Software Archive
Read-only legacy content
17060 Discussions
use Intel(R) Xeon(R) CPU E5-2680 v3 as coproceesor in windows remotely
sumit_p_
Intel(R) Xeon(R) CPU E5-2680 v3 with red hat 4.8
I want use this system as coprocessor in windows (visual studio 2012) (is is possible ?). This system is located in other place in same network. I can access it through putty. I installed MPSS 3.6.1 and Intel composer XE 2013 sp1. When i run  micctrl --addssh <username> <public-key> this command , it gives error :
 Error manipulating coprocessors: Intel(R) Xeon Phi(TM) coprocessor driver is not  loaded or you have insufficient access.
chris_b_6
hello windows compatibility pack is what you need.
