Bug: PCM doesn't support offline cores
Tomer_M_
PCM samples several events on socketRefCore which remains static during PCM's run. This prevents PCM from correctly reading counter values when specific cores are offline, for example when using:
$ echo 0 > /sys/devices/system/cpu/cpu7/online
In the above case in my system, PCM reports that energy is zero.
Tomer.
Roman_D_Intel
Hi Tomer,
unfortunately, changing topology while PCM is running is not something that we can support in near future.
Roman
