Functions & Macro-Wrapper using RDTSC instruction
SergeyKostrov
Valued Contributor II
Hi everybody,
Here are a couple of functions &macro-wrapper to measure time intervals with as better as possible accuracyusing RDTSC instruction:
//*** Version 1 - Win32 ***//
template < class T > inline _RTdeclspec_naked RTuint64 HrtClock( RTvoid )
//printf( "[ HrtClock ]\\n" );
_asm
rdtsc
ret
//*** Version 2 - Win32 ***//
_RTdeclspec_naked RTuint64 HrtClock( void )
_asm
rdtsc
ret
//*** Version 3 - Win32 ***//
void HrtClock( RTuint64 *puiClock )
RTuint64 v;
_asm
push eax
push edx
_emit 0x0f
_emit 0x31
mov dword ptr v, eax
mov dword ptr v+4, edx
pop edx
pop eax
*puiClock = v;
//*** Version 4 - Linux32 ( with GCC or MinGW ) ***//
RTclock_t HrtClock( RTvoid )
RTclock_t ctValue;
__asm__
"rdtsc;"
"mov %%edx, %%ecx;" : "=a" ( ctValue )
return ( RTclock_t )ctValue;
//*** Version 5 - Linux32 ( with GCC or MinGW ) ***//
#define HrtClock( Value ) \\
__asm__ __volatile__\\
".byte 0x0f; .byte 0x31" \\
: "=A" ( Value ) \\
TimP
For several years, Microsoft and Intel compilers have a built-in macro __rdtsc which handles all the platforms.
SergeyKostrov
It is declared in 'intrin.h' header file and actually this is an intrinsic function ( not a macro ):
unsigned __int64 __rdtsc( void );
SergeyKostrov
This is a follow up because I've detectedsomeissues with Version 4 example for Linux32 with GCC or
MinGW C/C++ compilers
This is what Intel's documentation says about RDTSC instruction in an 'Instruction Set Reference' Volume 2B:
Loads the current value of the processor's time-stamp counter ( a 64-bit MSR ) into the EDX:EAX
registers.
Found issues are as follows:
1. On a 32-bit platforms 'clock_t' type is declared as a32-bit type 'long' ( 4 bytes ) and it is verified with
all 32-bitC/C++ compilers I use:
typedef long clock_t;
2. "=A" has to be used instead of "=a"
3. A pair of registers 'edx' and 'ecx'is used instead of 'edx' and 'eax', and if you change:
"mov %%edx, %%ecx;" : "=A" ( ctValue )
to
"mov %%edx, %%eax;" : "=A" ( ctValue )
it doesn't work! So, theregisters 'edx' and 'ecx'have to beused anyway
4. Finally, a working C/C++ code looks like this:
inline RTuint64 HrtClock( RTvoid )
RTuint64 uiValue;
__asm__
"rdtsc;"
"mov %%edx, %%ecx;" : "=A" ( uiValue )
return ( RTuint64 )uiValue;
SergeyKostrov
Here are some assembler codes generated by a 'g++' C/C++ compiler.
The left example doesn't work. The right example works.
.stabn 68,0,284,LM5832-__Z8HrtClockv .stabn 68,0,284,LM5832-__Z8HrtClockv
LM5832: LM5832:
/APP /APP
rdtsc;mov %edx, %eax;rdtsc;mov %edx, %ecx;
/NO_APP /NO_APP
movl%eax, -8(%ebp) movl%eax, -8(%ebp)
movl%edx, -4(%ebp) movl%edx, -4(%ebp)
.stabn 68,0,287,LM5833-__Z8HrtClockv .stabn 68,0,287,LM5833-__Z8HrtClockv
LM5833: LM5833:
movl-8(%ebp), %eax movl-8(%ebp), %eax
movl-4(%ebp), %edx movl-4(%ebp), %edx
LBE895: LBE895:
LBE894: LBE894:
.stabn 68,0,288,LM5834-__Z8HrtClockv .stabn 68,0,288,LM5834-__Z8HrtClockv
LM5834: LM5834:
leave leave
ret ret
It is not clear why the left example doesn't work and it always returns 0.
A_T_Intel
It is worth mentioning the problem with RDTSC and out of order execution:
http://en.wikipedia.org/wiki/Time_Stamp_Counter
Starting with the Pentium Pro, Intel processors have supported out-of-order execution, where instructions are not necessarily performed in the order they appear in the executable. This can cause RDTSC to be executed later than expected, producing a misleading cycle count.[3] This problem can be solved by executing a serializing instruction, such as CPUID, to force every preceding instruction to complete before allowing the program to continue, or by using the RDTSCP instruction, which is a serializing variant of the RDTSC instruction (starting from Core i7[4] and starting from AMD Athlon 64 X2 CPUs with AM2 Socket (Windsor & Brisbane)).
SergeyKostrov
Thank you, Perry.
Unfortunately, I can'tuse RDTSCP instruction.
I had a problem withincorrect values returned from 'HrtClock' function that uses RTDSC instruction.It
was related to a declaration of return value as'clock_t' ( long \ 32-bit )instead of 'uint64' ( 64-bit ).
I wanted to inform that possiblythere is a bug in the MinGW C/C++ compiler related to '%%edx, %%ecx' declaration.
Sergey
TimP
I've encountered no difficulty with rdtsc under mingw:
[bash]unsigned long long int rdtsc( )
[/bash]
[bash]#elif defined(__GNUC__)
#if defined i386
   long long a;
   asm volatile("rdtsc":"=A" (a));
   return a;
#elif defined __x86_64
   unsigned int _hi,_lo;
   asm volatile("rdtsc":"=a"(_lo),"=d"(_hi));
   return ((unsigned long long int)_hi << 32) | _lo;
[/bash]
Evidently, tick count differences should be taken in 64-bit unsigned arithmetic.
The left shift operator displays correctly if you go to edit mode.
SergeyKostrov
Thank you, Tim. I'll try your example of using RDTSC instruction.
>>...Evidently, tick count differences should be taken in 64-bit unsigned arithmetic...
Always! When I tried to use 'clock_t', type'long' 32-bit on a32-bit platform, I had sometimes absolutely
incorrect values returned from my'HrtClock' function.
Sergey
TimP
Yes, 32-bit differences (taken from the low order 32 bits) will work until the counter has a carry into the high order bits, which takes very few seconds.
SergeyKostrov
I decided to use
__asm__ volatile( "rdtsc;" : "=A" ( uiValue ) ); ( version B )
instead of
__asm__( "rdtsc;"
"mov %%edx, %%ecx;" : "=A" ( uiValue ) );( version A )
because 'version B' doesn't have 'mov %%edx, %%ecx'.
In terms of assembler codes compiled by a MinGW C/C++ compiler I haven't found any problems
with theversion B:
.stabn 68,0,244,LM2990-__Z8HrtClockv
LM2990:
pushl %ebp
movl %esp, %ebp
subl $8, %esp
LBB548:
LBB549:
.stabn 68,0,258,LM2991-__Z8HrtClockv
LM2991:
/APP
rdtsc;
/NO_APP
movl %eax, -8(%ebp)
movl %edx, -4(%ebp)
.stabn 68,0,260,LM2992-__Z8HrtClockv
LM2992:
movl -8(%ebp), %eax
movl -4(%ebp), %edx
LBE549:
LBE548:
.stabn 68,0,261,LM2993-__Z8HrtClockv
LM2993:
leave
ret
.stabs "uiValue:(93,22)",128,0,249,-8
and it works. No runtimeissues or problems detected so far.
Sergey
SergeyKostrov
This is a follow up. All three widely used Visual Studios 2005, 2008 and 2010 have a declaration of '__rdtsc' intrinsic function
in 'intrin.h' header file:
__MACHINEI( unsigned __int64 __rdtsc( void ) )
