How to compile Code having PCM API?
totochan1985
There is a piece of code (c_example.c) that comes with the PCM installation. Can someone tell me how to compile that i.e which libraries it needs to be linked against. Below is the code.
#include "cpucounters.h"
#include <stdio.h>
#include <dlfcn.h>
#include <stdint.h>
#include <stdlib.h>
int pcm_getcpu()
        int id = -1;
        asm volatile (
                "rdtscp\n\t"
                "mov %%ecx, %0\n\t":
                "=r" (id) :: "%rax", "%rcx", "%rdx");
        // processor ID is in ECX: https://www.felixcloutier.com/x86/rdtscp
        // Linux encodes the NUMA node starting at bit 12, so remove the NUMA
        // bits when returning the CPU integer by masking with 0xFFF.
        return id & 0xFFF;
struct {
        int (*pcm_c_build_core_event)(uint8_t id, const char * argv);
        int (*pcm_c_init)();
        void (*pcm_c_start)();
        void (*pcm_c_stop)();
        uint64_t (*pcm_c_get_cycles)(uint32_t core_id);
        uint64_t (*pcm_c_get_instr)(uint32_t core_id);
        uint64_t (*pcm_c_get_core_event)(uint32_t core_id, uint32_t event_id);
} PCM;
#ifndef PCM_DYNAMIC_LIB
/* Library functions declaration (instead of .h file) */
int pcm_c_build_core_event(uint8_t, const char *);
int pcm_c_init();
void pcm_c_start();
void pcm_c_stop();
uint64_t pcm_c_get_cycles(uint32_t);
uint64_t pcm_c_get_instr(uint32_t);
uint64_t pcm_c_get_core_event(uint32_t, uint32_t);
#endif
int main(int argc, const char *argv[])
        int i,a[100],b[100],c[100];
        uint32_t total = 0;
        int lcore_id;
        /* Seed for predictable rand() results */
        srand(0);
        for (i=0; i < 100; ++i) {
                a[i] = rand();
                b[i] = rand();
                c[i] = rand();
#ifdef PCM_DYNAMIC_LIB
        void * handle = dlopen("libpcm.so", RTLD_LAZY);
        if(!handle) {
                printf("Abort: could not (dynamically) load shared library \n");
                return -1;
        PCM.pcm_c_build_core_event = (int (*)(uint8_t, const char *)) dlsym(handle, "pcm_c_build_core_event");
        PCM.pcm_c_init = (int (*)()) dlsym(handle, "pcm_c_init");
        PCM.pcm_c_start = (void (*)()) dlsym(handle, "pcm_c_start");
        PCM.pcm_c_stop = (void (*)()) dlsym(handle, "pcm_c_stop");
        PCM.pcm_c_get_cycles = (uint64_t (*)(uint32_t)) dlsym(handle, "pcm_c_get_cycles");
        PCM.pcm_c_get_instr = (uint64_t (*)(uint32_t)) dlsym(handle, "pcm_c_get_instr");
        PCM.pcm_c_get_core_event = (uint64_t (*)(uint32_t,uint32_t)) dlsym(handle, "pcm_c_get_core_event");
#else
        PCM.pcm_c_build_core_event = pcm_c_build_core_event;
        PCM.pcm_c_init = pcm_c_init;
        PCM.pcm_c_start = pcm_c_start;
        PCM.pcm_c_stop = pcm_c_stop;
        PCM.pcm_c_get_cycles = pcm_c_get_cycles;
        PCM.pcm_c_get_instr = pcm_c_get_instr;
        PCM.pcm_c_get_core_event = pcm_c_get_core_event;
#endif
        if(PCM.pcm_c_init == NULL || PCM.pcm_c_start == NULL || PCM.pcm_c_stop == NULL ||
                        PCM.pcm_c_get_cycles == NULL || PCM.pcm_c_get_instr == NULL ||
                        PCM.pcm_c_build_core_event == NULL)
                return -1;
        switch(argc-1)
                case 4:
                        PCM.pcm_c_build_core_event(3,argv[3]);
                case 3:
                        PCM.pcm_c_build_core_event(2,argv[2]);
                case 2:
                        PCM.pcm_c_build_core_event(1,argv[2]);
                case 1:
                        PCM.pcm_c_build_core_event(0,argv[1]);
                case 0:
                        break;
                default:
                        printf("Number of arguments are too many! exit...\n");
                        return -2;
        printf("[c_example] Initializing PCM measurements:\n");
        PCM.pcm_c_init();
        printf("[c_example] Calling PCM start()\n");
        PCM.pcm_c_start();
        for(i=0;i<10000;i++)
                c[i%100] = 4 * a[i%100] + b[i%100];
        for(i=0;i<100;i++)
                total += c[i];
        PCM.pcm_c_stop();
        printf("[c_example] PCM measurment stopped, compute result %u\n", total);
        lcore_id = pcm_getcpu();
        printf("C:%lu I:%lu, IPC:%3.2f\n",
                PCM.pcm_c_get_cycles(lcore_id),
                PCM.pcm_c_get_instr(lcore_id),
                (double)PCM.pcm_c_get_instr(lcore_id)/PCM.pcm_c_get_cycles(lcore_id));
        printf("CPU%d E0: %lu, E1: %lu, E2: %lu, E3: %lu\n",
                lcore_id,
                PCM.pcm_c_get_core_event(lcore_id,0),
                PCM.pcm_c_get_core_event(lcore_id,1),
                PCM.pcm_c_get_core_event(lcore_id,2),
                PCM.pcm_c_get_core_event(lcore_id,3));
        return 0;
Thomas_W_Intel
The example needs to be linked against libpcm. This should be everything you need.
You might also want to have a look at the Makefile of the project. It includes the rules to compile and link the example.
