1.2.3-54.el6.x86_64
xorg-x11-server-Xorg-1.15.0-26.el6.centos.x86_64
libattr-2.4.44-7.el6.x86_64
libX11-common-1.6.0-2.2.el6.noarch
epel-release-6-8.noarch
gpgme-1.1.8-3.el6.x86_64
crash-6.1.0-6.el6_6.x86_64
pam_passwdqc-1.0.5-6.el6.x86_64
popt-1.13-7.el6.x86_64
libXtst-1.2.2-2.1.el6.x86_64
hesiod-3.1.0-19.el6.x86_64
device-mapper-libs-1.02.90-2.el6_6.2.x86_64
libpng-1.2.49-1.el6_2.x86_64
srvadmin-smcommon-8.1.0-4.138.2.el6.x86_64
libsepol-2.0.41-4.el6.x86_64
libXcursor-1.1.14-2.1.el6.x86_64
srvadmin-rac-components-8.1.0-4.4.7.el6.x86_64
btparser-0.17-2.el6.x86_64
mozilla-filesystem-1.9-5.1.el6.x86_64
python-requests-1.1.0-4.el6.centos.noarch
newt-python-0.52.11-3.el6.x86_64
srvadmin-realssd-8.1.0-4.139.1.el6.x86_64
libstdc++-4.4.7-11.el6.x86_64
vconfig-1.9-8.1.el6.x86_64
kernel-2.6.32-504.3.3.el6.x86_64
syslog-ng-3.2.5-4.el6.x86_64
dbus-python-0.83.0-6.1.el6.x86_64
srvadmin-storage-cli-8.1.0-4.138.2.el6.x86_64
b43-fwcutter-012-2.2.el6.x86_64
librsvg2-2.26.0-14.el6.x86_64
pyOpenSSL-0.10-2.el6.x86_64
srvadmin-storageservices-8.1.0-4.3.1.el6.x86_64
fontconfig-2.8.0-5.el6.x86_64
ivtv-firmware-20080701-20.2.noarch
xorg-x11-drv-void-1.4.0-23.el6.x86_64
python-mako-0.3.4-1.el6.noarch
srvadmin-rnasoap-8.1.0-4.139.1.el6.x86_64
elfutils-libs-0.158-3.2.el6.x86_64
iwl3945-firmware-15.32.2.9-4.el6.noarch
pkgconfig-0.23-9.1.el6.x86_64
nfs-utils-lib-devel-1.1.5-9.el6.x86_64
nfsometer-1.6-1.el6.noarch
mpss-coi-dev-3.4.3-1.glibc2.12.2.x86_64
module-init-tools-3.9-24.el6.x86_64
words-3.0-17.el6.noarch
mpss-myo-dev-3.4.3-1.glibc2.12.2.x86_64
perl-IO-Compress-Base-2.021-136.el6_6.1.x86_64
libtheora-1.1.0-2.el6.x86_64
rsyslog-5.8.10-10.el6_6.x86_64
numpy-1.4.1-9.el6.x86_64
glibc2.12.2pkg-mpss-memdiag-kernel-3.4.3-1.glibc2.12.2.x86_64
hwdata-0.233-11.1.el6.noarch
abrt-cli-2.0.8-26.el6.centos.x86_64
mpss-daemon-dev-3.4.3-1.glibc2.12.2.x86_64
perl-Archive-Tar-1.58-136.el6_6.1.x86_64
python-libs-2.6.6-52.el6.x86_64
sudo-1.8.6p3-15.el6.x86_64
mpss-sysmgmt-micras-3.4.3-1.glibc2.12.2.x86_64
htop-1.0.1-2.el6.x86_64
slang-2.2.1-1.el6.x86_64
ORBit2-2.14.17-5.el6.x86_64
ntsysv-1.3.49.3-2.el6_4.1.x86_64
mpss-modules-2.6.32-504.16.2.el6.x86_64-3.4.3-1.x86_64
libscif-doc-3.4.3-1.glibc2.12.2.x86_64
db4-cxx-4.7.25-18.el6_4.x86_64
perl-Module-Loaded-0.02-136.el6_6.1.x86_64
mysql-libs-5.1.73-3.el6_5.x86_64
gstreamer-plugins-base-0.10.29-2.el6.x86_64
hal-libs-0.5.14-14.el6.x86_64
grub-0.97-93.el6.x86_64
automake-1.11.1-4.el6.noarch
tk-8.5.7-5.el6.x86_64
ofed-docs-3.5-2.1.gfbaca47.x86_64
rpm-libs-4.8.0-38.el6_6.x86_64
libtiff-3.9.4-10.el6_5.x86_64
trace-cmd-1.0.5-11.el6.x86_64
gnupg2-2.0.14-8.el6.x86_64
libusb1-1.0.9-0.6.rc1.el6.x86_64
strace-4.5.19-1.19.el6.x86_64
libart_lgpl-2.3.20-5.1.el6.x86_64
kbd-1.15-11.el6.x86_64
libarchive-2.8.3-4.el6_2.x86_64
intltool-0.41.0-1.1.el6.noarch
dmraid-events-1.0.0.rc16-11.el6.x86_64
libxml2-python-2.7.6-17.el6_6.1.x86_64
gcc-4.4.7-11.el6.x86_64
diffstat-1.51-2.el6.x86_64
libstdc++-devel-4.4.7-11.el6.x86_64
perl-Test-Simple-0.92-136.el6_6.1.x86_64
cscope-15.6-6.el6.x86_64
wireless-tools-29-5.1.1.el6.x86_64
mpitests_mvapich2_pgi_qlc-3.2-923.x86_64
libproxy-bin-0.3.0-10.el6.x86_64
libxslt-1.1.26-2.el6_3.1.x86_64
libssh2-1.4.2-1.el6_6.1.x86_64
mpitests_openmpi_intel_qlc-3.2-923.x86_64
abrt-2.0.8-26.el6.centos.x86_64
desktop-file-utils-0.15-9.el6.x86_64
curl-7.19.7-40.el6_6.4.x86_64
less-436-13.el6.x86_64
hunspell-1.2.8-16.el6.x86_64
libini_config-1.1.0-11.el6.x86_64
dejavu-sans-fonts-2.30-2.el6.noarch
samba-winbind-clients-3.6.23-14.el6_6.x86_64
pcmciautils-015-4.2.el6.x86_64
dapl-debuginfo-2.1.2-1.glibc2.12.2.x86_64
iptables-1.4.7-14.el6.x86_64
cracklib-dicts-2.8.16-4.el6.x86_64
sssd-common-1.11.6-30.el6_6.4.x86_64
libibmad-devel-1.3.11-1.el6.x86_64
python-sssdconfig-1.11.6-30.el6_6.4.noarch
libibcm-devel-1.0.5-3.el6.x86_64
libbsd-0.6.0-1.el6.x86_64
pam_radius-1.4.0-2.el6.x86_64
libSM-devel-1.2.1-2.el6.x86_64
iwl1000-firmware-39.31.5.1-1.el6.noarch
libibverbs-devel-static-1.1.8-3.el6.x86_64
parted-2.1-25.el6.x86_64
ntp-4.2.6p5-3.el6.centos.x86_64
libipathverbs-1.3-3.el6.x86_64
lrzsz-0.12.20-27.1.el6.x86_64
lcms-devel-1.19-1.el6.x86_64
ConsoleKit-libs-0.4.1-3.el6.x86_64
graphviz-2.26.0-10.el6.x86_64
poppler-data-0.4.0-1.el6.noarch
mdadm-3.3-6.el6_6.1.x86_64
mtdev-1.1.2-5.el6.x86_64
openssl-1.0.1e-30.el6.8.x86_64
dstat-0.7.0-1.el6.noarch
centos-indexhtml-6-2.el6.centos.noarch
kexec-tools-2.0.0-280.el6_6.2.x86_64
info-4.13a-8.el6.x86_64
libXrender-0.9.8-2.1.el6.x86_64
libXaw-1.0.11-2.el6.x86_64
rhino-1.7-0.7.r2.2.el6.noarch
srvadmin-deng-8.1.0-4.8.1.el6.x86_64
libXrandr-1.4.1-2.1.el6.x86_64
srvadmin-xmlsup-8.1.0-4.91.1.el6.x86_64
libgcc-4.4.7-11.el6.x86_64
libtalloc-2.0.7-2.el6.x86_64
libXt-1.1.4-6.1.el6.x86_64
sgpio-1.2.0.10-5.el6.x86_64
srvadmin-isvc-snmp-8.1.0-4.38.1.el6.x86_64
gamin-0.1.10-9.el6.x86_64
python-backports-1.0-3.el6.centos.x86_64
liberation-sans-fonts-1.05.1.20090721-5.el6.noarch
dbus-libs-1.2.24-8.el6_6.x86_64
perl-libs-5.10.1-136.el6_6.1.x86_64
python-flask-0.9-7.el6.noarch
srvadmin-storage-8.1.0-4.138.2.el6.x86_64
rfkill-0.3-4.el6.x86_64
grep-2.6.3-6.el6.x86_64
nfs-ganesha-fsal-ceph-2.1.0-11.el6.x86_64
ganglia-gmond-3.7.1-1.el6.x86_64
libgpg-error-1.7-4.el6.x86_64
nfs-ganesha-2.1.0-11.el6.x86_64
python-paramiko-1.7.5-2.1.el6.noarch
nss-tools-3.18.0-5.3.el6_6.x86_64
pcre-7.8-6.el6.x86_64
libXi-devel-1.7.2-2.2.el6.x86_64
gperftools-libs-2.0-11.el6.3.x86_64
glibc2.12.2pkg-libmicmgmt0-3.4.3-1.glibc2.12.2.x86_64
ipw2100-firmware-1.3-11.el6.noarch
file-libs-5.04-21.el6.x86_64
glibc2.12.2pkg-mpss-flash-3.4.3-1.glibc2.12.2.x86_64
perl-Module-Load-0.16-136.el6_6.1.x86_64
lcms-libs-1.19-1.el6.x86_64
biosdevname-0.5.1-1.el6.x86_64
mpss-sdk-k1om-3.4.3-1.x86_64
cups-libs-1.4.2-67.el6.x86_64
certmonger-0.75.13-1.el6.x86_64
mpss-hstreams-dev-3.4.3-1.glibc2.12.2.x86_64
perl-IO-Compress-Zlib-2.021-136.el6_6.1.x86_64
mpss-miccheck-bin-3.4.3-r1.glibc2.12.2.x86_64
file-5.04-21.el6.x86_64
glibc2.12.2pkg-libmicmgmt-doc-3.4.3-1.glibc2.12.2.x86_64
shared-mime-info-0.70-6.el6.x86_64
prelink-0.4.6-3.1.el6_4.x86_64
mpss-micmgmt-doc-3.4.3-1.glibc2.12.2.x86_64
libselinux-utils-2.0.94-5.8.el6.x86_64
perl-Crypt-SSLeay-0.57-17.el6.x86_64
jasper-libs-1.900.1-16.el6_6.3.x86_64
at-3.1.10-44.el6_6.2.x86_64
mpfr-2.4.1-6.el6.x86_64
libpcap-1.4.0-1.20130826git2dbcaa1.el6.x86_64
mailx-12.4-8.el6_6.x86_64
qt-x11-4.6.2-28.el6_5.x86_64
mesa-dri1-drivers-7.11-8.el6.x86_64
mpi-selector-1.0.3-1.x86_64
rpm-python-4.8.0-38.el6_6.x86_64
rsync-3.0.6-12.el6.x86_64
vim-enhanced-7.2.411-1.8.el6.x86_64
kernel-devel-2.6.32-431.23.3.el6.x86_64
binutils-devel-2.20.51.0.2-5.42.el6.x86_64
neon-0.29.3-3.el6_4.x86_64
python-kerberos-1.1-7.el6.x86_64
perl-Test-Harness-3.17-136.el6_6.1.x86_64
indent-2.2.10-7.el6.x86_64
openmpi_gcc-1.8.1-1.x86_64
device-mapper-persistent-data-0.3.2-1.el6.x86_64
perl-libwww-perl-5.833-2.el6.noarch
perl-ExtUtils-CBuilder-0.27-136.el6_6.1.x86_64
bison-2.4.1-5.el6.x86_64
mvapich2_gcc_qlc-1.8.1-1.x86_64
perl-parent-0.221-136.el6_6.1.x86_64
systemtap-2.5-5.el6.x86_64
yp-tools-2.9-12.el6.x86_64
openmpi_pgi_qlc-1.8.1-1.x86_64
libreport-plugin-reportuploader-2.0.9-21.el6.centos.x86_64
tcp_wrappers-7.6-57.el6.x86_64
libtar-1.2.11-17.el6_4.1.x86_64
intel-shmem-benchmarks-3.3-26521.1177_rhel6_qlc.x86_64
abrt-addon-kerneloops-2.0.8-26.el6.centos.x86_64
tcsh-6.17-25.el6_6.x86_64
redhat-lsb-4.0-7.el6.centos.x86_64
ofed-driver-2.6.32-504.16.2.el6.x86_64-3.4.3-1.x86_64
gdb-7.2-75.el6.x86_64
make-3.81-20.el6.x86_64
cfengine-community-3.6.5-1.x86_64
dapl-devel-2.1.2-1.glibc2.12.2.x86_64
dell-omsa-repository-2-5.noarch
c-ares-1.10.0-3.el6.x86_64
groff-1.18.1.4-21.el6.x86_64
freetype-2.3.11-15.el6_6.1.x86_64
libibverbs-devel-1.1.8-3.el6.x86_64
policycoreutils-2.0.83-19.47.el6_6.1.x86_64
sssd-ipa-1.11.6-30.el6_6.4.x86_64
redhat-rpm-config-9.0.3-42.el6.centos.noarch
foomatic-4.0.4-3.el6.x86_64
bind-libs-9.8.2-0.30.rc1.el6_6.3.x86_64
redhat-logos-60.0.14-12.el6.centos.noarch
freetype-devel-2.3.11-15.el6_6.1.x86_64
iwl6000g2a-firmware-17.168.5.3-1.el6.noarch
infiniband-diags-1.6.4-1.el6.x86_64
pm-utils-1.2.5-11.el6.x86_64
crash-gcore-command-1.0-5.el6.x86_64
srptools-1.0.2-1.el6.x86_64
libIDL-0.8.13-2.1.el6.x86_64
libgsf-1.14.15-5.el6.x86_64
system-setup-keyboard-0.7-4.el6.x86_64
fontpackages-filesystem-1.41-1.1.el6.noarch
shadow-utils-4.1.4.2-19.el6_6.1.x86_64
gnutls-2.8.5-14.el6_5.x86_64
ncurses-libs-5.7-3.20090208.el6.x86_64
mesa-dri-filesystem-10.1.2-2.el6.x86_64
libuser-0.56.13-5.el6.x86_64
flac-1.2.1-7.el6_6.x86_64
freeglut-devel-2.6.0-1.el6.x86_64
fribidi-0.19.2-2.el6.x86_64
libjpeg-turbo-1.2.1-3.el6_5.x86_64
libX11-devel-1.6.0-2.2.el6.x86_64
libaio-0.3.107-10.el6.x86_64
srvadmin-omacs-8.1.0-4.92.1.el6.x86_64
ql2500-firmware-7.03.00-1.el6_5.noarch
libacl-2.2.49-6.el6.x86_64
libXxf86vm-1.1.3-2.1.el6.x86_64
device-mapper-event-libs-1.02.90-2.el6_6.2.x86_64
bzip2-libs-1.0.5-7.el6_0.x86_64
mesa-libGL-devel-10.1.2-2.el6.x86_64
python-ordereddict-1.1-2.el6.centos.noarch
lsof-4.82-4.el6.x86_64
device-mapper-event-1.02.90-2.el6_6.2.x86_64
python-urllib3-1.5-7.el6.centos.noarch
perl-Pod-Escapes-1.04-136.el6_6.1.x86_64
tzdata-java-2015d-1.el6.noarch
xmlrpc-c-client-1.16.24-1210.1840.el6.x86_64
tcp_wrappers-libs-7.6-57.el6.x86_64
ceph-0.80.5-9.el6.x86_64
libselinux-2.0.94-5.8.el6.x86_64
dosfstools-3.0.9-4.el6.x86_64
srvadmin-storage-snmp-8.1.0-4.138.2.el6.x86_64
which-2.19-6.el6.x86_64
coreutils-libs-8.4-37.el6.x86_64
python-netaddr-0.7.5-4.el6.noarch
ganglia-gmond-python-3.7.1-1.el6.x86_64
xorg-x11-drv-vesa-2.3.2-15.el6.x86_64
perl-Locale-Maketext-Simple-0.18-136.el6_6.1.x86_64
python-pycurl-7.19.0-8.el6.x86_64
firefox-38.0-4.el6.centos.x86_64
libunwind-1.1-2.el6.x86_64
oprofile-0.9.9-6.el6_6.x86_64
rt73usb-firmware-1.8-7.el6.noarch
glibc2.12.2pkg-libmicaccesssdk0-3.4.3-1.glibc2.12.2.x86_64
tar-1.23-11.el6.x86_64
gpg-pubkey-c105b9de-4e0fd3a3
glibc2.12.2pkg-mpss-rasmm-kernel-3.4.3-1.glibc2.12.2.x86_64
crda-1.1.3_2014.06.13-1.el6.x86_64
libbasicobjects-0.1.1-11.el6.x86_64
python-setuptools-0.6.10-3.el6.noarch
mpss-boot-files-3.4.3-1.glibc2.12.2.x86_64
libhugetlbfs-utils-2.16-2.el6.x86_64
perl-Package-Constants-0.02-136.el6_6.1.x86_64
mpss-offload-dev-3.4.3-1.glibc2.12.2.x86_64
gmp-4.3.1-7.el6_2.2.x86_64
yum-utils-1.1.30-30.el6.noarch
libxcb-devel-1.9.1-2.el6.x86_64
glibc2.12.2pkg-libmicmgmt-dev-3.4.3-1.glibc2.12.2.x86_64
fprintd-0.1-21.git04fd09cfa.el6.x86_64
cpuspeed-1.5-20.el6_4.x86_64
libgudev1-147-2.57.el6.x86_64
plymouth-scripts-0.8.3-27.el6.centos.1.x86_64
qt3-3.3.8b-30.el6.x86_64
mpss-coi-doc-3.4.3-1.glibc2.12.2.x86_64
librados2-0.80.5-9.el6.x86_64
mpss-sciftutorials-doc-3.4.3-1.glibc2.12.2.x86_64
ImageMagick-c++-6.5.4.7-7.el6_5.x86_64
perl-Module-CoreList-2.18-136.el6_6.1.x86_64
liboil-0.3.16-4.1.el6.x86_64
sgml-common-0.6.3-33.el6.noarch
perl-Git-1.7.1-3.el6_4.1.noarch
rpm-4.8.0-38.el6_6.x86_64
infinipath-doc-3.3-26521.1177_rhel6_qlc.noarch
vim-minimal-7.2.411-1.8.el6.x86_64
perl-DBI-1.609-4.el6.x86_64
crash-trace-command-1.0-5.el6.x86_64
perl-DBD-SQLite-1.27-3.el6.x86_64
nfs-ganesha-docs-2.1.0-11.el6.noarch
perl-ExtUtils-ParseXS-2.2003.0-136.el6_6.1.x86_64
gdisk-0.8.10-1.el6.x86_64
mpitests_openmpi_gcc-3.2-923.x86_64
doxygen-1.6.1-6.el6.x86_64
systemtap-devel-2.5-5.el6.x86_64
perl-Time-HiRes-1.9721-136.el6_6.1.x86_64
xinetd-2.3.14-39.el6_4.x86_64
libicu-4.2.1-9.1.el6_2.x86_64
libreport-plugin-rhtsupport-2.0.9-21.el6.centos.x86_64
ypbind-1.20.4-30.el6.x86_64
mpitests_openmpi_pgi_qlc-3.2-923.x86_64
smbios-utils-bin-2.2.27-4.12.1.el6.x86_64
libutempter-1.1.5-4.1.el6.x86_64
abrt-addon-python-2.0.8-26.el6.centos.x86_64
crontabs-1.10-33.el6.noarch
cronie-1.4.4-12.el6.x86_64
libnih-1.0.1-7.el6.x86_64
subversion-1.6.11-12.el6_6.x86_64
cpp-4.4.7-11.el6.x86_64
ofed-driver-devel-2.6.32-504.16.2.el6.x86_64-3.4.3-1.x86_64
samba-common-3.6.23-14.el6_6.x86_64
ethtool-3.5-5.el6.x86_64
gpg-pubkey-5e3d7775-42d297af
dapl-utils-2.1.2-1.glibc2.12.2.x86_64
cifs-utils-4.8.1-19.el6.x86_64
cyrus-sasl-gssapi-2.1.23-15.el6_6.2.x86_64
util-linux-ng-2.17.2-12.18.el6.x86_64
system-config-network-tui-1.6.0.el6.2-1.el6.noarch
libibmad-1.3.11-1.el6.x86_64
alsa-lib-1.0.22-3.el6.x86_64
sssd-ldap-1.11.6-30.el6_6.4.x86_64
bind-utils-9.8.2-0.30.rc1.el6_6.3.x86_64
ilmbase-1.0.1-6.1.el6.x86_64
samba-client-3.6.23-14.el6_6.x86_64
aic94xx-firmware-30-2.el6.noarch
ibsim-0.5-7.el6.x86_64
fipscheck-lib-1.2.0-7.el6.x86_64
virt-what-1.11-1.2.el6.x86_64
mstflint-3.6.0-0.1_1.8.g7d4dede.el6.x86_64
filesystem-2.4.30-3.el6.x86_64
libcroco-0.6.2-5.el6.x86_64
busybox-1.15.1-21.el6_6.x86_64
latencytop-0.5-9.el6.x86_64
GConf2-2.28.0-6.el6.x86_64
ConsoleKit-0.4.1-3.el6.x86_64
libXmu-1.1.1-2.el6.x86_64
iso-codes-3.16-2.el6.noarch
glibc-headers-2.12-1.149.el6_6.7.x86_64
xorg-x11-xkb-utils-7.7-4.el6.x86_64
freeglut-2.6.0-1.el6.x86_64
xorg-x11-server-common-1.15.0-26.el6.centos.x86_64
libtasn1-2.3-6.el6_5.x86_64
ilmbase-devel-1.0.1-6.1.el6.x86_64
glibc-devel-2.12-1.149.el6_6.7.x86_64
pinfo-0.6.9-12.el6.x86_64
mc-4.7.0.2-3.el6.x86_64
libcap-2.16-5.5.el6.x86_64
OpenEXR-devel-1.6.1-8.1.el6.x86_64
passwd-0.77-4.el6_2.2.x86_64
freeipmi-1.2.1-6.el6_5.x86_64
usbutils-003-4.el6.x86_64
gnome-icon-theme-2.28.0-2.el6.noarch
hicolor-icon-theme-0.11-1.1.el6.noarch
glibc-devel-2.12-1.149.el6_6.7.i686
psacct-6.3.2-63.el6_3.3.x86_64
ql2400-firmware-7.03.00-1.el6_5.noarch
device-mapper-1.02.90-2.el6_6.2.x86_64
perl-XML-Grove-0.46alpha-40.el6.noarch
nss-3.18.0-5.3.el6_6.x86_64
srvadmin-sysfsutils-8.1.0-4.1.1.el6.x86_64
iputils-20071127-17.el6_4.2.x86_64
xkeyboard-config-2.11-1.el6.noarch
gpm-libs-1.20.6-12.el6.x86_64
libjpeg-turbo-devel-1.2.1-3.el6_5.x86_64
srvadmin-isvc-8.1.0-4.38.1.el6.x86_64
latencytop-tui-0.5-9.el6.x86_64
lvm2-libs-2.02.111-2.el6_6.2.x86_64
db4-4.7.25-18.el6_4.x86_64
sed-4.2.1-10.el6.x86_64
libasyncns-0.8-1.1.el6.x86_64
startup-notification-0.10-2.1.el6.x86_64
srvadmin-omacore-8.1.0-4.94.3.el6.x86_64
nfs4-acl-tools-0.3.3-6.el6.x86_64
libICE-1.0.6-1.el6.x86_64
srvadmin-nvme-8.1.0-4.139.1.el6.x86_64
python-ldap-2.3.10-1.el6.x86_64
srvadmin-storelib-sysfs-8.1.0-4.1.1.el6.x86_64
zip-3.0-1.el6.x86_64
libtdb-1.2.10-1.el6.x86_64
srvadmin-storageservices-snmp-8.1.0-4.3.1.el6.x86_64
bridge-utils-1.2-10.el6.x86_64
libogg-1.1.4-2.1.el6.x86_64
pygpgme-0.1-18.20090824bzr68.el6.x86_64
dracut-kernel-004-356.el6_6.2.noarch
latrace-0.5.9-2.el6.x86_64
cryptopp-5.6.2-2.el6.x86_64
libcap-ng-0.6.4-3.el6_0.1.x86_64
python-lxml-2.2.3-1.1.el6.x86_64
openjpeg-libs-1.3-10.el6_5.x86_64
kernel-2.6.32-504.16.2.el6.x86_64
jemalloc-3.6.0-1.el6.x86_64
python-dateutil-1.4.1-6.el6.noarch
selinux-policy-targeted-3.7.19-260.el6_6.3.noarch
libertas-usb8388-firmware-5.110.22.p23-3.1.el6.noarch
bzip2-1.0.5-7.el6_0.x86_64
perf-2.6.32-504.16.2.el6.x86_64
zd1211-firmware-1.4-4.el6.noarch
filebench-1.4.9.1-1.el6.x86_64
pytalloc-2.0.7-2.el6.x86_64
kernel-devel-2.6.32-504.16.2.el6.x86_64
ql2200-firmware-2.02.08-3.1.el6.noarch
libgssglue-devel-0.1-11.el6.x86_64
mpss-coi-3.4.3-1.glibc2.12.2.x86_64
ipw2200-firmware-3.1-4.el6.noarch
nfs-ganesha-2.1.0-5.el6.x86_64
mpss-daemon-3.4.3-1.glibc2.12.2.x86_64
libconfuse-2.7-4.el6.x86_64
mpss-micmgmt-3.4.3-1.glibc2.12.2.x86_64
mpss-micmgmt-python-3.4.3-1.glibc2.12.2.x86_64
python-nose-0.10.4-3.1.el6.noarch
mpss-core-3.4.3-1.glibc2.12.2.x86_64
theora-tools-1.1.0-2.el6.x86_64
intel-composerxe-compat-k1om-3.4.3-1.x86_64
checkpolicy-2.0.22-1.el6.x86_64
glibc2.12.2pkg-libodmdebug-dev-3.4.3-1.glibc2.12.2.x86_64
python-2.6.6-52.el6.x86_64
mpss-sysmgmt-python-3.4.3-1.glibc2.12.2.x86_64
diffutils-2.8.1-28.el6.x86_64
libXft-2.3.1-2.el6.x86_64
p11-kit-0.18.5-2.el6_5.2.x86_64
mpss-micsmc-gui-3.4.3-1.glibc2.12.2.x86_64
libedit-2.11-4.20080712cvs.1.el6.x86_64
giflib-4.1.6-3.1.el6.x86_64
mpss-eclipse-cdt-mpm-3.4.3-1.glibc2.12.2.x86_64
newt-0.52.11-3.el6.x86_64
pycairo-1.8.6-2.1.el6.x86_64
mpss-license-3.4.3-1.glibc2.12.2.x86_64
libthai-0.1.12-3.el6.x86_64
mpss-hstreams-doc-3.4.3-1.glibc2.12.2.x86_64
mpss-myo-doc-3.4.3-1.glibc2.12.2.x86_64
libfprint-0.1.0-19.pre2.el6.x86_64
ImageMagick-devel-6.5.4.7-7.el6_5.x86_64
postfix-2.6.6-6.el6_5.x86_64
autoconf-2.63-5.1.el6.noarch
qt-sqlite-4.6.2-28.el6_5.x86_64
git-1.7.1-3.el6_4.1.x86_64
psmisc-22.6-19.el6_5.x86_64
xorg-x11-fonts-Type1-7.2-9.1.el6.noarch
ppl-0.10.2-11.el6.x86_64
perl-URI-1.40-2.el6.noarch
kernel-2.6.32-431.23.3.el6.x86_64
upstart-0.6.5-13.el6_5.3.x86_64
perl-DBIx-Simple-1.32-3.el6.noarch
usermode-1.102-3.el6.x86_64
libtool-2.2.6-15.5.el6.x86_64
foomatic-db-ppds-4.0-7.20091126.el6.noarch
mvapich2_gcc-1.8.1-1.x86_64
rcs-5.7-37.el6.x86_64
perl-HTML-Tagset-3.20-4.el6.noarch
perl-libxml-perl-0.08-10.el6.noarch
mvapich_intel_qlc-1.2.0-3635.x86_64
mvapich2_pgi_qlc-1.8.1-1.x86_64
gstreamer-0.10.29-1.el6.x86_64
libcurl-7.19.7-40.el6_6.4.x86_64
openmpi_intel_qlc-1.8.1-1.x86_64
eggdbus-0.6-3.el6.x86_64
nss-softokn-3.14.3-22.el6_6.x86_64
oddjob-mkhomedir-0.30-5.el6.x86_64
intel-shmem-devel-3.3-26521.1177_rhel6_qlc.x86_64
patch-2.6-6.el6.x86_64
portreserve-0.0.4-9.el6.x86_64
kpartx-0.4.9-80.el6_6.3.x86_64
redhat-lsb-graphics-4.0-7.el6.centos.x86_64
ed-1.1-3.3.el6.x86_64
nss-softokn-freebl-3.14.3-22.el6_6.i686
mpss-psm-3.4.3-1.glibc2.12.2.x86_64
cyrus-sasl-lib-2.1.23-15.el6_6.2.x86_64
rdma-6.6_3.15-1.el6.noarch
gpg-pubkey-23b66a9d-3adb5504
cdparanoia-libs-10.2-5.1.el6.x86_64
dapl-devel-static-2.1.2-1.glibc2.12.2.x86_64
opensm-libs-3.3.17-1.el6.x86_64
libgcrypt-1.4.5-11.el6_4.x86_64
sssd-krb5-common-1.11.6-30.el6_6.4.x86_64
libibumad-devel-1.3.9-1.el6.x86_64
sssd-krb5-1.11.6-30.el6_6.4.x86_64
libibcm-1.0.5-3.el6.x86_64
jpackage-utils-1.7.5-3.12.el6.noarch
sssd-1.11.6-30.el6_6.4.x86_64
libibverbs-utils-1.1.8-3.el6.x86_64
OpenEXR-libs-1.6.1-8.1.el6.x86_64
cyrus-sasl-2.1.23-15.el6_6.2.x86_64
iwl6050-firmware-41.28.5.1-2.el6.noarch
libibmad-static-1.3.11-1.el6.x86_64
libsndfile-1.0.20-5.el6.x86_64
torque-5.1.0-3.x86_64
iwl6000-firmware-9.221.4.1-1.el6.noarch
librdmacm-devel-1.0.18.1-1.el6.x86_64
poppler-utils-0.12.4-3.el6_0.1.x86_64
ntpdate-4.2.6p5-3.el6.centos.x86_64
rng-tools-2-13.el6_2.x86_64
librdmacm-utils-1.0.18.1-1.el6.x86_64
systemtap-client-2.5-5.el6.x86_64
iotop-0.3.2-7.el6.noarch
minicom-2.3-6.1.el6.x86_64
ghostscript-devel-8.70-19.el6.x86_64
powertop-2.3-3.el6.x86_64
libcgroup-0.40.rc1-15.el6_6.x86_64
setuptool-1.19.9-4.el6.x86_64
iptables-ipv6-1.4.7-14.el6.x86_64
python-jinja2-26-2.6-3.el6.noarch
libX11-1.6.0-2.2.el6.x86_64
OpenEXR-1.6.1-8.1.el6.x86_64
pango-1.28.1-10.el6.x86_64
libXfixes-5.0.1-2.1.el6.x86_64
pulseaudio-libs-0.9.21-17.el6.x86_64
mesa-libGLU-10.1.2-2.el6.x86_64
libXxf86vm-devel-1.1.3-2.1.el6.x86_64
python-argparse-1.2.1-2.el6.centos.noarch
gtk2-2.24.23-6.el6.x86_64
bash-4.1.2-29.el6.x86_64
xmlrpc-c-1.16.24-1210.1840.el6.x86_64
python-six-1.7.3-1.el6.centos.noarch
perl-Module-Pluggable-3.90-136.el6_6.1.x86_64
perl-5.10.1-136.el6_6.1.x86_64
ceph-common-0.80.5-9.el6.x86_64
autofs-5.0.5-109.el6_6.1.x86_64
libxml2-2.7.6-17.el6_6.1.x86_64
gettext-devel-0.17-18.el6.x86_64
coreutils-8.4-37.el6.x86_64
icewm-1.3.8-3.el6.x86_64
perl-Params-Check-0.26-136.el6_6.1.x86_64
tigervnc-server-module-1.1.0-16.el6.centos.x86_64
libblkid-2.17.2-12.18.el6.x86_64
snappy-1.1.0-1.el6.x86_64
hwloc-1.5-3.el6_5.x86_64
binutils-2.20.51.0.2-5.42.el6.x86_64
openssh-server-5.3p1-104.el6_6.1.x86_64
perl-Log-Message-0.02-136.el6_6.1.x86_64
cups-1.4.2-67.el6.x86_64
libcollection-0.6.2-11.el6.x86_64
cpio-2.10-12.el6_5.x86_64
atk-1.30.0-1.el6.x86_64
ledmon-0.79-1.el6.x86_64
perl-Compress-Raw-Zlib-2.021-136.el6_6.1.x86_64
e2fsprogs-1.41.12-21.el6.x86_64
perl-IO-Zlib-1.09-136.el6_6.1.x86_64
yum-plugin-security-1.1.30-30.el6.noarch
perl-Log-Message-Simple-0.04-136.el6_6.1.x86_64
perl-Object-Accessor-0.34-136.el6_6.1.x86_64
polkit-0.96-7.el6.x86_64
xcb-util-0.3.6-5.el6.x86_64
setup-2.8.14-20.el6_4.1.noarch
librbd1-0.80.5-9.el6.x86_64
efibootmgr-0.5.4-12.el6.x86_64
libss-1.41.12-21.el6.x86_64
db4-devel-4.7.25-18.el6_4.x86_64
perl-Compress-Raw-Bzip2-2.021-136.el6_6.1.x86_64
ghostscript-fonts-5.50-23.2.el6.noarch
libgomp-4.4.7-11.el6.x86_64
audit-2.3.7-5.el6.x86_64
gettext-0.17-18.el6.x86_64
boost-program-options-1.41.0-25.el6.centos.x86_64
openldap-2.4.39-8.el6.x86_64
gdbm-devel-1.8.0-36.el6.x86_64
libvisual-0.4.0-10.el6.x86_64
yum-3.2.29-60.el6.centos.noarch
telnet-0.17-48.el6.x86_64
grubby-7.0.15-7.el6.x86_64
libitm-4.9.0-6.1.1.el6.x86_64
man-pages-overrides-6.6.3-2.el6.noarch
authconfig-6.1.12-19.el6.x86_64
perl-devel-5.10.1-136.el6_6.1.x86_64
e2fsprogs-libs-1.41.12-21.el6.x86_64
perl-Archive-Extract-0.38-136.el6_6.1.x86_64
sip-4.9.3-1.el6.x86_64
perl-CPANPLUS-0.88-136.el6_6.1.x86_64
perl-Parse-CPAN-Meta-1.40-136.el6_6.1.x86_64
perl-CPAN-1.9402-136.el6_6.1.x86_64
libproxy-0.3.0-10.el6.x86_64
gcc-gfortran-4.4.7-11.el6.x86_64
libreport-python-2.0.9-21.el6.centos.x86_64
libreport-plugin-mailx-2.0.9-21.el6.centos.x86_64
abrt-tui-2.0.8-26.el6.centos.x86_64
cronie-anacron-1.4.4-12.el6.x86_64
libreport-plugin-logger-2.0.9-21.el6.centos.x86_64
libgfortran-4.4.7-11.el6.x86_64
libpath_utils-0.2.1-11.el6.x86_64
plymouth-core-libs-0.8.3-27.el6.centos.1.x86_64
centos-release-6-6.el6.centos.12.2.x86_64
initscripts-9.03.46-1.el6.centos.1.x86_64
libdrm-2.4.52-4.el6.x86_64
readahead-1.5.6-2.el6.x86_64
cryptsetup-luks-libs-1.2.0-11.el6.x86_64
fprintd-pam-0.1-21.git04fd09cfa.el6.x86_64
libXdamage-devel-1.1.3-4.el6.x86_64
tcptraceroute-1.5-0.8.beta7.el6.x86_64
smartmontools-5.43-1.el6.x86_64
ibacm-1.0.9-0.git49af5a8.el6.x86_64
python-urlgrabber-3.9.1-9.el6.noarch
plymouth-0.8.3-27.el6.centos.1.x86_64
gd-2.0.35-11.el6.x86_64
xorg-x11-xauth-1.0.2-7.1.el6.x86_64
python-babel-0.9.4-5.1.el6.noarch
man-1.6f-32.el6.x86_64
krb5-workstation-1.10.3-37.el6_6.x86_64
gdk-pixbuf2-2.24.1-5.el6.x86_64
libXpm-3.5.10-2.el6.x86_64
jline-0.9.94-0.8.el6.noarch
srvadmin-omilcore-8.1.0-4.85.1.el6.x86_64
hunspell-en-0.20090216-7.1.el6.noarch
libXfixes-devel-5.0.1-2.1.el6.x86_64
libevent-1.4.13-4.el6.x86_64
nss-sysinit-3.18.0-5.3.el6_6.x86_64
bsd-mailx-8.1.2-5.el6.x86_64
PyQt4-4.6.2-9.el6.x86_64
lzo-2.03-3.1.el6_5.1.x86_64
srvadmin-ominst-8.1.0-4.94.3.el6.x86_64
dhcp-common-4.1.1-43.P1.el6.centos.1.x86_64
liberation-fonts-common-1.05.1.20090721-5.el6.noarch
python-backports-ssl_match_hostname-3.4.0.2-4.el6.centos.noarch
libffi-3.0.5-3.2.el6.x86_64
selinux-policy-3.7.19-260.el6_6.3.noarch
libnl-1.1.4-2.el6.x86_64
perl-version-0.77-136.el6_6.1.x86_64
mtr-0.75-5.el6.x86_64
sqlite-3.6.20-1.el6.x86_64
python-ceph-0.80.5-9.el6.x86_64
python-krbV-1.0.90-3.el6.x86_64
srvadmin-storelib-8.1.0-4.139.1.el6.x86_64
elfutils-libelf-0.158-3.2.el6.x86_64
rdate-1.4-16.el6.x86_64
python-nss-0.13-1.el6.x86_64
ganglia-3.7.1-1.el6.x86_64
pam-1.1.1-20.el6.x86_64
libtopology-0.3-7.el6.x86_64
libXt-devel-1.1.4-6.1.el6.x86_64
python-crypto-2.0.1-22.el6.x86_64
lvm2-2.02.111-2.el6_6.2.x86_64
xz-libs-4.999.9-0.5.beta.20091007git.el6.x86_64
atmel-firmware-1.3-7.el6.noarch
libXv-1.0.9-2.1.el6.x86_64
libscif0-3.4.3-1.glibc2.12.2.x86_64
sysvinit-tools-2.87-5.dsf.el6.x86_64
boost-thread-1.41.0-25.el6.centos.x86_64
ql23xx-firmware-3.03.27-3.1.el6.noarch
glibc2.12.2pkg-libodmdebug0-3.4.3-1.glibc2.12.2.x86_64
boost-system-1.41.0-25.el6.centos.x86_64
libmng-1.0.10-4.1.el6.x86_64
bfa-firmware-3.2.23.0-2.el6.noarch
libscif-dev-3.4.3-1.glibc2.12.2.x86_64
avahi-libs-0.6.25-15.el6.x86_64
ipa-python-3.0.0-42.el6.centos.x86_64
libXau-1.0.6-4.el6.x86_64
mpss-miccheck-3.4.3-r1.glibc2.12.2.x86_64
pixman-0.32.4-4.el6.x86_64
glibc2.12.2pkg-libmicaccesssdk-dev-3.4.3-1.glibc2.12.2.x86_64
perl-Term-UI-0.20-136.el6_6.1.x86_64
p11-kit-trust-0.18.5-2.el6_5.2.x86_64
libfontenc-1.0.5-2.el6.x86_64
ceph-libs-compat-0.80.5-9.el6.x86_64
mpss-mpm-3.4.3-1.glibc2.12.2.x86_64
glib2-2.28.8-4.el6.x86_64
pciutils-3.1.10-4.el6.x86_64
netperf-2.6.0-r0.glibc2.12.2.x86_64
libcephfs1-0.80.5-9.el6.x86_64
ImageMagick-6.5.4.7-7.el6_5.x86_64
wget-1.12-5.el6_6.1.x86_64
libtirpc-0.2.1-10.el6.x86_64
ImageMagick-c++-devel-6.5.4.7-7.el6_5.x86_64
pam-devel-1.1.1-20.el6.x86_64
libibumad-compat-2-1.3.4-1.ofed.1.5.1.x86_64
perl-IO-Compress-Bzip2-2.021-136.el6_6.1.x86_64
phonon-backend-gstreamer-4.6.2-28.el6_5.x86_64
ltrace-0.5-28.45svn.el6.x86_64
apr-util-1.3.9-3.el6_0.1.x86_64
ttmkfdir-3.0.9-32.1.el6.x86_64
vim-common-7.2.411-1.8.el6.x86_64
flex-2.5.35-9.el6.x86_64
cloog-ppl-0.15.7-1.2.el6.x86_64
atlas-3.8.4-2.el6.x86_64
xorg-x11-drv-ati-firmware-7.3.99-2.el6.noarch
pakchois-0.4-3.2.el6.x86_64
dmidecode-2.12-5.el6_5.x86_64
perl-ExtUtils-MakeMaker-6.55-136.el6_6.1.x86_64
swig-1.3.40-6.el6.x86_64
foomatic-db-4.0-7.20091126.el6.noarch
mpitests_mvapich2_gcc-3.2-923.x86_64
gettext-libs-0.17-18.el6.x86_64
perl-XML-Parser-2.36-7.el6.x86_64
perl-Module-Build-0.3500-136.el6_6.1.x86_64
byacc-1.9.20070509-7.el6.x86_64
mpitests_mvapich_intel_qlc-3.2-923.x86_64
perl-CGI-3.51-136.el6_6.1.x86_64
gstreamer-tools-0.10.29-1.el6.x86_64
gcc-c++-4.4.7-11.el6.x86_64
ncurses-devel-5.7-3.20090208.el6.x86_64
mpitests_openmpi_gcc_qlc-3.2-923.x86_64
libreport-2.0.9-21.el6.centos.x86_64
nss-softokn-freebl-3.14.3-22.el6_6.x86_64
intel-onesided-devel-3.3-26521.1177_rhel6_qlc.x86_64
libreport-plugin-kerneloops-2.0.9-21.el6.centos.x86_64
pinentry-0.7.6-6.el6.x86_64
redhat-lsb-compat-4.0-7.el6.centos.x86_64
ofed-ibpd-3.4.3-r0.glibc2.12.2.x86_64
libvpx-1.3.0-5.el6_5.x86_64
libsss_idmap-1.11.6-30.el6_6.4.x86_64
dapl-2.1.2-1.glibc2.12.2.x86_64
alsa-utils-1.0.22-9.el6_6.x86_64
librdmacm-1.0.18.1-1.el6.x86_64
udev-147-2.57.el6.x86_64
sssd-ad-1.11.6-30.el6_6.4.x86_64
libmthca-1.0.6-3.el6.x86_64
rpcbind-0.2.0-11.el6.x86_64
libipa_hbac-python-1.11.6-30.el6_6.4.x86_64
libICE-devel-1.0.6-1.el6.x86_64
b43-openfwwf-5.2-4.el6.noarch
libibumad-static-1.3.9-1.el6.x86_64
cryptsetup-luks-1.2.0-11.el6.x86_64
poppler-0.12.4-3.el6_0.1.x86_64
opensm-3.3.17-1.el6.x86_64
python-ethtool-0.6-5.el6.x86_64
unzip-6.0-2.el6_6.x86_64
alien-8.91-1.noarch
foomatic-db-filesystem-4.0-7.20091126.el6.noarch
cvs-1.11.23-16.el6.x86_64
xorg-x11-fonts-misc-7.2-9.1.el6.noarch
glibc-common-2.12-1.149.el6_6.7.x86_64
cas-0.15-1.el6.1.noarch
dejavu-fonts-common-2.30-2.el6.noarch
nfs-utils-lib-1.1.5-9.el6.x86_64
hdparm-9.43-4.el6.x86_64
nscd-2.12-1.149.el6_6.7.x86_64
tcpdump-4.0.0-3.20090921gitdf3cb4.2.el6.x86_64
mesa-dri-drivers-10.1.2-2.el6.x86_64
gpg-pubkey-0608b895-4bd22942
libXmu-devel-1.1.1-2.el6.x86_64
nss_compat_ossl-0.9.6-1.el6.x86_64
scl-utils-20120927-27.el6_6.x86_64
libXi-1.7.2-2.2.el6.x86_64
mingetty-1.08-5.el6.x86_64
nspr-4.10.8-1.el6_6.x86_64
gawk-3.1.7-10.el6.x86_64
mesa-libGL-10.1.2-2.el6.x86_64
chkconfig-1.3.49.3-2.el6_4.1.x86_64
srvadmin-deng-snmp-8.1.0-4.8.1.el6.x86_64
readline-6.0-4.el6.x86_64
libtevent-0.9.18-3.el6.x86_64
ustr-1.0.4-9.1.el6.x86_64
srvadmin-idrac-snmp-8.1.0-4.4.7.el6.x86_64
python-chardet-2.0.1-1.el6.centos.noarch
redhat-bookmarks-6-1.el6.centos.noarch
ca-certificates-2015.2.4-65.0.1.el6_6.noarch
setserial-2.17-25.el6.x86_64
libcom_err-1.41.12-21.el6.x86_64
yum-metadata-parser-1.1.2-16.el6.x86_64
srvadmin-storageservices-cli-8.1.0-4.3.1.el6.x86_64
audit-libs-2.3.7-5.el6.x86_64
libidn-1.18-2.el6.x86_64
openssh-askpass-5.3p1-104.el6_6.1.x86_64
eventlog-0.2.13-1.el6.x86_64
leveldb-1.7.0-2.el6.x86_64
java-1.7.0-openjdk-1.7.0.79-2.5.5.3.el6_6.x86_64
ql2100-firmware-1.19.38-3.1.el6.noarch
libgssglue-0.1-11.el6.x86_64
xorg-x11-drv-evdev-2.8.2-4.el6.x86_64
python-markupsafe-0.9.2-4.el6.x86_64
tzdata-2015d-1.el6.noarch
rt61pci-firmware-1.2-7.el6.noarch
libudev-147-2.57.el6.x86_64
system-config-firewall-tui-1.2.27-7.2.el6_6.noarch
glibc2.12.2pkg-libsettings0-3.4.3-1.glibc2.12.2.x86_64
man-pages-3.22-20.el6.noarch
lua-5.1.4-4.1.el6.x86_64
mpss-offload-3.4.3-1.glibc2.12.2.x86_64
libxcb-1.9.1-2.el6.x86_64
libldb-1.1.13-3.el6.x86_64
microcode_ctl-1.17-19.el6.x86_64
pax-3.4-10.1.el6.x86_64
mpss-sysmgmt-micdiagnostic-3.4.3-1.glibc2.12.2.x86_64
xz-4.999.9-0.5.beta.20091007git.el6.x86_64
net-tools-1.60-110.el6_2.x86_64
rpm-build-4.8.0-38.el6_6.x86_64
cairo-1.8.8-3.1.el6.x86_64
glibc2.12.2pkg-libsettings-dev-3.4.3-1.glibc2.12.2.x86_64
libpciaccess-0.13.3-0.1.el6.x86_64
libusb-0.1.12-23.el6.x86_64
openldap-clients-2.4.39-8.el6.x86_64
mpss-sciftutorials-3.4.3-1.glibc2.12.2.x86_64
pth-2.0.7-9.3.el6.x86_64
netperf-doc-2.6.0-r0.glibc2.12.2.x86_64
vim-X11-7.2.411-1.8.el6.x86_64
logrotate-3.7.8-17.el6.x86_64
perl-Digest-SHA-5.47-136.el6_6.1.x86_64
numactl-2.0.9-2.el6.x86_64
sysstat-9.0.4-27.el6.x86_64
perl-Error-0.17015-4.el6.noarch
valgrind-3.8.1-3.7.el6.x86_64
libtiff-devel-3.9.4-10.el6_5.x86_64
systemtap-runtime-2.5-5.el6.x86_64
libwmf-lite-0.2.8.4-23.el6.x86_64
xml-common-0.6.3-33.el6.noarch
quota-3.17-21.el6_5.x86_64
dmraid-1.0.0.rc16-11.el6.x86_64
mvapich_gcc-1.2.0-3635.x86_64
sos-2.2-68.el6.centos.noarch
perl-IPC-Cmd-0.56-136.el6_6.1.x86_64
patchutils-0.3.1-3.1.el6.x86_64
hal-info-20090716-3.1.el6.noarch
mvapich_pgi_qlc-1.2.0-3635.x86_64
perl-Time-Piece-1.15-136.el6_6.1.x86_64
xorg-x11-font-utils-7.2-11.el6.x86_64
perl-ExtUtils-Embed-1.28-136.el6_6.1.x86_64
tcl-8.5.7-6.el6.x86_64
python-iwlib-0.1-1.2.el6.x86_64
mvapich2_intel_qlc-1.8.1-1.x86_64
libreport-compat-2.0.9-21.el6.centos.x86_64
libicu-devel-4.2.1-9.1.el6_2.x86_64
intel-shmem-3.3-26521.1177_rhel6_qlc.x86_64
elinks-0.12-0.21.pre5.el6_3.x86_64
abrt-addon-ccpp-2.0.8-26.el6.centos.x86_64
MAKEDEV-3.24-6.el6.x86_64
kernel-2.6.32-504.8.1.el6.x86_64
redhat-lsb-core-4.0-7.el6.centos.x86_64
dbus-glib-0.86-6.el6.x86_64
gzip-1.3.12-22.el6.x86_64
kernel-devel-2.6.32-504.8.1.el6.x86_64
python-smbios-2.2.27-4.12.1.el6.x86_64
sg3_utils-libs-1.28-6.el6.x86_64
dash-0.5.5.1-4.el6.x86_64
samba-winbind-3.6.23-14.el6_6.x86_64
libibumad-1.3.9-1.el6.x86_64
iproute-2.6.32-33.el6_6.x86_64
cracklib-2.8.16-4.el6.x86_64
sssd-client-1.11.6-30.el6_6.4.x86_64
opensm-devel-3.3.17-1.el6.x86_64
openssh-5.3p1-104.el6_6.1.x86_64
sssd-proxy-1.11.6-30.el6_6.4.x86_64
iwl5150-firmware-8.24.2.2-1.el6.noarch
ibutils-1.5.7-9.el6.x86_64
cyrus-sasl-plain-2.1.23-15.el6_6.2.x86_64
libXau-devel-1.0.6-4.el6.x86_64
qperf-0.4.9-1.el6.x86_64
kernel-2.6.32-504.12.2.el6.x86_64
lockdev-1.0.1-18.el6.x86_64
mpss-psm-dev-3.4.3-1.glibc2.12.2.x86_64
pam_krb5-2.3.11-9.el6.x86_64
kernel-devel-2.6.32-504.12.2.el6.x86_64
xorg-x11-twm-1.0.3-5.1.el6.x86_64
iw-3.10-1.1.el6.x86_64
basesystem-10.0-4.el6.noarch
graphviz-tcl-2.26.0-10.el6.x86_64
krb5-libs-1.10.3-37.el6_6.x86_64
libxkbfile-1.0.6-1.1.el6.x86_64
ncurses-base-5.7-3.20090208.el6.x86_64
system-config-firewall-base-1.2.27-7.2.el6_6.noarch
java-1.6.0-openjdk-1.6.0.35-1.13.7.1.el6_6.x86_64
bzip2-devel-1.0.5-7.el6_0.x86_64
zlib-1.2.3-29.el6.x86_64
libXext-1.3.2-2.1.el6.x86_64
xdg-utils-1.0.2-17.20091016cvs.el6.noarch
glibc-2.12-1.149.el6_6.7.i686
xterm-253-1.el6.x86_64
libXext-devel-1.3.2-2.1.el6.x86_64
perl-XML-Twig-3.34-1.el6.noarch
nss-util-3.18.0-1.el6_6.x86_64
expat-2.0.1-11.el6_2.x86_64
libXinerama-1.1.3-2.1.el6.x86_64
xorg-x11-proto-devel-7.7-9.el6.noarch
mlocate-0.22.2-4.el6.x86_64
srvadmin-hapi-8.1.0-4.10.2.el6.x86_64
libgcj-4.4.7-11.el6.x86_64
nano-2.0.9-7.el6.x86_64
libsemanage-2.0.43-4.2.el6.x86_64
srvadmin-omcommon-8.1.0-4.92.1.el6.x86_64
libSM-1.2.1-2.el6.x86_64
python-werkzeug-0.8.3-2.el6.noarch
perl-Pod-Simple-3.13-136.el6_6.1.x86_64
traceroute-2.0.14-2.el6.x86_64
blktrace-1.0.1-6.el6.x86_64
kernel-firmware-2.6.32-504.16.2.el6.noarch
findutils-4.4.2-6.el6.x86_64
irqbalance-1.0.4-10.el6.x86_64
libuuid-2.17.2-12.18.el6.x86_64
eject-2.1.5-17.el6.x86_64
python-iniparse-0.3.1-2.1.el6.noarch
dracut-004-356.el6_6.2.noarch
libnet-1.1.6-7.el6.x86_64
mesa-libGLU-devel-10.1.2-2.el6.x86_64
keyutils-libs-1.4-5.el6.x86_64
iwl5000-firmware-8.83.5.1_1-1.el6_1.1.noarch
pytz-2010h-2.el6.noarch
dbus-1.2.24-8.el6_6.x86_64
python-beaker-1.3.1-7.el6.noarch
tigervnc-server-1.1.0-16.el6.centos.x86_64
libdhash-0.4.3-11.el6.x86_64
iwl4965-firmware-228.61.2.24-2.1.el6.noarch
kernel-headers-2.6.32-504.16.2.el6.x86_64
ghostscript-8.70-19.el6.x86_64
libvorbis-1.2.3-4.el6_2.1.x86_64
numad-0.5-11.20140620git.el6.x86_64
pciutils-libs-3.1.10-4.el6.x86_64
rootfiles-8.1-6.1.el6.noarch
mpss-myo-3.4.3-1.glibc2.12.2.x86_64
openssh-ldap-5.3p1-104.el6_6.1.x86_64
perl-Module-Load-Conditional-0.30-136.el6_6.1.x86_64
mpss-hstreams-3.4.3-1.glibc2.12.2.x86_64
dhclient-4.1.1-43.P1.el6.centos.1.x86_64
libref_array-0.1.4-11.el6.x86_64
SDL-1.2.14-3.el6.x86_64
mpss-core-dev-3.4.3-1.glibc2.12.2.x86_64
bc-1.06.95-1.el6.x86_64
cmake-2.8.12.2-4.el6.x86_64
perl-Compress-Zlib-2.021-136.el6_6.1.x86_64
mpss-coi-staticdev-3.4.3-1.glibc2.12.2.x86_64
db4-utils-4.7.25-18.el6_4.x86_64
m4-1.4.13-5.el6.x86_64
jasper-devel-1.900.1-16.el6_6.3.x86_64
elfutils-0.158-3.2.el6.x86_64
libXdamage-1.1.3-4.el6.x86_64
mpss-mpm-doc-3.4.3-1.glibc2.12.2.x86_64
gdbm-1.8.0-36.el6.x86_64
libXcomposite-0.4.3-4.el6.x86_64
mpss-modules-dev-2.6.32-504.16.2.el6.x86_64-3.4.3-1.x86_64
nmap-5.51-4.el6.x86_64
procps-3.2.8-30.el6.x86_64
python-matplotlib-0.99.1.2-1.el6.x86_64
ofed-scripts-3.5-2.1.gf22c08d.x86_64
libXfont-1.4.5-4.el6_6.x86_64
kbd-misc-1.15-11.el6.noarch
apr-1.3.9-5.el6_2.x86_64
qt-4.6.2-28.el6_5.x86_64
libsysfs-2.1.0-7.el6.x86_64
yum-plugin-fastestmirror-1.1.30-30.el6.noarch
mcelog-101-0.el6.x86_64
xz-lzma-compat-4.999.9-0.5.beta.20091007git.el6.x86_64
keyutils-1.4-5.el6.x86_64
mpitests_mvapich_gcc-3.2-923.x86_64
perl-HTML-Parser-3.64-2.el6.x86_64
perl-File-Fetch-0.26-136.el6_6.1.x86_64
mesa-private-llvm-3.4-3.el6.x86_64
mpitests_mvapich_pgi_qlc-3.2-923.x86_64
ctags-5.8-2.el6.x86_64
tmpwatch-2.9.16-4.el6.x86_64
perl-core-5.10.1-136.el6_6.1.x86_64
libproxy-python-0.3.0-10.el6.x86_64
mpitests_mvapich2_intel_qlc-3.2-923.x86_64
pam-tacplus-1.3.9-1.el6.x86_64
libsmbios-2.2.27-4.12.1.el6.x86_64
abrt-libs-2.0.8-26.el6.centos.x86_64
oddjob-0.30-5.el6.x86_64
intel-onesided-3.3-26521.1177_rhel6_qlc.x86_64
libreport-cli-2.0.9-21.el6.centos.x86_64
redhat-lsb-printing-4.0-7.el6.centos.x86_64
smbios-utils-python-2.2.27-4.12.1.el6.x86_64
time-1.7-37.1.el6.x86_64
environment-modules-3.2.10-1.el6_5.x86_64
libhugetlbfs-2.16-2.el6.x86_64
ncurses-5.7-3.20090208.el6.x86_64
libipa_hbac-1.11.6-30.el6_6.4.x86_64
kernel-devel-2.6.32-504.3.3.el6.x86_64
libibverbs-1.1.8-3.el6.x86_64
yum-dellsysid-2.2.27-4.12.1.el6.x86_64
sssd-common-pac-1.11.6-30.el6_6.4.x86_64
ibutils-libs-1.5.7-9.el6.x86_64
iwl100-firmware-39.31.5.1-1.el6.noarch
opensm-static-3.3.17-1.el6.x86_64
libtool-ltdl-2.2.6-15.5.el6.x86_64
urw-fonts-2.4-10.el6.noarch
torque-client-5.1.0-3.x86_64
hal-0.5.14-14.el6.x86_64
acpid-1.0.10-2.1.el6.x86_64
perftest-2.2-1.el6.x86_64
Loc_N_Intel
Hi Mona,
Just in case you didn't start ibscif vitual adaptor for the coprocessor, please do so:
# service ofed-mic start
Mona_L_
I did start all the services.
i can run this:
monatest@r14n2:~/phi_testing$ mpirun -genv I_MPI_DEBUG=5 -genv I_MPI_FABRICS shm -n 1 -host r14n2-mic0 --env LD_LIBRARY_PATH $MIC_LD_LIBRARY_PATH /home/monatest/phi_testing/montecarlo.mic : -n 1 -host r14n2-mic1 --env LD_LIBRARY_PATH $MIC_LD_LIBRARY_PATH /home/monatest/phi_testing/montecarlo.mic
But as soon as i want to use both MIC's i get errors like this:
r14n2-mic1.int.mona.surfsara.nl.5892scif_connect failed with error 19 (No such device)
 (err=28)
r14n2-mic1.int.mona.surfsara.nl.5894Out of endpoint resources (err=28)
Fatal error in MPI_Init: Internal MPI error!, error stack:
MPIR_Init_thread(784):
MPID_Init(1323)......: channel initialization failed
MPIDI_CH3_Init(141)..:
Is it not possibel to use both MIC's in one host this way?
