Software Archive
Read-only legacy content
17060 Discussions
styles and properties of button and text won't change or update
Sey_T_
Hi, Please see the images. nothing changes  after I apply color or font  styles to text. Likewise, button's color won't change after I select a different color style. Is this a bug or my computer is too slow or what? can someone help me please? Thanks
Chris_P_Intel
Looks like a bug. But it's easy to workaround, and a learning opportunity.
If you look at the "HTML Preview" tab you might see something like this:
<div class="navbar inner-element uib_w_1 tt hhh" data-uib="framework7/header" data-ver="0">
    <div class="navbar-inner">
        <div class="left"></div>
        <div class="center">Header</div>
        <div class="right"></div>
    </div>
</div>
and if you look at the Less preview for that text style, you might see something like this
@media all {
     .hhh a {
       color:#2037d9 !important;
Now, in my example, I made a simple text style that only sets color and its name is "hhh"
So, you can pretty easily see that the selector in the LESS file is wrong.   It is   .hhh a
but it should be  .hhh .center
So the solution is to click the EDIT LESS button from the LESS Preview pane and change the selector.  Here is mine modified
@media all {
     .hhh .center {
And after making and saving that change and switching back to App Designer, things are working.  Of course, if I use that style again, it won't parse out the values correctly, and it'll clobber my changes when it updates. But that's easily avoidable.
Chris_P_Intel
    </div>
</div>
@media all {
     .hhh a {
@media all {
     .hhh .center {
Sey_T_
thanks Chris, I will try editing from LESS pane.
Sey_T_
 Hi Chris.
Thanks. that worked well.
