Software Tuning, Performance Optimization & Platform Monitoring
Discussion regarding monitoring and software tuning methodologies, Performance Monitoring Unit (PMU) of Intel microprocessors, and platform updating.
How to recognize wthat a applications exacting to latency ?
SB17
初学者
1,685 次查看
Hello all
I look for applications exacting to latency.
Not always developers can tell that the application is exacting to latency.
I had an idea to define it by forum of monitoring of counters of the CPU.
Whether to check the CPU or process he expects data from memory or from a network.
I looked on the Internet, but I thought that at this forum I can be directed in the right direction much quicker.
What counters can reflect a situation of waiting of process or the processor of data from memory or from a network?
Whether can reflect it that applications are exacting to latency?
Thanks for your time
P.S. Probably it somehow can be made by means of Intel Amplifer however I didn't try yet and it will be great do it by console or C.
0 项奖励
1 解答
Thomas_G_4
新分销商 II
1,685 次查看
Idling is a difficult term for recent CPUs. Is is pretty rare that a CPU core has no instructions in the pipeline (idle) but is not forced to some different low-power state.
There are many events that give you information about halted CPU cores.
The fixed events on Intel CPUs give a first impression: If the INST_RETIRED.ANY event value per second is small, this is an indication. If the CPU_CLOCKS_UNHALTED.* are small, the CPU was probably in halted state.
You should have a look at all events with STALL in their names. Moreover, the CYCLE_ACTIVITY.* events can be what you are searching for. There is an event like "no activity due to waiting on memory loads". But keep in mind that a stall is different from idling.
Additionally, take a look at the C3 and C6 state counters.
There are scientific papers about that topic but the points, you are interested in, are somewhat hidden. There is a paper for reducing the CPU clock when a code's performance is limited by memory accesses. So, they need to detect it but their main work is about the reaction. I don't have links to that paper, but <insert search engine> will find it.
在原帖中查看解决方案
0 项奖励
4 回复数
SB17
初学者
1,685 次查看
Maybe my english is very bad.
I will try to rephrase
How to understand from PCM that the CPU/core is idle ?
Is it possible to understand that the idle is associated with waiting for a response from memory or PCI-E or file system ?
Tell me what I can read on this topic ?
Thanks for you time
0 项奖励
Thomas_G_4
新分销商 II
1,686 次查看
0 项奖励
McCalpinJohn
名誉分销商 III
1,685 次查看
Unfortunately the documentation in Chapter 19 of Volume 3 of the Intel Architectures SW Developer's Manual is badly broken for the CYCLE_ACTIVITY.* events on almost all processors.   The documentation for the Skylake core looks like the only one that correctly lists the required CMASK values.
0 项奖励
SB17
初学者
1,685 次查看
sorry for long absence
Vary thanks for answer.
I will try to find info about CYCLE_ACTIVITY.* events.
Thanks for you time
0 项奖励
回复
