Calculating Memory Bandwidth using perfmon2
Shuja-ur-Rehman_B_
I need to calculate memory bandwidth using perfmon2 for the following system.
model name      : Intel(R) Core(TM) i7-3740QM CPU @ 2.70GHz
Can anybody let me know the formula for it?
Shuja
dhumal__akshay
You can compute the memory bandwidth using Intel PCM tool. Run pcm-memory.x and fetch data for read/write bandwidth of each channel.
