Software Archive
Read-only legacy content
17060 Discussions
vt-d posted interrupts support
Rakesh_B_
        I have the S2600CP server board with cpu "Intel(R) Xeon(R) CPU E5-2620 v2 @ 2.10GHz" which supports for APICv, I had patched the linux kernel source 3.18.0 to support vt-d posted interrupts on direct assigned devices, Given in lkml "http://thread.gmane.org/gmane.linux.kernel.iommu/7708".
        I had checked the vt-d specification document[1] that describes "Remapping hardware support for interrupt-posting capability is reported through the Posted Interrupt Support (PI) field in the Capability register (CAP_REG)", In which it returns as the posted interrupt is not supported.  The assigning the ixgbe network device is been done via VFIO assignment method.
        [1] http://www.intel.com/content/www/us/en/intelligent-systems/intel-technology/vt-directed-io-spec.html
        Does the above hardware support vt-d posted interrupt for direct assigned device assignment or it requires any hardware to do this.
Rakesh
Quoc-Thai_L_Intel
The key is to get the correct combination of motherboard, chipset, CPU, and software for Intel(R) VT-d to work.  Here is another thread discussing about it that may provide some information for you: https://software.intel.com/en-us/forums/topic/473597?language=es
-Thai
