Software Archive
Read-only legacy content
17060 Discussions
using opengl wi the f90gl libraries
Intel_C_Intel
I have developed a structural analysis program and now i want to add some features like 3d modeling to see the deflections of the structure and diagrams, etc.
to do this i decided to use glut so i downloaded the f90gl source and binaries, and to try it out i added a subroutine to a program i already have and it worked fine but when i try to use the same code in my structural analysis program it gives me the following:
Linking...
dfor.lib(for_m_qqs.obj) : error LNK2001: unresolved external symbol _errno
dfor.lib(for_portlib.obj) : error LNK2001: unresolved external symbol _errno
Debug/RIGIDEZ.exe : fatal error LNK1120: 1 unresolved externals
Error executing link.exe.
RIGIDEZ.exe - 3 error(s), 5 warning(s)
The warnings are about variables not used.
Also I added the switch /nodefaultlib:"libc.lib" for the link since i believe it conflicts with libcmt.lib (?)
i hope someone can help me find a solution
thanks,
Len
Do not use /nodefaultlib - it is almost always the wrong remedy for Multiple C Library Syndrome". If you have references to both libc and libcmt, then you will need to rebuild everything using a consistent setting for whether or not the multithread libraries are being used.
Taking a quick look, I think that the precompiled f90GL libraries we provide as a courtesy are built with the non-threaded libraries. Do you have something being built threaded?
Steve
Intel_C_Intel
thanks Steve,
i've been looking into my project settings and on the category "Code Generation" under the C/C++ tab the run-time library is set as "Single Threaded".
Also under the Fortran tab the "Use Multi-threaded Libraries" is unchecked
So i don't think i've built anything threaded.
I will take out he "/nodefaultlib" switch and try to set my project multi-threaded to see if this works also you think it would be good to build the f90gl libraries multi-threaded?
Well, i'll try it out and read about threads on the help. I'll post the results later.
Thanks, if you can give me any further advised i would appreciate it!
Len
Intel_C_Intel
it worked!
now i built everything with multi-threaded libraries and it linked it ok, no errors.
thanks
