Software Archive
Read-only legacy content
17060 Discussões
vectorization of nested loops.
conor_p_
Principiante
7.792 Visualizações
Hey everyone, I have the following set of nested loops which I would like to vectorize. If you're familiar with molecular simulations, this is a linked cell energy calculation. I checked the requirements for intel vectorization, and I believe I satisfy them. There aren't multiple branch points. All array accessing, except for envar in the inner most loop, is unit stride. I believe the if statements in these loops can be interpreted as mask-constructs. I keep getting the error 'loop not vectorized: not inner loop," hence the addition of the !dir$ imp simd collapse(4). When i compile with -vec-report2  -guide -openmp the compiler still says "loop not vectorized: not inner loop," despite the collapse command. I would like to port this to the xeon phi coprocessor, so any help with the vectorization here would be greatly appreciated. I understand this is a fair amount of code, but i have tried to add many comments for explanation.
 !$omp parallel do schedule(dynamic) reduction(+:energy) default(private) firstprivate(listvar), &
    !$omp& shared(r,tr,cv,param,envar,alpha,GaussChar,pf)
    !dir$ omp simd collapse(4)
    !dir$ vector aligned
    !--- loop over all cells present
    do i = 0,listvar%ncellT-1
       !--- these are pointers to array r which contains the positions of particles along with the particle type.
       !--- c1s is the location in r where the first atom in cell i is stored. c1e is where the last atom is stored
       c1s   = tr(i)%start
       c1e   = tr(i)%end
       !--- loop over cell neighbors
       do k=1,26
          !---determine this cell
          cell_neigh = cv(k,i)%cnum
          !--- only calculate energy between particle 1 and particle 2 once.
          !---This is done by only calculating energies between cell pairs (i,cell_neigh) where cell_neigh is gt than i
          if(cell_neigh.gt.i)then
             !---minimum image criterion for distance calculation
             minx =cv(k,i)%min_x
             miny =cv(k,i)%min_y
             minz =cv(k,i)%min_z
             !---pointers to positions in array r. Tell where the atoms for cell cell_neigh are contained in r
             c2s = tr(cell_neigh)%start
             c2e = tr(cell_neigh)%end
             !--- loop over particles in each cell
             do j = c1s,c1e
                x1 = r(j)%x
                y1 = r(j)%y
                z1 = r(j)%z
                type1 = r(j)%type
                do l= c2s,c2e
                   x2 = r(l)%x
                   y2 = r(l)%y
                   z2 = r(l)%z
                   type2 = r(l)%type
                   !--- obtain displacements
                   !--- apply minimum image here
                   dx = x2-x1-minx
                   dy = y2-y1-miny
                   dz = z2-z1-minz
                   dr2 = dx*dx+dy*dy+dz*dz
                   !--- is distance is less than cutoff, calculate energy
                   if(dr2.lt.param%rcut2)then
                      !--- obtain interaction parameters for atoms of type1 and type2
                      val(:)= envar(type1,type2)%val(:)
                      dr    = sqrt(dr2)
                      dri   = 1.0d0/dr
                      dr2i  = val(1)/dr2
                      dr6i  = dr2i*dr2i*dr2i
                      dr12i = dr6i*dr6i
                      !--- lennard jones energy
                      energy = energy + 4.0d0*val(2)*(dr12i - dr6i)
                      !--- electrostatic energy
                      !energy = energy + pf*charge*(erfc(alpha*dr)-GaussChar)
                   endif
                enddo
             enddo
          endif
       enddo
    enddo
    !$omp end parallel do
26 Respostas
conor_p_
Principiante
6.459 Visualizações
Sorry for all the spaces, I can't seem to figure out how to go back and edit my post to delete them.
TimP
Colaborador honorário III
6.459 Visualizações
If the inner loop isn't vectorizable, it seems unlikely that forcing collapse could improve the situation (if the situation is remotely eligible for collapse, which doesn't appear to be your case).
Where you have an outer loop which is vectorizable, while inner ones aren't, you can encourage the compiler to vectorize it by placing !$omp simd on that loop.  If the loop is to be both parallel and simd, that's !$omp parallel do simd.  You can't use alignment assertions in such a loop unless you can assure that the loop count is an integral multiple of vector width times number of threads.
conor_p_
Principiante
6.459 Visualizações
Can you tell me how to specifically do that? All the examples I find are in c++. When I type
!$omp parallel do simd schedule(dynamic) reduction(+:energy) default(private) firstprivate(listvar),&
It tells me this is a syntax error with the simd, Also, I don't know if I completely followed you when you said the loop is to be parallel and simd. I would like to code to vectorize, since I would like to put in on a MIC (hence SIMD). To put in on the MIC, it needs to be parallelized. Is that what you mean by both parallel and simd?
conor_p_
Principiante
6.459 Visualizações
Never mind. For some reason the SIMD instruction doesn't work on my desktop, but it works fine on the supercomputer I am running the code on. However, the compiler is now throwing the following error: 'The openmp simd directives require perfectly nested loops: no code may appear before or after the loops being collapsed." I have commented out everything in the subroutine except the code I posted here. What code is it referring to that prevents the vectorization?
TimP
6.459 Visualizações
If you are still trying collapse in the manner you suggested above, the complaint is expected, as you have code between the levels of DO loop.
I haven't seen rules documented for parallel do simd outer loops, assuming you remove the collapse.  The compiler may require similar rules to collapse even though you don't specify collapse.
conor_p_
Principiante
6.459 Visualizações
Ok, can you tell me when I would want to collapse a loop? I feel like I do not want to collapse my loop here. If I move all the code to the innermost loops, it will require the code to go access the same array element more than once. With the collapse command present and my code arranged to what is shown below, I still get the following. I might be in over my head here.
loop was not vectorized: unsupported loop structure. This line given was the line with OMP directive
loop was not vectorized: existence of vector dependence. this refers to inner loop with index L
loop was not vectorized: not inner loop. This refers to loop with index j
loop was not vectorized: not inner loop . This refers to loop with index k
loop was not vectorized: top test could not be found. This refer to line with outer loop with index i
 !$omp parallel do simd collapse(1) schedule(dynamic) reduction(+:energy) default(private) firstprivate(listvar), &
    do i = 0,ncellT
       do k=1,26
          c1s   = tr(i)%start
          c1e   = tr(i)%end
             !---minimum image
             minx =cv(k,i)%min_x
             miny =cv(k,i)%min_y
             minz =cv(k,i)%min_z
             do j = c1s,c1e
                x1 = r(j)%x
                y1 = r(j)%y
                z1 = r(j)%z
                type1 = r(j)%type
                do l= c2s,c2e
                   x2 = r(l)%x
                   y2 = r(l)%y
                   z2 = r(l)%z
                   type2 = r(l)%type
                   dx = x2-x1-minx
                   dy = y2-y1-miny
                   dz = z2-z1-minz
                      dr    = sqrt(dr2)
                      dri   = 1.0d0/dr
                      dr2i  = val(1)/dr2
                      dr12i = dr6i*dr6i
                   endif
                enddo
             enddo
          endif
       enddo
    enddo
    !$omp end parallel do simd
TimP
6.459 Visualizações
If collapse(2) worked, it could help by increasing parallel chunk size, in case ncellT were not large (e.g. 2000 or so for MIC).  If outer loop vectorization were successful, proportionately larger chunks would be useful.
With the large conditional block inside, it may be difficult for the compiler to accomplish vectorization.  If the conditionals are what is preventing vectorization (rather than sequential dependencies in inner loops), collapse or application of simd on outer loop aren't so likely to be useful.
If you are able to accomplish vectorized sum reduction in the inner loop, it could be helpful to have separately named inner loop sums which in turn are summed in the parallel reduction variable in the outer loop.
conor_p_
Principiante
6.459 Visualizações
So to check if it was the if statement that was giving me an issue, I commented them out and ran vec report. The same same errors were obtained, so I don't believe it is the if statements.
conor_p_
Principiante
6.459 Visualizações
Do you think I may benefit from moving the OMP parallel region to the inner two loops? Ideally I would like to run this whole code on the MICs. I could run the outer two loops serially on the MIC, and the inner two loops in parallel on the MIC. I am concerned about the computational load here. If I were to parallelize the inner two loops, I don't think either loop is greater than the number of threads.
jimdempseyatthecove
6.459 Visualizações
"parallel outer-vector inner"
At issue here is your data layout is AOS, which does not lend itself to vectorization.
What you would want to do is change to SOA layout.
You currently have an array of particles that constitute your collection of particles.
What you should do is organize your data  such that you have a:
Collection of particles with arrays of same attribute/dimension.
This way you can manipulate the collection en mass
Change data layout from:
do j = c1s,c1e
  x1 = r(j)%x
  y1 = r(j)%y
  z1 = r(j)%z
  type1 = r(j)%type
  do l= c2s,c2e
    x2 = r(l)%x
    y2 = r(l)%y
    z2 = r(l)%z
    type2 = r(l)%type
to:
do j = c1s,c1e
  x1 = r%x(j)
  y1 = r%y(j)
  z1 = r%z(j)
  type1 = r%type(j)
  do i= c2s,c2e
    x2 = r%x(i)
    y2 = r%y(i)
    z2 = r%z(i)
    type2 = r%type(i)
If thine eye offends thee, then add import/export functions to/from the collection that uses a particle object.
Jim Dempsey
conor_p_
Principiante
6.459 Visualizações
Thank you very much for your response! I have written a short snippet version of the code I posted to investigate the differences in speed between AoS SoA and just arrays. However, I can't get that to vectorize. Should I post a new thread since the code is different, or is that ok for me to post here?
jimdempseyatthecove
6.459 Visualizações
Post it here since it involves your problem, and hopefully your solution.
Jim Dempsey
conor_p_
Principiante
6.459 Visualizações
Ok, so I took your advice and changed the data layout. I switched both to conventional arrays and a structure or arrays layout. I wrote the following code to analyze what's going on. The inner two loops, when written on there on, vectorize as "permuted loop was vectorized." However both fail to vectorize when nested as the inner two loops. The output of -vec-report2 -guide is shown below the code. Since this doesn't seem to be a data layout issue now, do I possibly have some kind of flow dependence issues with c1s,c1e,c2s,c2e?
program vec
  use ifport
  implicit none
  type r
     double precision :: x(60000),y(60000),z(60000)
  end type r
  type(r) :: part
  !--- convention array
  double precision :: rnew(3,60000)
  integer :: start(1000), end(1000)
  !--- various variables
  double precision :: energy
  double precision :: x1,y1,z1,x2,y2,z2,dr2
  integer :: i,j,k,l,count
  integer :: c1s,c1e,c2s,c2e
  call srand(10)
  !--- dont care about this. this is just initializing random positions
  do i = 1,60000
     rnew(1,i) = 10*rand(); rnew(2,i) = 10*rand(); rnew(3,i) = 10*rand()
     part%x(i) = rnew(1,i); part%y(i) = rnew(2,i); part%z(i) = rnew(3,i)
  end do
  !--- dont car about this either. just assigning pointers to rnew and part
  count = 0
  do i = 1,1000
     start(i) = count*60+1
     end(i)   = (count+1)*60
     count = count + 1
  enddo
  energy =0.0d0
 !---main code I would like to port to MIC
  do i= 1,1000
     do j = 1,1000
        c1s = start(i)
        c1e = end(i)
        if(j.gt.i) then
           c2s = start(j)
           c2e = end(j)
           do l=c2s,c2e
              do k = c1s,c1e
                 x1 = rnew(1,k); y1 = rnew(2,k); z1 = rnew(3,k)
                 x2 = rnew(1,l); y1 = rnew(2,l); z2 = rnew(3,l)
                 dr2 = (x2-x1)**2+(y2-y1)**2+(z2-z1)**2
                 if(dr2.lt.2)then
                    energy = energy + 1
                 endif
              enddo
           enddo
	endif
     enddo
  enddo
 !---main code I would like to port to MIC in array of structure format
  do i= 1,1000
     do j = 1,1000
        c1s = start(i)
        c1e = end(i)
        if(j.gt.i) then
           c2s = start(j)
           c2e = end(j)
           do l=c2s,c2e
              do k = c1s,c1e
                 x1 = part%x(k); y1 = part%y(k); z1 = part%z(k)
                 x2 = part%x(l); y2 = part%y(l); z2 = part%z(l)
                 if(dr2.lt.2)then
                    energy = energy + 1
                 endif
              enddo
           enddo
	endif
     enddo
  enddo
  !--- analyze inner two loops
  c1s = start(i);c1e = end(i); c2s = start(j); c2e = end(j)
  do k=c1s,c1e
     do l = c2s,c2e
        if(dr2.lt.2)then
           energy = energy + 1
        endif
     enddo
  enddo
  do k=c1s,c1e
     do l = c2s,c2e
        x2 = part%x(l); y1 = part%y(l); z2 = part%z(l)
        if(dr2.lt.2)then
           energy = energy + 1
        endif
     enddo
  enddo
  stop
end program vec
compile: ifort -vec-report2 -guide vec.f90 -O3
vec.f90(50) (col.3) remark: loop was not vectorized: not inner loop.
vec.f90(52) (col.3) remark: loop was not vectorized: not inner loop.
vec.f90(61) (col.3) remark: loop was not vectorized: not inner loop.
vec.f90(83) (col.3) remark: LOOP WAS VECTORIZED
vec.f90(83) (col.3) remark: loop was not vectorized: not inner loop.
vec.f90(92) (col.3) remark: loop was not vectorized: not inner loop.
vec.f90(94) (col.3) remark: loop was not vectorized: not inner loop.
vec.f90(116) (col.3) remark:PERMUTED LOOP WAS VECTORIZED
vec.f90(133) (col.3) remark: loop was not vectorized: not inner loop.
vec.f90(132) (col.3) remark:PERMUTED LOOP WAS VECTORIZED
James_C_Intel2
Funcionário
6.459 Visualizações
It may make no difference, but in a couple of places you have something like this
  do i= 1,1000
     do j = 1,1000
        c1s = start(i)
        c1e = end(i)
        if(j.gt.i) then
          // Compute i, j interaction
        endif
    end do
  end do
Surely it'd be simpler to write it as
     do i= 1,1000
       do j = i+1,1000
        c1s = start(i)
        c1e = end(i)
         // Compute i,j interaction
    end do
  end do
Or, does that break the vectorization?
(I'm assuming that you're relying on the compiler to hoist the loop invariant loads of c1s,c1e out of the j loop, so I haven't done that)
conor_p_
Principiante
6.459 Visualizações
Sure. This is just my test code. My actual code is a little more complicated and requires the if statement. Hence, I am trying to see if I can even get the compiler to vectorize this simpler scenario.
conor_p_
Principiante
6.459 Visualizações
I think the following is interesting. In the above code, when I wrote the inner two loops by themselves I got the message permuted loop was vectorized. To see if I could get it to vectorize in a subroutine, and then call that subroutine, I added the subroutine below. However, now its telling me the inner loop cannot be vectorized due to a vector dependence, and that the outer loop cannot be vectorized: not inner loop. I can't figure out where I have a vector dependence, and why simd isn't overriding it.
subroutine cell_pair_kernel(i,j,energy,rnew,start,end)
  implicit none
  !dir$ simd collapse(2)
  do k=c1s,c1e
     do l = c2s,c2e
        x2 = rnew(1,l); y2 = rnew(2,l); z2 = rnew(3,l)
        if(dr2.lt.2)then
           energy = energy + 1
        endif
     enddo
  enddo
end subroutine cell_pair_kernel
jimdempseyatthecove
6.459 Visualizações
Using V-Tune (principally to see the vectorization) on Host We find
0x1400016b0     Block 44:   0.0%
0x1400016b0 97  lea r12, ptr [r14*8]                                  10.075ms  10.075ms 0.0% 0ms
0x1400016b8 95  add r14, 0x4                                           9.985ms  9.985ms  0.0% 0ms
0x1400016bc 97 lea r15, ptr [r12+rdx*8]                               50.080ms  50.080ms 0.0% 0ms
0x1400016c0 100 vsubpd ymm12, ymm8, ymmword ptr [rdi+r15*1+0x165a98]                     0.0%
0x1400016ca 100 vsubpd ymm14, ymm9, ymmword ptr [rdi+r15*1+0x1dad98]  10.001ms  10.001ms 0.0% 0ms
0x1400016d4 100 vsubpd ymm15, ymm13, ymmword ptr [rdi+r15*1+0x250098] 59.965ms  59.965ms 0.0% 0ms
0x1400016de 100 vmulpd ymm12, ymm12, ymm12                            30.014ms  30.014ms 0.0% 0ms
0x1400016e3 100 vmulpd ymm14, ymm14, ymm14                           120.036ms 120.036ms 0.0% 0ms
0x1400016e8 100 vmulpd ymm15, ymm15, ymm15                             0.0%
0x1400016ed 100 vaddpd ymm12, ymm12, ymm14                            10.018ms  10.018ms 0.0% 0ms
0x1400016f2 100 vaddpd ymm12, ymm12, ymm15                             9.999ms   9.999ms 0.0% 0ms
0x1400016f7 102 vcmppd ymm14, ymm12, ymm1, 0x1                       100.023ms 100.023ms 0.0% 0ms
0x1400016fc 103 vandpd ymm15, ymm0, ymm14                            119.941ms 119.941ms 0.0% 0ms
0x140001701 103 vaddpd ymm3, ymm15, ymm3                              60.015ms  60.015ms 0.0% 0ms
0x140001705 95  cmp r14, rax                                         289.851ms 289.851ms 0.0% 0ms
0x140001708 95  jb 0x1400016b0 <Block 44>                              0.0%
This illustrates complete vectorization of the inner loop beginning at line 94 of your SOA format.
I would expect the Xeon Phi code generation to be similar (though using wider vectors).
Jim Dempsey
TimP
6.459 Visualizações
Vectorization may happen more readily with
energy = energy + merge(1,0,dr2<2)
Your simd directive is incorrect. How about
!$omp simd reduction(+: energy) collapse(2)
or the !dir$ equivalent?
These directives are likely to generate wrong code if they optimize with incorrect specification clauses.
If the compiler sees an alias between the energy argument and the inputs (and you didn't set -assume dummy_aliases or the like) that appears to be an optimization bug, which you might work around by using a local scalar variable inside the loop.
jimdempseyatthecove
6.459 Visualizações
The code you chose for test is not quite the same as your actual code posted. Principally your particle structure was larger, thus making the strides for X, Y and Z further apart.
53      do j = 1,1000        0.0%
54        0.0%
55         c1s = start(i)                                                              0.0%
56         c1e = end(i)        0.0%
57         if(j.gt.i) then                                                             0.0%
58        0.0%
59            c2s = start(j)                                                           0.0%
60            c2e = end(j)                                                             0.0%
61        0.0%
62            do l=c2s,c2e                                          10.029ms  10.029ms 0.0% 0ms
63        0.0%
64               do k = c1s,c1e                                    400.218ms 400.218ms 0.0% 0ms
65        0.0%
66                  x1 = rnew(1,k); y1 = rnew(2,k); z1 = rnew(3,k) 376.782ms 376.782ms 0.0% 0ms
67                  x2 = rnew(1,l); y1 = rnew(2,l); z2 = rnew(3,l)                     0.0%
68        0.0%
69                  dr2 = (x2-x1)**2+(y2-y1)**2+(z2-z1)**2         195.448ms 195.448ms 0.0% 0ms
70        0.0%
71                  if(dr2.lt.2)then                               121.946ms 121.946ms 0.0% 0ms
72                     energy = energy + 1                           9.985ms   9.985ms 0.0% 0ms
73                  endif                                                              0.0%
74               enddo        0.0%
75            enddo        0.0%
76        0.0%
77     endif        0.0%
78      enddo        0.0%
79   enddo        0.0%
80        0.0%
81  !---main code I would like to port to MIC in array of structure format             0.0%
82   do i= 1,1000        0.0%
83        0.0%
84      do j = 1,1000        0.0%
85        0.0%
86         c1s = start(i)                                                              0.0%
87         c1e = end(i)        0.0%
88         if(j.gt.i) then                                                             0.0%
89        0.0%
90        0.0%
91            c2s = start(j)                                                           0.0%
92            c2e = end(j)                                                             0.0%
93            do l=c2s,c2e                                          10.047ms  10.047ms 0.0% 0ms
94        0.0%
95               do k = c1s,c1e                                    369.831ms 369.831ms 0.0% 0ms
96        0.0%
97                  x1 = part%x(k); y1 = part%y(k); z1 = part%z(k)  60.155ms  60.155ms 0.0% 0ms
98                  x2 = part%x(l); y2 = part%y(l); z2 = part%z(l)  39.988ms  39.988ms 0.0% 0ms
99        0.0%
100                  dr2 = (x2-x1)**2+(y2-y1)**2+(z2-z1)**2        240.033ms 240.033ms 0.0% 0ms
101        0.0%
102                  if(dr2.lt.2)then                              100.023ms 100.023ms 0.0% 0ms
103                     energy = energy + 1                        179.956ms 179.956ms 0.0% 0ms
104                  endif                                                             0.0%
105               enddo        0.0%
106            enddo        0.0%
107        0.0%
108     endif        0.0%
109      enddo        0.0%
110   enddo        0.0%
The above is as you posted with effectively stride 3
The first loop took 1114.4ms, the second 1000ms (14% faster)
Changing the first dim of rnew to 16 to account for additional properties (likely larger than necessary, but large enough to exhibit stride large enough to span cache line) yielded 1289.6ms or ~29% faster. Your speed difference on AVX would be somewhere in between. On MIC it would be hard to guess without running a test (and using appropriate size for rnew).
Jim Dempsey
conor_p_
Principiante
6.283 Visualizações
Ok, than you very much! The reason why I was trying to get all loops to vectorize, because I was under the assumption that I would get poor performance on the MIC if all loops weren't vectorized, not just the inner loop. Thats why I was trying to force all four loops to vectorize. Thanks for actually running test cases on my code.
Responder
