Software Archive
Read-only legacy content
17060 Discussions
with my OPTIONAL variable (sortz), retlog=present(sortz) not working
kvrichardson
With my OPTIONAL variable (sortz), retlog=present(sortz) and (present(sortz) aren't working.
Not sure why. Here's what I have:
SUBROUTINE LIBRARIAN(prompt,choices,nchoices,nchosen,opts,nopts,
+optchosen,sortz)
USE DFLOGM
IMPLICIT NONE
LOGICAL, OPTIONAL :: sortz
LOGICAL(KIND=4) retlog
INTEGER x
if (retlog) then
x=1
else
x=2
endif
if (present(sortz) then
x=1
else
x=2
endif
With either test, the result is always x=1 even when I know I haven't passed the optional variable and in debug you can see it as "undefined".
This is a mixed language project - would my settings for "C, by reference", "Uppercase" or for "After All Args" disturb the workings of this ?
Any ideas would be appreciated.
Keith Richardson
kvrichardson
cancel this...I just found part on optional in Dr. Fortran in latest (12/00) newsletter!!!!
Thanks, Steve!
I'm glad to see that the Good Doctor was able to be of assistance.
Steve
kvrichardson
Now we're going to see why they call him 'THE GOOD DOCTOR' !
I read your piece and realized I either needed an interface in the calling routine or a contained subroutine. Since I have 50 calling routines, many of which include the optional sortz logical in the call, I opted for the former. So I changed my code to the following (changed or new lines as indicated):
     + optchosen,sortz)
USE DFLOGM
IMPLICIT NONE
NEW -*INCLUDE 'CPCOM.FOR'             !to use COMMON variable libsort
INCLUDE 'RESOURCE.FD'
CHARACTER*(*) prompt
integer nchoices
CHARACTER*(*) choices(nchoices)
integer nchosen, nopts
character*40 opts(nopts)
integer optchosen
changed-*LOGICAL sortz, sortz2           !removed OPTIONAL here, added sortz2
INTEGER x
INTEGER*4 retint, numc
integer ln(nchoices)
COMMON numc
EXTERNAL DISCALL
TYPE (dialog) dlg
NEW -*libsort=.false. !default is sortz is not present
NEW -*call TEST (sortz)    !sets libsort to .true. if sortz present, in contained subr. 			below
NEW -*if (.not.libsort) then
NEW -*	sortz2=.false.   !sortz not present so do not sort
NEW -*else
NEW -*	sortz2=sortz
NEW -*endif
	if (sortz2) then 			   !use sortz2 instead of sortz
	!launch dialog with sorted list box
	IF(.not. DlgInit(IDD_LIBRARIAN_SORTED_4_OPT, dlg)) THEN
		WRITE (*,*) "ERROR: dialog not found"
	ELSE
	ENDIF
	else
		....!launch dialog w/out sorted list box
	endif
	RETURN
new-* CONTAINS
new-* SUBROUTINE TEST(sortlog)
new-*	include 'cp.com'
new-* 	OPTIONAL :: sortlog
new-* 	IF (PRESENT(sortlog)) libsort=.TRUE.
new-* 	END SUBROUTINE TEST
       END SUBROUTINE
So, in prose, I added the CONTAINS SUBROUTINE TEST, removed the optional switch for sortz (actually, I tried it both ways and it didn't make a difference), and called to TEST.
In debugging, I stepped into TEST and libsort got set to .true. in the contained subroutine TEST whether or not sortz was present (whether it said "undefined address" in the debugger or was actually set to .true. or .false.).
Very strange. What am I not understanding?
Thanks doc,
Keith
kvrichardson
If my code is packed together in a giant run-on sentence when you folks read the prior post and you'd like to see it, just let me know and I'll e-mail it to you.
Keith
In the code you've given, SORTZ is always going to be present, because it is specified in the call to TEST and is not OPTIONAL in LIBRARIAN. If you want to test whether SORTZ was passed in to LIBRARIAN, it has to be OPTIONAL here *AND* anyone who calls LIBRARIAN needs to have an explicit interface for it.
Steve (aka Dr. Fortran)
P.S. To prevent your code from running together, bracket it with:
I edited your entry to do that.
kvrichardson
Thanks. That explains it!
