1825 Discussions
Access to Intel(r) Performance Counter Monitor has denied (no MSR or PCI CFG space access) message is showing with pcm-memory.x
Jerry_S_1
Hello, i am jerry
I am trying to run the pcm-memory.x and pcm-power.x on windows platform with WinRing0X64.dll and sys driver files instead of recompiled msr.sys.
By the way, pcm-win.x is running well but pcm-memory and power tool have some problems to run them.
they are alway showing below messages
for pcm-memory.x
C:\IntelPerformanceCounterMonitor-V2.9\PCM-Memory_Win\Debug>pcm-memory.exe 5
DEBUG: Setting Ctrl+C done.
 Intel(r) Performance Counter Monitor: Memory Bandwidth Monitoring Utility V2.9 (2015-08-07 10:23:17 +0200 ID=721d9e3)
 Copyright (c) 2009-2015 Intel Corporation
 This utility measures memory bandwidth per channel or per DIMM rank in real-time
Starting MSR service failed with error 2 ATrying to load winring0.dll/winring0.sys driver...
Using winring0.dll/winring0.sys driver.
Number of physical cores: 4
Number of logical cores: 8
Number of online logical cores: 8
Threads (logical cores) per physical core: 2
Num sockets: 1
Physical cores per socket: 4
Core PMU (perfmon) version: 3
Number of core PMU generic (programmable) counters: 4
Width of generic (programmable) counters: 48 bits
Number of core PMU fixed counters: 3
Width of fixed counters: 48 bits
Nominal core frequency: 3600000000 Hz
Package thermal spec power: 84 Watt; Package minimum power: 0 Watt; Package maximum power: 0 Watt;
Driver Unloaded.
Loaded Driver C:\IntelPerformanceCounterMonitor-V2.9\PCM-Memory_Win\Debug\winpmem_64.sys.
Access to Intel(r) Performance Counter Monitor has denied (no MSR or PCI CFG space access).
Cleaning up
for pcm-power.x
C:\IntelPerformanceCounterMonitor-V2.9\PCM-Power_Win\Debug>pcm-power.exe
 Intel(r) Performance Counter Monitor V2.9 (2015-08-07 10:23:17 +0200 ID=721d9e3)
 Power Monitoring Utility
Num sockets: 1
Driver Unloaded.
Loaded Driver C:\IntelPerformanceCounterMonitor-V2.9\PCM-Power_Win\Debug\winpmem_64.sys.
Unsupported processor model (60).
Cleaning up
In case of pcm-power.x, my CPU(i74790) seems to not be supported because of non-xeon series.
By the way, i am not sure for pcm-momory.x. I think it should be running well.
Do you have any ideas for this?
Once message "Access to Intel(r) Performance Counter Monitor has denied (no MSR or PCI CFG space access)." looks like
my CPU can not get access to Specific MSR register and PCI CFG bar with MMIO since my CPU don't have these kinds of feature.
thanks in advance.
BR,
JERRY
Roman_D_Intel
pcm-memory is not supported on your processor (it does not have the performance monitoring units that the tool requires).
Roman
Roman_D_Intel
Roman
Jerry_S_1
Hi Roman,
Thanks for your quick reply.
i understand.
thanks again.
Jerry
