Can I monitor process using PCM
Chandrashekhar_G_
I have linux.
when I run pcm.x "sleep 1" it gives me hardware counters per core. I want the hardware counters per process.
Is possible to monitor hardware counters per process using pcm?
Chandrashekhar Garkar.
Patrick_F_Intel1
Hello Chandrashekhar,
Sorry, you can't use PCM to get the hardware counters per process.
You can get per process counters with VTune or maybe (probably) with linux perf.
Pat
Chandrashekhar_G_
Hello Pat,
Thanks for a quick reply.
I am facing some issues with perf so I wanted an alternative to perf.
Is VTune opensource??
--Chandrashekhar
Patrick_F_Intel1
No, VTune is not openSource.
But you can try it for free at http://software.intel.com/en-us/intel-vtune-amplifier-xe
Pat
Chandrashekhar_G_
Thanks Pat,
Can I get counters for one core at a time, as I have multicore system.
Using PCM I mean to say.
--chandrashekhar garkar
Chandrashekhar_G_
Thanks Pat,
Bernard
Valued Contributor I
Better option is to use VTune to perform code analysis.Some counters have the granularity of single hardware thread (i.e logical cpu).
sol_s_
If you are having issues with perf, you can try the PAPI which will work fine for the the multi-core per process analysis, or look into Valgrind.
Patrick_F_Intel1
Chandrashekhar G. wrote:
Thanks Pat,
I'm not exactly sure what you mean. Using PCM you can get stats for each core. But not for just 1 core at a time (unless you boot to single core).
Pat
