Software Archive
Read-only legacy content
17060 Discussions
warning #11021: unresolved IMB_internal_barrier
quan_w_
I'm follow the ReadMe_IMB.txt in intel mpi benchmarks directory, the set in that txt like this:
 a) Change the "Solution Platforms" dialog box to "x64".
   b) Change the "Solution Configurations" dialog box to "Release".
   c) Check other settings as required, for example:
    General > Project Defaults
       - Set "Character Set" to "Use Multi-Byte Character Set"
    C/C++ > General
       - Set "Additional Include Directories" to
           "$(I_MPI_ROOT)\intel64\include"
       - Set "Warning Level" to "Level 1 (/W1)"
    C/C++ > Preprocessor
       - For the "Preprocessor definitions" within the Visual Studio
         projects, add the conditional compilation macros WIN_IMB and
         _CRT_SECURE_NO_DEPRECATE. Depending on the components you intend to
         use, add one or more of the following macros:
         MPI1, EXT, MPIIO, NBC, RMA.
    Linker > Input
       - Set "Additional Dependencies" to "$(I_MPI_ROOT)\intel64\lib\impi.lib".
warning #11021: unresolved IMB_internal_barrier.
It seems the link error, is that should i add other lib to vs2015? But, i can't find some information about this.
thank you!
