Software Archive
Read-only legacy content
stdarg.h files
newport_j
I am starting a new thread on this.
I get the error
compilation aborted for (code4)
/usr/include/libio.h(53): catastrophic error: canot open source file "stdarg.h"
#include
If there is anything in the Intel lit about this? if sothen direct me to it. Iguess that icc header files do not include
stdarg.h.
I did a search and yesit is not Intel Cilk++. .
However, I never explicitly called for stdarg.h like I did math.h
#include
It is looking for stdarg.h anyway. I mustemploy a work around.I am unsure how to do it.
I know in my /usr/include/libio.h (53)
There is a file libio.h in /usr/include/ that calls stdarg.h on line 53.
That does not bother gcc at all, but itis catastrophic for icc.
How do I deal with this?
I am using Ubuntu 11.04 , gcc 4.2.4 and icc 12.0.0 with Intel Cilk++.
Any help appreciated.
Newport_j
Brandon_H_Intel
As I've stated in other threads, try upgrading to update 6 or later and see if that helps with this.
SergeyKostrov
Valued Contributor II
Quoting newport_j
#include
[SergeyK] Is there any possibility that your development environment is corrupted? When did you
install the GCC compiler?
[SergeyK] Could you attach a'libio.h' for areview?
Sergey
PS:
By the way, this isa content of'stdarg.h' file that I have and it has a very interesting comment:
* This is just an RC_INVOKED guard for the real stdarg.h
* fixincluded in gcc system dir. One day we will delete this file.
#ifndef RC_INVOKED
#include_next
#endif
There is nothing else in the header! My installation is about 6 years old.
newport_j
What you say is true. I made a test program that prove that. It is called square.c (attached). Put in stdio.h as an include filecompile with gcc it does not complain. Compile with icc and get the error in question. Simple.
But what about all the icc example icccode with extension *.c that has a include file stdio.h in the include file section. I saw that and thought there must be something wrong.
It is there in icc c code. Explain.
Newport_j
Barry_T_Intel
Try adding the -H option to your compilation command line. It will display the include files as they're brought in.
- Barry
Brandon_H_Intel
Again, I have to reiterate, you really need to upgrade to update 6. The 12.0 compiler was never tested on and does not support Ubuntu 11.04, and header problems like this are very typical when running the compiler on operating systems newer than what is supported. If you still see these problems with the 12.1 compiler that does support 11.04, then we can work from there. I strongly suspect though that these tests will work.
SergeyKostrov
Quoting newport_j
I would follow aBarry's advise( Post #4 )"...adding the -H option to your compilation command line..."
