1854 Discussions
Inaccuracy from Memory read/write bytes when using PCM-2.11 on Core i7 5960X Haswell-E
ZWang45
Hi All,
I try to use PCM-2.11 to measure the memory read/write bytes on Intel I7 5960X Processor Extreme Edition.
The example “for (int i = 0; i < 200000000; i++) (int *)p_data = i;” is compiled with ICC 16.0.3.
I have checked the assemble of the store instruction: movdqa. It means each cache line will be read first.
The PCM result shows:
BytesReadFromMC: 47615872 (wrong number)
BytesWrittenToMC: 808465920 (right number).
Do I need to modify the lines in cpucounters.cpp:
void ServerPCICFGUncore::program()
    uint32 MCCntConfig[4] = {
        MC_CH_PCI_PMON_CTL_EVENT(0x04) + MC_CH_PCI_PMON_CTL_UMASK(3),
        MC_CH_PCI_PMON_CTL_EVENT(0x04) + MC_CH_PCI_PMON_CTL_UMASK(12),
McCalpinJohn
It looks like this is an attempt to measure behavior for the initial access to the array.   The behavior of the system for page instantiation may not be what you expect.
I recommend that you add more loops to read/write the data after it is initialized, and that you make the number of times the data is accessed after initialization an easy-to-modify variable.  You should then see that you get the expected memory access counts for subsequent accesses.
