Software Archive
Read-only legacy content
17060 Discussions
undefined reference to std::sort() in offload on mic
baoyun_p_
I want to execute std::sort() in offload method on MIC, the code as following:
#include <stdlib.h>
#include <algorithm>
#define data_num 100000
#pragma offload_attribute(push,target(mic))
struct T{
	float fea;
	int pos;
bool myGreater(T i, T j){
	return i.fea > j.fea;
T *data;
#pragma offload_attribute(pop)
void main(){
	#pragma offload target(mic:0) in(data:length(data_num) alloc_if(1))
                data = (T*) malloc(sizeof(T) * data_num);
		std::sort(data, data+data_num, myGreater);
 I use icc compiler to compile, and it give the error informantion: "undefined reference to std::sort<T*, bool(*)>..." , but when I remove the all "#pragma...", it can  go through compile.
I guess that the std::sort algorithm cannot be used in MIC,
Kevin_D_Intel
Encapsulate at least <algorithm> within an offload_attribute push/pop. i.e.
#pragma offload_attribute(push, target(mic))
Kevin_D_Intel
