Software Archive
Read-only legacy content
17060 Discussions
xdk 3987 optional permission in android build settings not work
Arthur_T_
after I added
android.permission.WRITE_EXTERNAL_STORAGE
to android build settings: Add Permissions
then create the package, it is not added to config.xml
Then I try to add to intelxdk.config.additions.xml instead as:
<platform name="android">
    <config-file target="AndroidManifest.xml" parent="/*">
      <uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE" />
    </config-file>
</platform>
but config.xml only contain this:
      </config-file>
Is it a bug and how can I add the permission?
PaulF_IntelCorp
In the Build Settings field for additional permissions, did you add it as "WRITE_EXTERNAL_STORAGE" or as "android.permission.WRITE_EXTERNAL_STORAGE"? You need to use the shorter one (the first example).
