Software Archive
Read-only legacy content
17060 Discussions
why is this error
josef_j_1
itry to install this plugin and i always get this error
com.cranberrygame.phonegap.plugin.ad.admob
{"dep_graph":{"com.cranberrygame.phonegap.plugin.ad.admob":"[email protected]"}}
Dale_S_Intel
I'm seeing the same.  I'll investigate and get back to you here.
Thanks!
Dale
Dale_S_Intel
It looks like it's a problem with the plugin.  You might try using these instructions, but I haven't tried running it myself.  Essentially, if you follow the "Solution 2" instructions, and be sure to remove the playservices dependences from the plugin.xml, it might work.
Let me know if that works for you, meanwhile I'll see if I can find a better solution.
Dale
josef_j_1
Thanks Dale , Solution 2 worked fine !
