Software Archive
Read-only legacy content
17060 Discussions
wrong offload tag code
Alin_M_Elena
in the document listed here (the documentation for the latest intel fortran compiler 13.1.3)
http://software.intel.com/en-us/node/413108#30B8C09D-9EC7-401B-8CFC-E4FC3649C0AF
the code listed after (practically the last code there)
The following example demonstrates the tag argument:
contains two mistakes:
1. prevents the code to compile due to two stray #endif in the code
2. uses uninitialised values for gtag and ktag
this makes the resulting code to crash with the following message
[aelena00@node005 fortran]$ ifort -o offloadTags.MIX offloadTags.F90
[aelena00@node005 fortran]$ ./offloadTags.MIX
offload error: device 0 does not have a pending signal for wait(0xffffffffdeda6cd2)
forrtl: error (76): Abort trap signal
Image PC Routine Line Source
libc.so.6 00000036186328A5 Unknown Unknown Unknown
libc.so.6 0000003618634085 Unknown Unknown Unknown
liboffload.so.5 00007F7641690F1E Unknown Unknown Unknown
liboffload.so.5 00007F764169A80D Unknown Unknown Unknown
offloadTags.MIX 000000000040395C Unknown Unknown Unknown
offloadTags.MIX 0000000000403772 Unknown Unknown Unknown
offloadTags.MIX 000000000040370C Unknown Unknown Unknown
libc.so.6 000000361861ECDD Unknown Unknown Unknown
offloadTags.MIX 0000000000403599 Unknown Unknown Unknown
Aborted (core dumped)
[aelena00@node005 fortran]$ ifort -o offloadTags.MIX offloadTags.F90 -DdoGLOB
offload error: device 0 does not have a pending signal for wait((nil))
liboffload.so.5 00007FB889492F1E Unknown Unknown Unknown
liboffload.so.5 00007FB88949C80D Unknown Unknown Unknown
offloadTags.MIX 0000000000403960 Unknown Unknown Unknown
initialising them to some values... results in an working code
5.100000 5.100000 5.100000 5.100000 5.100000
regards,
Alin
I have already reported this against the documentation.
Kevin_D_Intel
Thank you for the note Alin. The noted mistakes in this example are fixed in the documentation for the coming Composer XE 2013 SP1 release (next month).
Alin_M_Elena
Thank you Kevin! Great to hear that!
Alin
