Cannot reinstall Intel XTU patform
TonyGesto
Hello mates i just unistalled Intel XTU by control panel on Windows 11, but when i try to reinstall the program shows a error and report this log file...seems like was not properly unistalled....
[62D8:0740][2022-03-09T20:30:03]i001: Burn v3.11.1.2318, Windows v10.0 (Build 22000: Service Pack 0), path: C:\Users\tonyg\AppData\Local\Temp\{FC29EA28-B317-45D9-B24C-330F61A8802F}\.cr\XTUSetup.exe
[62D8:0740][2022-03-09T20:30:03]i000: Initializing string variable 'RemoveAllDataCheckboxValue' to value '[RemoveAllDataCheckbox]'
[62D8:0740][2022-03-09T20:30:03]i000: Initializing version variable 'BundleVersionNumber' to value '7.6.0.37'
[62D8:0740][2022-03-09T20:30:03]i009: Command Line: '-burn.clean.room=C:\Users\tonyg\Downloads\XTUSetup.exe -burn.filehandle.attached=572 -burn.filehandle.self=684'
[62D8:0740][2022-03-09T20:30:03]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\tonyg\Downloads\XTUSetup.exe'
[62D8:0740][2022-03-09T20:30:03]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\tonyg\Downloads\'
[62D8:0740][2022-03-09T20:30:03]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\tonyg\AppData\Local\Temp\Intel(R)_Extreme_Tuning_Utility_20220309203003.log'
[62D8:0740][2022-03-09T20:30:03]i052: Condition 'VersionNT >= v6.1' evaluates to true.
[62D8:0740][2022-03-09T20:30:03]i000: Setting string variable 'WixBundleName' to value 'Intel(R) Extreme Tuning Utility'
[62D8:0740][2022-03-09T20:30:03]i000: Setting string variable 'WixBundleManufacturer' to value 'Intel Corporation'
[62D8:6094][2022-03-09T20:30:03]i000: Setting version variable 'WixBundleFileVersion' to value '7.6.0.37'
[62D8:0740][2022-03-09T20:30:03]i100: Detect begin, 1 packages
[62D8:0740][2022-03-09T20:30:03]i000: Setting version variable 'MsiAlreadyInstalledVersion' to value '7.6.0.37'
[62D8:0740][2022-03-09T20:30:03]i000: Setting string variable 'NETFRAMEWORK45' to value '528449'
[62D8:0740][2022-03-09T20:30:03]i000: Setting version variable 'WindowsDllVersion' to value '10.0.22000.434'
[62D8:0740][2022-03-09T20:30:03]w120: Detected partially cached package: Intel_XtuInstaller.msi, invalid payload: Intel_XtuInstaller.msi, reason: 0x80070002
[62D8:0740][2022-03-09T20:30:03]i101: Detected package: Intel_XtuInstaller.msi, state: Present, cached: Partial
[62D8:0740][2022-03-09T20:30:03]i052: Condition 'BundleVersionNumber > MsiAlreadyInstalledVersion OR BundleVersionNumber = "0.0.0.0" OR NOT WixBundleAction = 5' evaluates to false.
[62D8:0740][2022-03-09T20:30:03]e000: Another flavor of the XTU application of a same or higher version is already installed. Uninstall the following from Add/Remove Programs: Intel(R) Extreme Tuning Utility
[62D8:0740][2022-03-09T20:30:03]e000: Error 0x81f40001: Bundle condition evaluated to false: BundleVersionNumber > MsiAlreadyInstalledVersion OR BundleVersionNumber = "0.0.0.0" OR NOT WixBundleAction = 5
[62D8:0740][2022-03-09T20:30:03]i199: Detect complete, result: 0x0
