Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
353 Discussions
Intel VROC software RAID5 failed after single disk failure
Spacely
We have a 8 NVME drive Raid5.  One drive failed so we replaced it.  I placed the new drive into the server and it did not rebuild automatically.
Intel VROC states that the
Volume0,  Raid5(Parity)  is degraded.
I have the option to rebuild using the new drive but am afraid I will loose all the data.  Is that the proper steps to recover the RAID5?
sudo mdadm --detail /dev/md126
/dev/md126:
Container : /dev/md/imsm0, member 0
Raid Devices : 8
Total Devices : 7
State : active, FAILED, Not Started
Active Devices : 7
Working Devices : 7
Failed Devices : 0
Spare Devices : 0
Consistency Policy : unknown
UUID : 807054a8:5d4f9f4a:2f6496b1:ed5a03f0
Number Major Minor RaidDevice State
- 0 0 0 removed
- 0 0 1 removed
- 0 0 2 removed
- 0 0 3 removed
- 0 0 4 removed
- 0 0 5 removed
- 0 0 6 removed
- 0 0 7 removed
- 259 9 4 sync /dev/nvme6n1
- 259 10 7 sync /dev/nvme9n1
- 259 6 0 sync /dev/nvme2n1
- 259 5 3 sync /dev/nvme5n1
- 259 7 2 sync /dev/nvme4n1
- 259 11 5 sync /dev/nvme7n1
- 259 8 1 sync /dev/nvme3n1
Running the command lsblk  shows all the 8 drives are showing up.  nvme8n1 was the bad drive that I replaced:
nvme5n1 259:5 0 7T 0 disk
nvme2n1 259:6 0 7T 0 disk
nvme4n1 259:7 0 7T 0 disk
nvme3n1 259:8 0 7T 0 disk
nvme6n1 259:9 0 7T 0 disk
nvme9n1 259:10 0 7T 0 disk
nvme7n1 259:11 0 7T 0 disk
nvme8n1 259:12 0 7T 0 disk
Thanks for any help!
RyanFeeko
New Contributor II
hey @Spacely , after replace the new drive, its may need kick start the rebuilding and once rebuilding completed only then the RAID5 back to normal state.
Hope this helps...
Megala-Durairaj
Hi Andrew,
Greetings for the day!
We do have an article containing instructions on RAID 5 rebuild. Please refer to the article below and confirm if it meets your needs
How to Recover an Intel® Virtual RAID on CPU (Intel® VROC) RAID 5 Volume
Kindly check and confirm
Megala Durairaj
Intel.com/VROC
Megala-Durairaj
Hi Andrew,
Megala Durairaj
Intel.com/VROC
Megala-Durairaj
Hi Andrew,
Hope you are doing good!
 Could you please confirm whether the article sent in the previous post has been helpful in addressing the issue? Your feedback on this matter would be greatly appreciated.
Megala Durairaj
Intel.com/VROC
Megala-Durairaj
Hi Andrew,
Could you please confirm whether the VROC article sent in the previous post has been helpful in addressing the issue? Your feedback on this matter would be greatly appreciated.
Megala Durairaj
Intel.com/VROC
Megala-Durairaj
Hi Andrew,
Megala Durairaj
Intel.com/VROC
