Software Archive
Read-only legacy content
17060 Discussions
trouble installing mpss 3.1
shane_k_
on rhel6.4 installing via: "yum install --nogpgcheck --noplugins --disablerepo=* *.rpm" results in many dependency complaints:
-snip-
--> Finished Dependency Resolution
Error: Package: glibc2.12.2pkg-libmicaccesssdk-dev-3.1-0.1.build0.glibc2.12.2.x86_64 (/glibc2.12.2pkg-libmicaccesssdk-dev-3.1-0.1.build0.glibc2.12.2.x86_64)
Requires: mpss-modules-headers-dev
Error: Package: mpss-coi-dev-3.1-0.1.build0.glibc2.12.2.x86_64 (/mpss-coi-dev-3.1-0.1.build0.glibc2.12.2.x86_64)
Requires: mpss-coi
Error: Package: mpss-metadata-dev-3.1-0.1.build0.glibc2.12.2.x86_64 (/mpss-metadata-dev-3.1-0.1.build0.glibc2.12.2.x86_64)
Requires: mpss-metadata
Error: Package: mpss-daemon-dev-3.1-0.1.build0.glibc2.12.2.x86_64 (/mpss-daemon-dev-3.1-0.1.build0.glibc2.12.2.x86_64)
Requires: mpss-daemon
Error: Package: libscif-dev-3.1-0.1.build0.glibc2.12.2.x86_64 (/libscif-dev-3.1-0.1.build0.glibc2.12.2.x86_64)
Error: Package: glibc2.12.2pkg-libodmdebug-dev-3.1-0.1.build0.glibc2.12.2.x86_64 (/glibc2.12.2pkg-libodmdebug-dev-3.1-0.1.build0.glibc2.12.2.x86_64)
Error: Package: mpss-micmgmt-doc-3.1-0.1.build0.glibc2.12.2.x86_64 (/mpss-micmgmt-doc-3.1-0.1.build0.glibc2.12.2.x86_64)
Requires: glibc2.12.2pkg-mpss-rasmm-kernel
Error: Package: mpss-micmgmt-3.1-0.1.build0.glibc2.12.2.x86_64 (/mpss-micmgmt-3.1-0.1.build0.glibc2.12.2.x86_64)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
package mpss-coi, required for mpss-coi-dev, does not exist in the download
uninstalled mpss3.0 via:  rpm -qa | grep intel-mic | awk '{system("rpm -e --nodeps "$1)}'
root@mic-a:~/mpss-3.1 # uname -a
Linux mic-a.ptest.sas.com 2.6.32-358.14.1.el6.x86_64 #1 SMP Mon Jun 17 15:54:20 EDT 2013 x86_64 x86_64 x86_64 GNU/Linux
root@mic-a:~/mpss-3.1 # rpm -qa | sort
abrt-2.0.8-15.el6.x86_64
abrt-addon-ccpp-2.0.8-15.el6.x86_64
abrt-addon-kerneloops-2.0.8-15.el6.x86_64
abrt-addon-python-2.0.8-15.el6.x86_64
abrt-cli-2.0.8-15.el6.x86_64
abrt-libs-2.0.8-15.el6.x86_64
abrt-tui-2.0.8-15.el6.x86_64
acl-2.2.49-6.el6.x86_64
acpid-1.0.10-2.1.el6.x86_64
aic94xx-firmware-30-2.el6.noarch
alsa-lib-1.0.22-3.el6.x86_64
alsa-utils-1.0.22-5.el6.x86_64
ant-1.7.1-13.el6.x86_64
ant-antlr-1.7.1-13.el6.x86_64
ant-apache-bcel-1.7.1-13.el6.x86_64
ant-apache-bsf-1.7.1-13.el6.x86_64
ant-apache-log4j-1.7.1-13.el6.x86_64
ant-apache-oro-1.7.1-13.el6.x86_64
ant-apache-regexp-1.7.1-13.el6.x86_64
ant-apache-resolver-1.7.1-13.el6.x86_64
ant-commons-logging-1.7.1-13.el6.x86_64
ant-commons-net-1.7.1-13.el6.x86_64
ant-javamail-1.7.1-13.el6.x86_64
ant-jdepend-1.7.1-13.el6.x86_64
ant-jsch-1.7.1-13.el6.x86_64
ant-junit-1.7.1-13.el6.x86_64
antlr-2.7.7-6.5.el6.x86_64
ant-nodeps-1.7.1-13.el6.x86_64
ant-swing-1.7.1-13.el6.x86_64
ant-trax-1.7.1-13.el6.x86_64
apache-jasper-5.5.28-3.el6.noarch
apache-tomcat-apis-0.1-1.el6.noarch
apr-1.3.9-5.el6_2.x86_64
apr-devel-1.3.9-5.el6_2.x86_64
at-3.1.10-43.el6_2.1.x86_64
atk-1.28.0-2.el6.x86_64
atmel-firmware-1.3-7.el6.noarch
attr-2.4.44-7.el6.x86_64
audit-2.2-2.el6.x86_64
audit-libs-2.2-2.el6.x86_64
authconfig-6.1.12-13.el6.x86_64
autoconf-2.63-5.1.el6.noarch
autofs-5.0.5-74.el6_4.x86_64
automake-1.11.1-4.el6.noarch
avahi-0.6.25-12.el6.x86_64
avahi-glib-0.6.25-12.el6.x86_64
avahi-libs-0.6.25-12.el6.x86_64
axis-1.2.1-7.3.el6_3.noarch
b43-fwcutter-012-2.2.el6.x86_64
b43-openfwwf-5.2-4.el6.noarch
basesystem-10.0-4.el6.noarch
bash-4.1.2-15.el6_4.x86_64
bc-1.06.95-1.el6.x86_64
bcel-5.2-7.2.el6.x86_64
bfa-firmware-3.0.3.1-1.el6.noarch
bind-libs-9.8.2-0.17.rc1.el6_4.5.x86_64
bind-utils-9.8.2-0.17.rc1.el6_4.5.x86_64
binutils-2.20.51.0.2-5.36.el6.x86_64
biosdevname-0.4.1-3.el6.x86_64
bison-2.4.1-5.el6.x86_64
blktrace-1.0.1-6.el6.x86_64
bridge-utils-1.2-10.el6.x86_64
bsf-2.4.0-4.1.el6.noarch
btparser-0.17-1.el6.x86_64
busybox-1.15.1-15.el6.x86_64
bzip2-1.0.5-7.el6_0.x86_64
bzip2-libs-1.0.5-7.el6_0.x86_64
ca-certificates-2010.63-3.el6_1.5.noarch
cairo-1.8.8-3.1.el6.x86_64
cdparanoia-libs-10.2-5.1.el6.x86_64
checkpolicy-2.0.22-1.el6.x86_64
chkconfig-1.3.49.3-2.el6.x86_64
classpathx-jaf-1.0-15.4.el6.x86_64
classpathx-mail-1.1.1-9.4.el6.noarch
cloog-ppl-0.15.7-1.2.el6.x86_64
compat-dapl-1.2.19-2.el6.x86_64
compat-dapl-devel-1.2.19-1.x86_64
compat-libstdc++-33-3.2.3-69.el6.i686
comps-extras-17.8-1.el6.noarch
ConsoleKit-0.4.1-3.el6.x86_64
ConsoleKit-libs-0.4.1-3.el6.x86_64
coreutils-8.4-19.el6_4.2.x86_64
coreutils-libs-8.4-19.el6_4.2.x86_64
cpio-2.10-11.el6_3.x86_64
cpp-4.4.7-3.el6.x86_64
cpuspeed-1.5-20.el6_4.x86_64
cracklib-2.8.16-4.el6.x86_64
cracklib-dicts-2.8.16-4.el6.x86_64
crash-6.1.0-1.el6.x86_64
crda-1.1.1_2010.11.22-1.el6.x86_64
cronie-1.4.4-7.el6.x86_64
cronie-anacron-1.4.4-7.el6.x86_64
crontabs-1.10-33.el6.noarch
cryptsetup-luks-1.2.0-7.el6.x86_64
cryptsetup-luks-libs-1.2.0-7.el6.x86_64
cups-1.4.2-50.el6_4.5.x86_64
cups-libs-1.4.2-50.el6_4.5.x86_64
curl-7.19.7-37.el6_4.x86_64
cvs-1.11.23-15.el6.x86_64
cyrus-sasl-2.1.23-13.el6_3.1.x86_64
cyrus-sasl-lib-2.1.23-13.el6_3.1.x86_64
cyrus-sasl-plain-2.1.23-13.el6_3.1.x86_64
dapl-2.0.34-1.x86_64
dapl-debuginfo-2.0.34-1.x86_64
dapl-devel-2.0.34-1.x86_64
dapl-devel-static-2.0.34-1.x86_64
dapl-utils-2.0.34-1.x86_64
dash-0.5.5.1-4.el6.x86_64
db4-4.7.25-17.el6.x86_64
db4-utils-4.7.25-17.el6.x86_64
dbus-1.2.24-7.el6_3.x86_64
dbus-glib-0.86-6.el6_4.x86_64
dbus-libs-1.2.24-7.el6_3.x86_64
dbus-python-0.83.0-6.1.el6.x86_64
dejavu-fonts-common-2.30-2.el6.noarch
dejavu-lgc-sans-mono-fonts-2.30-2.el6.noarch
dejavu-sans-mono-fonts-2.30-2.el6.noarch
desktop-file-utils-0.15-9.el6.x86_64
device-mapper-1.02.77-9.el6.x86_64
device-mapper-event-1.02.77-9.el6.x86_64
device-mapper-event-libs-1.02.77-9.el6.x86_64
device-mapper-libs-1.02.77-9.el6.x86_64
device-mapper-persistent-data-0.1.4-1.el6.x86_64
dhclient-4.1.1-34.P1.el6.x86_64
dhcp-common-4.1.1-34.P1.el6.x86_64
diffutils-2.8.1-28.el6.x86_64
dmidecode-2.11-2.el6_1.x86_64
dmraid-1.0.0.rc16-11.el6.x86_64
dmraid-events-1.0.0.rc16-11.el6.x86_64
dmz-cursor-themes-0.4-4.el6.noarch
dosfstools-3.0.9-4.el6.x86_64
dracut-004-303.el6.noarch
dracut-kernel-004-303.el6.noarch
e2fsprogs-1.41.12-14.el6_4.2.x86_64
e2fsprogs-libs-1.41.12-14.el6_4.2.x86_64
ecj-3.4.2-6.el6.x86_64
ed-1.1-3.3.el6.x86_64
efibootmgr-0.5.4-10.el6.x86_64
eggdbus-0.6-3.el6.x86_64
eject-2.1.5-17.el6.x86_64
elfutils-0.152-1.el6.x86_64
elfutils-libelf-0.152-1.el6.x86_64
elfutils-libs-0.152-1.el6.x86_64
enchant-1.5.0-4.el6.x86_64
ethtool-3.5-1.el6.x86_64
expat-2.0.1-11.el6_2.x86_64
expat-devel-2.0.1-11.el6_2.x86_64
file-5.04-15.el6.x86_64
file-libs-5.04-15.el6.x86_64
filesystem-2.4.30-3.el6.x86_64
findutils-4.4.2-6.el6.x86_64
fipscheck-1.2.0-7.el6.x86_64
fipscheck-lib-1.2.0-7.el6.x86_64
firefox-17.0.8-1.el6_4.x86_64
flac-1.2.1-6.1.el6.x86_64
flex-2.5.35-8.el6.x86_64
fontconfig-2.8.0-3.el6.x86_64
fontpackages-filesystem-1.41-1.1.el6.noarch
foomatic-4.0.4-1.el6_1.1.x86_64
foomatic-db-4.0-7.20091126.el6.noarch
foomatic-db-filesystem-4.0-7.20091126.el6.noarch
foomatic-db-ppds-4.0-7.20091126.el6.noarch
fortune-1.0-37.2.el6.rf.x86_64
fprintd-0.1-20.git04fd09cfa.el6.x86_64
fprintd-pam-0.1-20.git04fd09cfa.el6.x86_64
freetype-2.3.11-14.el6_3.1.x86_64
gamin-0.1.10-9.el6.x86_64
gawk-3.1.7-10.el6.x86_64
gcc-4.4.7-3.el6.x86_64
gcc-c++-4.4.7-3.el6.x86_64
gcc-gfortran-4.4.7-3.el6.x86_64
GConf2-2.28.0-6.el6.x86_64
gd-2.0.35-11.el6.x86_64
gdb-7.2-60.el6_4.1.x86_64
gdbm-1.8.0-36.el6.x86_64
gedit-2.28.4-3.el6.x86_64
geronimo-specs-1.0-3.5.M2.el6.noarch
geronimo-specs-compat-1.0-3.5.M2.el6.noarch
gettext-0.17-16.el6.x86_64
ghostscript-8.70-15.el6_4.1.x86_64
ghostscript-fonts-5.50-23.1.el6.noarch
giflib-4.1.6-3.1.el6.x86_64
glib2-2.22.5-7.el6.x86_64
glibc-2.12-1.107.el6_4.2.i686
glibc-2.12-1.107.el6_4.2.x86_64
glibc-common-2.12-1.107.el6_4.2.x86_64
glibc-devel-2.12-1.107.el6_4.2.i686
glibc-devel-2.12-1.107.el6_4.2.x86_64
glibc-headers-2.12-1.107.el6_4.2.x86_64
gmp-4.3.1-7.el6_2.2.x86_64
gnome-desktop-2.28.2-11.el6.x86_64
gnome-icon-theme-2.28.0-2.el6.noarch
gnome-keyring-2.28.2-8.el6_3.x86_64
gnome-python2-2.28.0-3.el6.x86_64
gnome-python2-canvas-2.28.0-3.el6.x86_64
gnome-python2-desktop-2.28.0-4.el6.x86_64
gnome-python2-gnome-2.28.0-3.el6.x86_64
gnome-python2-gnomevfs-2.28.0-3.el6.x86_64
gnome-themes-2.28.1-6.el6.noarch
gnome-vfs2-2.24.2-6.el6.x86_64
gnupg2-2.0.14-4.el6.x86_64
gnutls-2.8.5-10.el6_4.2.x86_64
gpgme-1.1.8-3.el6.x86_64
gpg-pubkey-2fa658e0-45700c69
gpg-pubkey-fd431d51-4ae0493b
gpm-libs-1.20.6-12.el6.x86_64
graphviz-2.26.0-10.el6.x86_64
graphviz-tcl-2.26.0-10.el6.x86_64
grep-2.6.3-3.el6.x86_64
groff-1.18.1.4-21.el6.x86_64
grub-0.97-81.el6.x86_64
grubby-7.0.15-3.el6.x86_64
gstreamer-0.10.29-1.el6.x86_64
gstreamer-plugins-base-0.10.29-2.el6.x86_64
gstreamer-tools-0.10.29-1.el6.x86_64
gtk2-2.18.9-12.el6.x86_64
gtk2-engines-2.18.4-5.el6.x86_64
gtksourceview2-2.8.2-4.el6.x86_64
gzip-1.3.12-19.el6_4.x86_64
hal-0.5.14-11.el6.x86_64
hal-info-20090716-3.1.el6.noarch
hal-libs-0.5.14-11.el6.x86_64
hamcrest-1.1-9.4.el6.x86_64
hdparm-9.16-3.4.el6.x86_64
hesiod-3.1.0-19.el6.x86_64
hicolor-icon-theme-0.11-1.1.el6.noarch
hsqldb-1.8.0.10-10.el6.noarch
hunspell-1.2.8-16.el6.x86_64
hunspell-en-0.20090216-7.1.el6.noarch
hwdata-0.233-7.9.el6.noarch
ibacm-1.0.8-0.git7a3adb7.el6.x86_64
ibsim-0.5-7.el6.x86_64
ibsim-debuginfo-0.5-0.1.g327c3d8.x86_64
ibutils-1.5.7-7.el6.x86_64
ibutils-libs-1.5.7-7.el6.x86_64
infiniband-diags-1.5.13-1.x86_64
infinipath-psm-2.9-926.1005_open.x86_64
infinipath-psm-devel-2.9-926.1005_open.x86_64
info-4.13a-8.el6.x86_64
initscripts-9.03.38-1.el6_4.2.x86_64
intel-advisor-xe-cli-251878-13.1-1.i486
intel-advisor-xe-cli-251878-13.1-1.x86_64
intel-advisor-xe-cli-common-251878-13.1-1.noarch
intel-advisor-xe-doc-251878-13.1-1.noarch
intel-advisor-xe-gui-251878-13.1-1.x86_64
intel-advisor-xe-gui-common-251878-13.1-1.noarch
intel-compilerproc-080-14.0-0.i486
intel-compilerproc-080-14.0-0.x86_64
intel-compilerproc-117-13.0-1.i486
intel-compilerproc-117-13.0-1.x86_64
intel-compilerproc-common-080-14.0-0.noarch
intel-compilerproc-common-117-13.0-1.noarch
intel-compilerproc-devel-080-14.0-0.i486
intel-compilerproc-devel-080-14.0-0.x86_64
intel-compilerproc-devel-117-13.0-1.i486
intel-compilerproc-devel-117-13.0-1.x86_64
intel-compilerpro-common-080-14.0-0.noarch
intel-compilerpro-common-117-13.0-1.noarch
intel-compilerpro-common-pset-080-14.0-0.noarch
intel-compilerpro-devel-080-14.0-0.i486
intel-compilerpro-devel-080-14.0-0.x86_64
intel-compilerpro-devel-117-13.0-1.i486
intel-compilerpro-devel-117-13.0-1.x86_64
intel-compilerprof-117-13.0-1.i486
intel-compilerprof-117-13.0-1.x86_64
intel-compilerprof-common-117-13.0-1.noarch
intel-compilerprof-devel-117-13.0-1.i486
intel-compilerprof-devel-117-13.0-1.x86_64
intel-compilerpro-vars-080-14.0-0.noarch
intel-compilerpro-vars-117-13.0-1.noarch
intel-gdb-080-13.0-0.x86_64
intel-gdb-cdt-080-13.0-0.x86_64
intel-gdb-common-080-13.0-0.noarch
intel-gdb-mic-080-13.0-0.x86_64
intel-gdb-mpm-080-13.0-0.x86_64
intel-gdb-server-080-13.0-0.x86_64
intel-gdb-toplevel-080-13.0-0.noarch
intel-icsxe-4.0.3p-028.noarch
intel-icsxe-intel64-4.0.3p-028.x86_64
intel-idb-080-13.0-0.i486
intel-idb-080-13.0-0.x86_64
intel-idb-117-13.0-1.i486
intel-idb-117-13.0-1.x86_64
intel-idbcdt-080-13.0-0.noarch
intel-idbcdt-117-13.0-1.noarch
intel-idb-common-080-13.0-0.noarch
intel-idb-common-117-13.0-1.noarch
intel-imb-3.2.4p-001.noarch
intel-inspector-xe-cli-250094-13.1-2.i486
intel-inspector-xe-cli-250094-13.1-2.x86_64
intel-inspector-xe-cli-common-250094-13.1-2.noarch
intel-inspector-xe-doc-250094-13.1-2.noarch
intel-inspector-xe-gui-250094-13.1-2.x86_64
intel-inspector-xe-gui-common-250094-13.1-2.noarch
intel-ipp-117-7.1-1.i486
intel-ipp-117-7.1-1.x86_64
intel-ipp-common-080-8.0-1.noarch
intel-ipp-common-117-7.1-1.noarch
intel-ipp-common-devel-080-8.0-1.i486
intel-ipp-common-devel-080-8.0-1.x86_64
intel-ipp-devel-117-7.1-1.i486
intel-ipp-devel-117-7.1-1.x86_64
intel-ipp-st-080-8.0-1.i486
intel-ipp-st-080-8.0-1.x86_64
intel-ipp-st-devel-080-8.0-1.i486
intel-ipp-st-devel-080-8.0-1.x86_64
intel-mkl-080-11.1-0.i486
intel-mkl-080-11.1-0.x86_64
intel-mkl-117-11.0-1.i486
intel-mkl-117-11.0-1.x86_64
intel-mkl-common-080-11.1-0.noarch
intel-mkl-common-117-11.0-1.noarch
intel-mkl-devel-080-11.1-0.i486
intel-mkl-devel-080-11.1-0.x86_64
intel-mkl-devel-117-11.0-1.i486
intel-mkl-devel-117-11.0-1.x86_64
intel-mkl-f95-common-080-11.1-0.noarch
intel-mkl-f95-devel-080-11.1-0.i486
intel-mkl-f95-devel-080-11.1-0.x86_64
intel-mkl-gnu-080-11.1-0.i486
intel-mkl-gnu-080-11.1-0.x86_64
intel-mkl-gnu-devel-080-11.1-0.i486
intel-mkl-gnu-devel-080-11.1-0.x86_64
intel-mkl-mic-080-11.1-0.x86_64
intel-mkl-mic-devel-080-11.1-0.x86_64
intel-mpi-4.1.0p-024.noarch
intel-mpi-ia32-4.1.0p-024.i486
intel-mpi-intel64-4.1.0p-024.x86_64
intel-mpi-mic-4.1.0p-024.x86_64
intel-mpi-rt-4.1.0p-024.noarch
intel-mpi-rt-ia32-4.1.0p-024.i486
intel-mpi-rt-intel64-4.1.0p-024.x86_64
intel-mpi-rt-mic-4.1.0p-024.x86_64
intel-openmp-080-14.0-0.i486
intel-openmp-080-14.0-0.x86_64
intel-openmp-117-13.0-1.i486
intel-openmp-117-13.0-1.x86_64
intel-openmp-devel-080-14.0-0.i486
intel-openmp-devel-080-14.0-0.x86_64
intel-openmp-devel-117-13.0-1.i486
intel-openmp-devel-117-13.0-1.x86_64
intel-sourcechecker-common-080-14.0-0.noarch
intel-sourcechecker-common-117-13.0-1.noarch
intel-sourcechecker-devel-080-14.0-0.i486
intel-sourcechecker-devel-080-14.0-0.x86_64
intel-sourcechecker-devel-117-13.0-1.i486
intel-sourcechecker-devel-117-13.0-1.x86_64
intel-tac_em64t-8.1.0p-024.x86_64
intel-tac_mic-8.1.0p-024.x86_64
intel-ta_em64t-8.1.0p-024.x86_64
intel-tatc_em64t-8.1.0p-024.x86_64
intel-tatc_mic-8.1.0p-024.x86_64
intel-tbb-080-4.2-0.noarch
intel-tbb-117-4.1-1.noarch
intel-tbb-devel-080-4.2-0.noarch
intel-tbb-devel-117-4.1-1.noarch
intel-tc_impi_em64t-8.1.0p-024.x86_64
intel-tc_impi_mic-8.1.0p-024.x86_64
intel-vtune-amplifier-xe-cli-253325-13.1-2.i486
intel-vtune-amplifier-xe-cli-253325-13.1-2.x86_64
intel-vtune-amplifier-xe-cli-common-253325-13.1-2.noarch
intel-vtune-amplifier-xe-collector-target-253325-13.1-2.i486
intel-vtune-amplifier-xe-collector-target-253325-13.1-2.x86_64
intel-vtune-amplifier-xe-common-253325-13.1-2.noarch
intel-vtune-amplifier-xe-doc-253325-13.1-2.noarch
intel-vtune-amplifier-xe-gui-253325-13.1-2.x86_64
intel-vtune-amplifier-xe-gui-common-253325-13.1-2.noarch
intel-vtune-amplifier-xe-pwr-253325-13.1-2.noarch
intel-vtune-amplifier-xe-sep-253325-13.1-2.noarch
iproute-2.6.32-23.el6.x86_64
iptables-1.4.7-9.el6.x86_64
iptables-ipv6-1.4.7-9.el6.x86_64
iputils-20071127-17.el6_4.x86_64
ipw2100-firmware-1.3-11.el6.noarch
ipw2200-firmware-3.1-4.el6.noarch
irqbalance-1.0.4-4.el6_4.x86_64
iscsi-initiator-utils-6.2.0.873-2.el6.x86_64
iso-codes-3.16-2.el6.noarch
ivtv-firmware-20080701-20.2.noarch
iw-0.9.17-4.el6.x86_64
iwl1000-firmware-39.31.5.1-1.el6.noarch
iwl100-firmware-39.31.5.1-1.el6.noarch
iwl3945-firmware-15.32.2.9-4.el6.noarch
iwl4965-firmware-228.61.2.24-2.1.el6.noarch
iwl5000-firmware-8.83.5.1_1-1.el6_1.1.noarch
iwl5150-firmware-8.24.2.2-1.el6.noarch
iwl6000-firmware-9.221.4.1-1.el6.noarch
iwl6000g2a-firmware-17.168.5.3-1.el6.noarch
iwl6000g2b-firmware-17.168.5.2-1.el6.noarch
iwl6050-firmware-41.28.5.1-2.el6.noarch
jakarta-commons-codec-1.3-11.7.el6.x86_64
jakarta-commons-discovery-0.4-5.4.el6.noarch
jakarta-commons-el-1.0-18.4.el6.noarch
jakarta-commons-httpclient-3.1-0.7.el6_3.x86_64
jakarta-commons-lang-2.4-1.1.el6.noarch
jakarta-commons-logging-1.0.4-10.el6.noarch
jakarta-commons-net-2.0-2.1.el6.noarch
jakarta-oro-2.0.8-6.6.el6.x86_64
jasper-libs-1.900.1-15.el6_1.1.x86_64
java-1.5.0-gcj-1.5.0.0-29.1.el6.x86_64
java-1.6.0-openjdk-1.6.0.0-1.62.1.11.11.90.el6_4.x86_64
java-1.6.0-openjdk-devel-1.6.0.0-1.62.1.11.11.90.el6_4.x86_64
java-1.6.0-openjdk-javadoc-1.6.0.0-1.62.1.11.11.90.el6_4.x86_64
java_cup-0.10k-5.el6.x86_64
jdepend-2.9-1.2.el6.noarch
jline-0.9.94-0.8.el6.noarch
jpackage-utils-1.7.5-3.12.el6.noarch
jsch-0.1.41-2.2.el6.noarch
junit-3.8.2-6.5.el6.x86_64
junit4-4.5-5.3.el6.noarch
jzlib-1.0.7-7.5.el6.x86_64
kbd-1.15-11.el6.x86_64
kbd-misc-1.15-11.el6.noarch
kernel-2.6.32-131.0.15.el6.x86_64
kernel-2.6.32-131.30.1.el6.x86_64
kernel-2.6.32-358.14.1.el6.x86_64
kernel-devel-2.6.32-131.30.1.el6.x86_64
kernel-devel-2.6.32-358.14.1.el6.x86_64
kernel-devel-2.6.32-358.23.2.el6.x86_64
kernel-firmware-2.6.32-358.14.1.el6.noarch
kernel-headers-2.6.32-358.14.1.el6.x86_64
kexec-tools-2.0.0-258.el6_4.2.x86_64
keyutils-1.4-4.el6.x86_64
keyutils-libs-1.4-4.el6.x86_64
kpartx-0.4.9-64.el6_4.1.x86_64
krb5-libs-1.10.3-10.el6_4.4.x86_64
ksh-20100621-19.el6_4.4.x86_64
lcms-libs-1.19-1.el6.x86_64
less-436-10.el6.x86_64
libacl-2.2.49-6.el6.x86_64
libaio-0.3.107-10.el6.x86_64
libarchive-2.8.3-4.el6_2.x86_64
libart_lgpl-2.3.20-5.1.el6.x86_64
libasyncns-0.8-1.1.el6.x86_64
libattr-2.4.44-7.el6.x86_64
libblkid-2.17.2-12.9.el6_4.3.x86_64
libbonobo-2.24.2-5.el6.x86_64
libbonoboui-2.24.2-3.el6.x86_64
libcanberra-0.22-1.el6.x86_64
libcanberra-gtk2-0.22-1.el6.x86_64
libcap-2.16-5.5.el6.x86_64
libcap-ng-0.6.4-3.el6_0.1.x86_64
libcom_err-1.41.12-14.el6_4.2.x86_64
libconfuse-2.7-6.2.x86_64
libconfuse-devel-2.7-6.2.x86_64
libcurl-7.19.7-37.el6_4.x86_64
libcxgb3-1.3.1-1.el6.x86_64
libcxgb3-debuginfo-1.3.1-1.x86_64
libcxgb4-1.2.0-1.el6.x86_64
libcxgb4-debuginfo-1.2.0-1.x86_64
libdaemon-0.14-1.el6.x86_64
libdrm-2.4.39-1.el6.x86_64
libedit-2.11-4.20080712cvs.1.el6.x86_64
liberation-fonts-common-1.05.1.20090721-5.el6.noarch
liberation-mono-fonts-1.05.1.20090721-5.el6.noarch
liberation-sans-fonts-1.05.1.20090721-5.el6.noarch
liberation-serif-fonts-1.05.1.20090721-5.el6.noarch
libertas-usb8388-firmware-5.110.22.p23-3.1.el6.noarch
libevent-1.4.13-4.el6.x86_64
libffi-3.0.5-3.2.el6.x86_64
libfontenc-1.0.5-2.el6.x86_64
libfprint-0.1.0-19.pre2.el6.x86_64
libgcc-4.4.7-3.el6.i686
libgcc-4.4.7-3.el6.x86_64
libgcj-4.4.7-3.el6.x86_64
libgcrypt-1.4.5-9.el6_2.2.x86_64
libgfortran-4.4.7-3.el6.x86_64
libglade2-2.6.4-3.1.el6.x86_64
libgnome-2.28.0-11.el6.x86_64
libgnomecanvas-2.26.0-4.el6.x86_64
libgnomeui-2.24.1-4.el6.x86_64
libgomp-4.4.7-3.el6.x86_64
libgpg-error-1.7-4.el6.x86_64
libgssglue-0.1-11.el6.x86_64
libgudev1-147-2.46.el6.x86_64
libibcm-1.0.5-1.x86_64
libibcm-debuginfo-1.0.5-1.x86_64
libibcm-devel-1.0.5-1.x86_64
libibmad-1.3.8-1.x86_64
libibmad-debuginfo-1.3.8-1.x86_64
libibmad-devel-1.3.8-1.x86_64
libibmad-static-1.3.8-1.x86_64
libibumad-1.3.7-1.x86_64
libibumad-debuginfo-1.3.7-1.x86_64
libibumad-devel-1.3.7-1.x86_64
libibumad-static-1.3.7-1.x86_64
libibverbs-1.1.6-5.el6.x86_64
libibverbs-debuginfo-1.1.4-1.24.gb89d4d7.x86_64
libibverbs-devel-1.1.6-5.el6.x86_64
libibverbs-devel-static-1.1.4-1.24.gb89d4d7.x86_64
libibverbs-utils-1.1.6-5.el6.x86_64
libICE-1.0.6-1.el6.x86_64
libIDL-0.8.13-2.1.el6.x86_64
libidn-1.18-2.el6.x86_64
libipathverbs-1.2-4.el6.x86_64
libipathverbs-debuginfo-1.2-1.x86_64
libjpeg-turbo-1.2.1-1.el6.x86_64
libmlx4-1.0.1-1.20.g6771d22.x86_64
libmlx4-debuginfo-1.0.1-1.20.g6771d22.x86_64
libmlx4-devel-1.0.1-1.20.g6771d22.x86_64
libmng-1.0.10-4.1.el6.x86_64
libmthca-1.0.5-0.1.gbe5eef3.x86_64
libmthca-debuginfo-1.0.5-0.1.gbe5eef3.x86_64
libmthca-devel-static-1.0.5-0.1.gbe5eef3.x86_64
libnes-1.1.3-1.x86_64
libnes-debuginfo-1.1.3-1.x86_64
libnes-devel-static-1.1.3-1.x86_64
libnih-1.0.1-7.el6.x86_64
libnl-1.1.4-1.el6_4.x86_64
libnotify-0.5.0-1.el6.x86_64
libogg-1.1.4-2.1.el6.x86_64
liboil-0.3.16-4.1.el6.x86_64
libpcap-1.0.0-6.20091201git117cb5.el6.x86_64
libpciaccess-0.13.1-2.el6.x86_64
libpng-1.2.49-1.el6_2.x86_64
libproxy-0.3.0-4.el6_3.x86_64
libproxy-bin-0.3.0-4.el6_3.x86_64
libproxy-python-0.3.0-4.el6_3.x86_64
librdmacm-1.0.17-0.git4b5c1aa.el6.x86_64
librdmacm-debuginfo-1.0.15-1.x86_64
librdmacm-devel-1.0.17-0.git4b5c1aa.el6.x86_64
librdmacm-utils-1.0.17-0.git4b5c1aa.el6.x86_64
libreport-2.0.9-15.el6.x86_64
libreport-cli-2.0.9-15.el6.x86_64
libreport-compat-2.0.9-15.el6.x86_64
libreport-plugin-kerneloops-2.0.9-15.el6.x86_64
libreport-plugin-logger-2.0.9-15.el6.x86_64
libreport-plugin-mailx-2.0.9-15.el6.x86_64
libreport-plugin-reportuploader-2.0.9-15.el6.x86_64
libreport-plugin-rhtsupport-2.0.9-15.el6.x86_64
libreport-python-2.0.9-15.el6.x86_64
libsdp-1.1.108-0.17.ga6958ef.x86_64
libsdp-debuginfo-1.1.108-0.17.ga6958ef.x86_64
libsdp-devel-1.1.108-0.17.ga6958ef.x86_64
libselinux-2.0.94-5.3.el6_4.1.x86_64
libselinux-utils-2.0.94-5.3.el6_4.1.x86_64
libsemanage-2.0.43-4.2.el6.x86_64
libsepol-2.0.41-4.el6.x86_64
libSM-1.2.1-2.el6.x86_64
libsndfile-1.0.20-5.el6.x86_64
libss-1.41.12-14.el6_4.2.x86_64
libssh2-1.4.2-1.el6.x86_64
libstdc++-4.4.7-3.el6.i686
libstdc++-4.4.7-3.el6.x86_64
libstdc++-devel-4.4.7-3.el6.i686
libstdc++-devel-4.4.7-3.el6.x86_64
libsysfs-2.1.0-7.el6.x86_64
libtar-1.2.11-17.el6.x86_64
libtasn1-2.3-3.el6_2.1.x86_64
libtdb-1.2.10-1.el6.x86_64
libthai-0.1.12-3.el6.x86_64
libtheora-1.1.0-2.el6.x86_64
libtiff-3.9.4-9.el6_3.x86_64
libtirpc-0.2.1-6.el6_4.x86_64
libtool-2.2.6-15.5.el6.x86_64
libtool-ltdl-2.2.6-15.5.el6.x86_64
libudev-147-2.46.el6.x86_64
libusb-0.1.12-23.el6.x86_64
libusb1-1.0.9-0.6.rc1.el6.x86_64
libuser-0.56.13-5.el6.x86_64
libutempter-1.1.5-4.1.el6.x86_64
libuuid-2.17.2-12.9.el6_4.3.x86_64
libvisual-0.4.0-9.1.el6.x86_64
libvorbis-1.2.3-4.el6_2.1.x86_64
libwnck-2.28.0-3.el6.x86_64
libX11-1.5.0-4.el6.x86_64
libX11-common-1.5.0-4.el6.noarch
libXau-1.0.6-4.el6.x86_64
libXaw-1.0.11-2.el6.x86_64
libxcb-1.8.1-1.el6.x86_64
libXcomposite-0.4.3-4.el6.x86_64
libXcursor-1.1.13-2.el6.x86_64
libXdamage-1.1.3-4.el6.x86_64
libXext-1.3.1-2.el6.x86_64
libXfixes-5.0-3.el6.x86_64
libXfont-1.4.5-2.el6.x86_64
libXft-2.3.1-2.el6.x86_64
libXi-1.6.1-3.el6.x86_64
libXinerama-1.1.2-2.el6.x86_64
libxml2-2.7.6-12.el6_4.1.x86_64
libxml2-python-2.7.6-12.el6_4.1.x86_64
libXmu-1.1.1-2.el6.x86_64
libXp-1.0.0-15.1.el6.x86_64
libXpm-3.5.10-2.el6.x86_64
libXrandr-1.4.0-1.el6.x86_64
libXrender-0.9.7-2.el6.x86_64
libXres-1.0.6-2.el6.x86_64
libxslt-1.1.26-2.el6_3.1.x86_64
libXt-1.1.3-1.el6.x86_64
libXtst-1.2.1-2.el6.x86_64
libXv-1.0.7-2.el6.x86_64
libXxf86vm-1.1.2-2.el6.x86_64
lm_sensors-libs-3.1.1-17.el6.x86_64
log4j-1.2.14-6.4.el6.x86_64
logrotate-3.7.8-16.el6.x86_64
lsof-4.82-4.el6.x86_64
lua-5.1.4-4.1.el6.x86_64
lucene-2.3.1-5.9.el6.noarch
lucene-contrib-2.3.1-5.9.el6.noarch
lvm2-2.02.98-9.el6.x86_64
lvm2-libs-2.02.98-9.el6.x86_64
m2crypto-0.20.2-9.el6.x86_64
m4-1.4.13-5.el6.x86_64
mailx-12.4-6.el6.x86_64
make-3.81-20.el6.x86_64
MAKEDEV-3.24-6.el6.x86_64
man-1.6f-32.el6.x86_64
man-pages-3.22-20.el6.noarch
man-pages-overrides-6.4.1-1.el6.noarch
mdadm-3.2.5-4.el6_4.1.x86_64
mesa-dri1-drivers-7.11-8.el6.x86_64
mesa-dri-drivers-9.0-0.8.el6_4.3.x86_64
mesa-dri-filesystem-9.0-0.8.el6_4.3.x86_64
mesa-libGL-9.0-0.8.el6_4.3.x86_64
mesa-libGLU-9.0-0.8.el6_4.3.x86_64
microcode_ctl-1.17-14.el6.x86_64
mingetty-1.08-5.el6.x86_64
mlocate-0.22.2-4.el6.x86_64
module-init-tools-3.9-21.el6_4.x86_64
mozilla-filesystem-1.9-5.1.el6.x86_64
mpfr-2.4.1-6.el6.x86_64
mpi-selector-1.0.3-1.x86_64
mpitests_mvapich2_gcc-3.2-923.x86_64
mpitests_mvapich_gcc-3.2-923.x86_64
mpitests_openmpi_gcc-3.2-923.x86_64
mpss-ganglia-web-3.1-0.1.build0.glibc2.12.2.x86_64
mpss-ganglia-web-dev-3.1-0.1.build0.glibc2.12.2.x86_64
mpss-modules-headers-3.1-0.1.build0.glibc2.12.2.x86_64
mstflint-1.4-6.el6.x86_64
mtr-0.75-5.el6.x86_64
mvapich2_gcc-1.7-6.2012svn5140.x86_64
mvapich_gcc-1.2.0-3635.x86_64
mx4j-3.0.1-9.13.el6.noarch
mysql-libs-5.1.69-1.el6_4.x86_64
nano-2.0.9-7.el6.x86_64
ncurses-5.7-3.20090208.el6.x86_64
ncurses-base-5.7-3.20090208.el6.x86_64
ncurses-libs-5.7-3.20090208.el6.x86_64
net-snmp-5.5-44.el6_4.4.x86_64
net-snmp-libs-5.5-44.el6_4.4.x86_64
net-tools-1.60-110.el6_2.x86_64
netxen-firmware-4.0.534-3.1.el6.noarch
newt-0.52.11-3.el6.x86_64
newt-python-0.52.11-3.el6.x86_64
nfs-utils-1.2.3-36.el6.x86_64
nfs-utils-lib-1.1.5-6.el6.x86_64
notification-daemon-0.5.0-1.el6.x86_64
nspr-4.9.5-2.el6_4.x86_64
nss-3.14.3-4.el6_4.x86_64
nss-softokn-3.14.3-3.el6_4.x86_64
nss-softokn-freebl-3.14.3-3.el6_4.i686
nss-softokn-freebl-3.14.3-3.el6_4.x86_64
nss-sysinit-3.14.3-4.el6_4.x86_64
nss-tools-3.14.3-4.el6_4.x86_64
nss-util-3.14.3-3.el6_4.x86_64
ntp-4.2.4p8-3.el6.x86_64
ntpdate-4.2.4p8-3.el6.x86_64
ntsysv-1.3.49.3-2.el6.x86_64
numactl-2.0.7-6.el6.x86_64
objectweb-asm-3.2-2.1.el6.noarch
ofed-docs-1.5.4.1-OFED.1.5.4.1.x86_64
ofed-scripts-1.5.4.1-OFED.1.5.4.1.x86_64
openjpeg-libs-1.3-9.el6_3.x86_64
openldap-2.4.23-32.el6_4.1.x86_64
openmpi_gcc-1.4.3-1.x86_64
opensm-3.3.13-1.x86_64
opensm-debuginfo-3.3.13-1.x86_64
opensm-devel-3.3.13-1.x86_64
opensm-libs-3.3.13-1.x86_64
opensm-static-3.3.13-1.x86_64
openssh-5.3p1-84.1.el6.x86_64
openssh-clients-5.3p1-84.1.el6.x86_64
openssh-server-5.3p1-84.1.el6.x86_64
openssl-1.0.0-27.el6_4.2.x86_64
ORBit2-2.14.17-3.2.el6_3.x86_64
PackageKit-0.5.8-21.el6.x86_64
PackageKit-glib-0.5.8-21.el6.x86_64
PackageKit-gtk-module-0.5.8-21.el6.x86_64
PackageKit-yum-0.5.8-21.el6.x86_64
PackageKit-yum-plugin-0.5.8-21.el6.x86_64
pam-1.1.1-13.el6.x86_64
pam_passwdqc-1.0.5-6.el6.x86_64
pango-1.28.1-7.el6_3.x86_64
parted-2.1-19.el6.x86_64
passwd-0.77-4.el6_2.2.x86_64
patch-2.6-6.el6.x86_64
pax-3.4-10.1.el6.x86_64
pciutils-3.1.10-2.el6.x86_64
pciutils-libs-3.1.10-2.el6.x86_64
pcmciautils-015-4.2.el6.x86_64
pcre-7.8-6.el6.x86_64
perftest-1.3.0-2.el6.x86_64
perl-5.10.1-131.el6_4.x86_64
perl-CGI-3.51-131.el6_4.x86_64
perl-devel-5.10.1-131.el6_4.x86_64
perl-ExtUtils-MakeMaker-6.55-131.el6_4.x86_64
perl-ExtUtils-ParseXS-2.2003.0-131.el6_4.x86_64
perl-libs-5.10.1-131.el6_4.x86_64
perl-Module-Pluggable-3.90-131.el6_4.x86_64
perl-Pod-Escapes-1.04-131.el6_4.x86_64
perl-Pod-Simple-3.13-131.el6_4.x86_64
perl-Test-Harness-3.17-131.el6_4.x86_64
perl-Test-Simple-0.92-131.el6_4.x86_64
perl-version-0.77-131.el6_4.x86_64
phonon-backend-gstreamer-4.6.2-26.el6_4.x86_64
pinentry-0.7.6-6.el6.x86_64
pinfo-0.6.9-12.el6.x86_64
pixman-0.26.2-5.el6_4.x86_64
pkgconfig-0.23-9.1.el6.x86_64
plymouth-0.8.3-27.el6.x86_64
plymouth-core-libs-0.8.3-27.el6.x86_64
plymouth-scripts-0.8.3-27.el6.x86_64
pm-utils-1.2.5-10.el6.x86_64
policycoreutils-2.0.83-19.30.el6.x86_64
polkit-0.96-2.el6_0.1.x86_64
poppler-0.12.4-3.el6_0.1.x86_64
poppler-data-0.4.0-1.el6.noarch
poppler-utils-0.12.4-3.el6_0.1.x86_64
popt-1.13-7.el6.x86_64
portreserve-0.0.4-9.el6.x86_64
postfix-2.6.6-2.2.el6_1.x86_64
ppl-0.10.2-11.el6.x86_64
prelink-0.4.6-3.el6.x86_64
procps-3.2.8-25.el6.x86_64
psacct-6.3.2-63.el6_3.3.x86_64
psmisc-22.6-15.el6_0.1.x86_64
pth-2.0.7-9.3.el6.x86_64
pulseaudio-libs-0.9.21-14.el6_3.x86_64
pycairo-1.8.6-2.1.el6.x86_64
pygobject2-2.20.0-5.el6.x86_64
pygpgme-0.1-18.20090824bzr68.el6.x86_64
pygtk2-2.16.0-3.el6.x86_64
pygtksourceview-2.8.0-1.el6.x86_64
pyOpenSSL-0.10-2.el6.x86_64
python-2.6.6-37.el6_4.x86_64
python-dateutil-1.4.1-6.el6.noarch
python-dmidecode-3.10.13-3.el6_4.x86_64
python-ethtool-0.6-3.el6.x86_64
python-gudev-147.1-4.el6_0.1.x86_64
python-iniparse-0.3.1-2.1.el6.noarch
python-iwlib-0.1-1.2.el6.x86_64
python-libs-2.6.6-37.el6_4.x86_64
python-pycurl-7.19.0-8.el6.x86_64
python-rhsm-1.1.8-1.el6.x86_64
python-simplejson-2.0.9-3.1.el6.x86_64
python-urlgrabber-3.9.1-8.el6.noarch
PyXML-0.8.4-19.el6.x86_64
qdox-1.9.2-2.el6.noarch
ql2100-firmware-1.19.38-3.1.el6.noarch
ql2200-firmware-2.02.08-3.1.el6.noarch
ql23xx-firmware-3.03.27-3.1.el6.noarch
ql2400-firmware-5.08.00-1.el6.noarch
ql2500-firmware-5.08.00-1.el6.noarch
qperf-0.4.6-6.el6.x86_64
qperf-debuginfo-0.4.6-0.1.gb81434e.x86_64
qt3-3.3.8b-30.el6.x86_64
qt-4.6.2-26.el6_4.x86_64
qt-sqlite-4.6.2-26.el6_4.x86_64
qt-x11-4.6.2-26.el6_4.x86_64
quota-3.17-18.el6.x86_64
rarian-0.8.1-5.1.el6.x86_64
rarian-compat-0.8.1-5.1.el6.x86_64
rdate-1.4-16.el6.x86_64
rds-devel-2.0.4-1.x86_64
rds-tools-2.0.6-3.el6.x86_64
readahead-1.5.6-1.el6.x86_64
readline-6.0-4.el6.x86_64
redhat-bookmarks-6-1.el6.noarch
Red_Hat_Enterprise_Linux-Release_Notes-6-en-US-4-2.el6.noarch
redhat-indexhtml-6-1.el6.noarch
redhat-logos-60.0.14-1.el6.noarch
redhat-lsb-4.0-7.el6.x86_64
redhat-lsb-compat-4.0-7.el6.x86_64
redhat-lsb-core-4.0-7.el6.x86_64
redhat-lsb-graphics-4.0-7.el6.x86_64
redhat-lsb-printing-4.0-7.el6.x86_64
redhat-menus-14.0.0-3.el6.noarch
redhat-release-server-6Server-6.4.0.4.el6.x86_64
redhat-rpm-config-9.0.3-42.el6.noarch
regexp-1.5-4.4.el6.x86_64
rfkill-0.3-4.el6.x86_64
rhino-1.7-0.7.r2.2.el6.noarch
rhn-check-1.0.0.1-4.el6.noarch
rhn-client-tools-1.0.0.1-4.el6.noarch
rhnlib-2.5.22-12.el6.noarch
rhnsd-4.9.3-2.el6.x86_64
rhn-setup-1.0.0.1-4.el6.noarch
rng-tools-2-13.el6_2.x86_64
rootfiles-8.1-6.1.el6.noarch
rpcbind-0.2.0-11.el6.x86_64
rpm-4.8.0-32.el6.x86_64
rpm-build-4.8.0-32.el6.x86_64
rpm-libs-4.8.0-32.el6.x86_64
rpm-python-4.8.0-32.el6.x86_64
rrdtool-1.3.8-6.el6.x86_64
rrdtool-devel-1.3.8-6.el6.x86_64
rsync-3.0.6-9.el6.x86_64
rsyslog-5.8.10-6.el6.x86_64
rt61pci-firmware-1.2-7.el6.noarch
rt73usb-firmware-1.8-7.el6.noarch
sat4j-2.2.0-4.0.el6.noarch
sdpnetstat-1.60-0.3.gb6e7425.x86_64
sed-4.2.1-10.el6.x86_64
selinux-policy-3.7.19-195.el6_4.12.noarch
selinux-policy-targeted-3.7.19-195.el6_4.12.noarch
setserial-2.17-25.el6.x86_64
setup-2.8.14-20.el6.noarch
setuptool-1.19.9-3.el6.x86_64
sgml-common-0.6.3-32.el6.noarch
sgpio-1.2.0.10-5.el6.x86_64
shadow-utils-4.1.4.2-13.el6.x86_64
shared-mime-info-0.70-4.el6.x86_64
sinjdoc-0.5-9.1.el6.x86_64
slang-2.2.1-1.el6.x86_64
slf4j-1.5.8-8.el6.noarch
smartmontools-5.43-1.el6.x86_64
sos-2.2-38.el6.noarch
sound-theme-freedesktop-0.7-3.el6.noarch
sqlite-3.6.20-1.el6.x86_64
srptools-0.0.4-15.el6.x86_64
startup-notification-0.10-2.1.el6.x86_64
strace-4.5.19-1.17.el6.x86_64
subscription-manager-1.1.23.1-1.el6_4.x86_64
sudo-1.8.6p3-7.el6.x86_64
swig-1.3.40-6.el6.x86_64
sysstat-9.0.4-20.el6.x86_64
system-config-firewall-base-1.2.27-5.el6.noarch
system-config-firewall-tui-1.2.27-5.el6.noarch
system-config-network-tui-1.6.0.el6.2-1.el6.noarch
system-gnome-theme-60.0.2-1.el6.noarch
system-icon-theme-6.0.0-2.el6.noarch
systemtap-1.8-7.el6.x86_64
systemtap-client-1.8-7.el6.x86_64
systemtap-devel-1.8-7.el6.x86_64
systemtap-runtime-1.8-7.el6.x86_64
sysvinit-tools-2.87-4.dsf.el6.x86_64
tar-1.23-11.el6.x86_64
tcl-8.5.7-6.el6.x86_64
tcl-devel-8.5.7-6.el6.x86_64
tcpdump-4.0.0-3.20090921gitdf3cb4.2.el6.x86_64
tcp_wrappers-7.6-57.el6.x86_64
tcp_wrappers-libs-7.6-57.el6.x86_64
tcsh-6.17-24.el6.x86_64
time-1.7-37.1.el6.x86_64
tk-8.5.7-5.el6.x86_64
tmpwatch-2.9.16-4.el6.x86_64
traceroute-2.0.14-2.el6.x86_64
tzdata-2013c-2.el6.noarch
tzdata-java-2013c-2.el6.noarch
unzip-6.0-1.el6.x86_64
upstart-0.6.5-12.el6_4.1.x86_64
urw-fonts-2.4-10.el6.noarch
usbutils-003-4.el6.x86_64
usermode-1.102-3.el6.x86_64
ustr-1.0.4-9.1.el6.x86_64
util-linux-ng-2.17.2-12.9.el6_4.3.x86_64
vconfig-1.9-8.1.el6.x86_64
vim-common-7.2.411-1.8.el6.x86_64
vim-enhanced-7.2.411-1.8.el6.x86_64
vim-minimal-7.2.411-1.8.el6.x86_64
virt-what-1.11-1.2.el6.x86_64
wget-1.12-1.8.el6.x86_64
which-2.19-6.el6.x86_64
wireless-tools-29-5.1.1.el6.x86_64
words-3.0-17.el6.noarch
ws-commons-util-1.0.1-13.el6.noarch
wsdl4j-1.5.2-7.8.el6.noarch
ws-jaxme-0.5.1-4.6.el6.noarch
xalan-j2-2.7.0-9.8.el6.noarch
xcb-util-0.3.6-1.el6.x86_64
xdg-utils-1.0.2-17.20091016cvs.el6.noarch
xerces-j2-2.7.1-12.6.el6_0.x86_64
xml-common-0.6.3-32.el6.noarch
xml-commons-apis-1.3.04-3.6.el6.x86_64
xml-commons-resolver-1.1-4.18.el6.x86_64
xmldb-api-0.1-0.4.20011111cvs.1.5.el6.noarch
xmldb-api-sdk-0.1-0.4.20011111cvs.1.5.el6.noarch
xmlrpc3-client-3.0-4.15.el6.noarch
xmlrpc3-common-3.0-4.15.el6.noarch
xmlrpc-c-1.16.24-1209.1840.el6.x86_64
xmlrpc-c-client-1.16.24-1209.1840.el6.x86_64
xorg-x11-drv-ati-firmware-6.99.99-1.el6.noarch
xorg-x11-font-utils-7.2-11.el6.x86_64
xorg-x11-xauth-1.0.2-7.1.el6.x86_64
xulrunner-17.0.8-3.el6_4.x86_64
xz-4.999.9-0.3.beta.20091007git.el6.x86_64
xz-libs-4.999.9-0.3.beta.20091007git.el6.x86_64
xz-lzma-compat-4.999.9-0.3.beta.20091007git.el6.x86_64
yum-3.2.29-40.el6.noarch
yum-metadata-parser-1.1.2-16.el6.x86_64
yum-rhn-plugin-0.9.1-43.el6.noarch
yum-utils-1.1.30-14.el6.noarch
zd1211-firmware-1.4-4.el6.noarch
zenity-2.28.0-1.el6.x86_64
zip-3.0-1.el6.x86_64
zlib-1.2.3-29.el6.x86_64
zlib-devel-1.2.3-29.el6.x86_64
Frances_R_Intel
Is the line "uninstalled mpss3.0 via:  rpm -qa | grep intel-mic | awk '{system("rpm -e --nodeps "$1)}'" a note about what you did? If so, were you actually running MPSS 3.0? A lot of rpm file names were changed with the MPSS 3.* releases and grepping for intel-mic doesn't work. There is an uninstall script to use for MPSS 3.0 and beyond.
Also is the line "package mpss-coi, required for mpss-coi-dev, does not exist in the download" also a note about what you saw and not the output from some command? If so, there really should be a file called mpss-coi-3.1-0.1.build0.glibc2.12.2.x86_64.rpm in the release tar file.
So, could you 1) untar the release package again to see if mpss-coi-3.1-0.1.build0.glibc2.12.2.x86_64.rpm is there and 2) confirm that the previous release of the MPSS did uninstall correctly (either using "sudo yum remove --noplugins --disablerepo=* intel-mic\*" for pre-3.0 releases or the uninstall script for 3.0 and later releases)?  Thanks.
shane_k_
appears my issue was due to a corrupt download which was missing among other things the uninstall script
