Software Archive
Read-only legacy content
17060 Discussions
view error for base64 image
igor_m_1
I have update Crosswalk feat from r17 to r19.
After this I have many problems on tags and CSS (mean for SPAN tag) but this issue i solved.
But now I cannot see all old image that was in base64 format, that with Crosswalk r-17 was working.
I tryed more base 64 format (png, jpeg, svg-xml) but the result was the same: a white square.
Usually I get base64 string from my remote web-service ( base64 string is not wrote in local code ) so I tried to write whole base64 String in local code, but doesn't work.
I want to tell you that this issue is only in real android devices: when I use simulatore inside IntelXDK is all visible.
I'm building for Android from sdk version 17.
Someone as same issue with crosswalk 19 ?
