Software Archive
Read-only legacy content
17060 Discussions
slow loading application
rennan_s_
Hi, good. I wanted to ask you is, know a way to make the app newly created start quickly. I created an app through the framework app on intel, but he takes too long to start and sometimes even bears. Someone there can help me? Thank you very much in advance.
Amrita_C_Intel
Which Intel XDK Version are you using?
Can you check that does it happens just for this app or every other app?
Try out any samples which is under samples and demos in Intel XDK to check the above stated behaviour.
rennan_s_
vlw friend, checked some demos here, all behave properly. still not figure out why this app is behaving like this.
Elroy_A_Intel
This seems to be a unique issue due to changes that you have added to your project. I recommend that you debug your application using the Debug Tab. On that tab you will be able to debug your application running on your physical device. The developer console provides you with access to the tools needed for evaluating the application's network traffic and profiles.
