Software Tuning, Performance Optimization & Platform Monitoring
Discussion regarding monitoring and software tuning methodologies, Performance Monitoring Unit (PMU) of Intel microprocessors, and platform updating.
1812 Discussões
Intel IOMeter problem - why Windows multi-threading data fetching is much much faster than IOMeter?
zhaonaiy
Principiante
1.597 Visualizações
Greetings,
I do apologize if I post this message to a wrong place, but I really don't know where to seek help about IOMeter (not sure if Intel still take care of its support, even though it has already gone to sourceforge).
I did some testing using windows multi-threading data fetching against IO Meter, but foundIOPS calculated from my program is much much faster than IOMeter. I tried hard to figure out where's the problem but got frustrated.
My SSD is PLEXTOR PX-128M3S, by IOMeter, its max 512B random read IOPS is around 94k (queue depth is 32).
However my program (32 windows threads) can reach around 500k 512B IOPS, around 5 times of IOMeter!!! I did data validation but didn't find any error in data fetching. It's because my data fetching in order?
I paste my code below (it mainly fetch 512B from file and release it; I did use 4bytes (an int) to validate program logic and didn't find problem), can anybody help me figure out where I am wrong?
Thanks so much in advance!!
Nai Yan.
#include
#include
** Purpose: Verify file random read IOPS in comparison with IOMeter
** Author: Nai Yan
** Date: Feb. 9th, 2012
//Global variables
long completeIOs = 0;
long completeBytes = 0;
int threadCount = 32;
unsigned long long length = 1073741824; //4G test file
int interval = 1024;
int resultArrayLen = 320000;
int *result = new int[resultArrayLen];
//Method declarison
double GetSecs(void); //Calculate out duration
int InitPool(long long,char*,int); //Initialize test data for testing, if successful, return 1; otherwise, return a non 1 value.
int * FileRead(char * path);
unsigned int DataVerification(int*, int sampleItem); //Verify data fetched from pool
int main()
int sampleItem = 0x1;
char * fPath = "G:\\\\workspace\\\\4G.bin";
unsigned int invalidIO = 0;
if (InitPool(length,fPath,sampleItem)!= 1)
printf("File write err... \\n");
//start do random I/Os from initialized file
double start = GetSecs();
int * fetchResult = FileRead(fPath);
double end = GetSecs();
printf("File read IOPS is %.4f per second.. \\n",completeIOs/(end - start));
//start data validation, for 4 bytes fetch only
// invalidIO = DataVerification(fetchResult,sampleItem);
// if (invalidIO !=0)
// printf("Total invalid data fetch IOs are %d", invalidIO);
return 0;
int InitPool(long long length, char* path, int sample)
printf("Start initializing test data ... \\n");
FILE * fp = fopen(path,"wb");
if (fp == NULL)
printf("file open err... \\n");
exit (-1);
else //initialize file for testing
fseek(fp,0L,SEEK_SET);
for (int i=0; i
fwrite(&sample,sizeof(int),1,fp);
fclose(fp);
fp = NULL;
printf("Data initialization is complete...\\n");
return 1;
LARGE_INTEGER frequency;
LARGE_INTEGER start;
if(! QueryPerformanceFrequency(&frequency))
printf("QueryPerformanceFrequency Failed\\n");
if(! QueryPerformanceCounter(&start))
printf("QueryPerformanceCounter Failed\\n");
return ((double)start.QuadPart/(double)frequency.QuadPart);
class input
public:
char *path;
int starting;
input (int st, char * filePath):starting(st),path(filePath){}
//Workers
DWORD WINAPI FileReadThreadEntry(LPVOID lpThreadParameter)
input * in = (input*) lpThreadParameter;
char* path = in->path;
FILE * fp = fopen(path,"rb");
int sPos = in->starting;
// int * result = in->r;
if(fp != NULL)
fpos_t pos;
for (int i=0; i
pos = i * interval;
fsetpos(fp,&pos);
//For 512 bytes fetch each time
unsigned char *c =new unsigned char [512];
if (fread(c,512,1,fp) ==1)
InterlockedIncrement(&completeIOs);
delete c;
//For 4 bytes fetch each time
/*if (fread(&result[sPos + i],sizeof(int),1,fp) ==1)
else
printf("file read err...\\n");
exit(-1);
fclose(fp);
fp = NULL;
else
printf("File open err... \\n");
exit(-1);
int * FileRead(char * p)
printf("Starting reading file ... \\n");
HANDLE mWorkThread[256]; //max 256 threads
completeIOs = 0;
int slice = int (resultArrayLen/threadCount);
for(int i = 0; i < threadCount; i++)
mWorkThread = CreateThread(
NULL,
0,
FileReadThreadEntry,
(LPVOID)(new input(i*slice,p)),
0,
NULL);
WaitForMultipleObjects(threadCount, mWorkThread, TRUE, INFINITE);
printf("File read complete... \\n");
return result;
unsigned int DataVerification(int* result, int sampleItem)
unsigned int invalid = 0;
for (int i=0; i< resultArrayLen/interval;i++)
if (result!=sampleItem)
invalid ++;
continue;
return invalid;
2 Respostas
Patrick_F_Intel1
Funcionário
1.597 Visualizações
Hello zhaonaly,
If I understand correctly, you are comparing IOmeter's random read performance to your program's sequential read performance.
Random 'anything' (such as disk reads/writes, memory reads/writes)are generally much slower than sequential reads and writes.
The IOmeter product has a forum and you've posted this message there.
That is probably the appropriate place for the message.
Hope this helps,
Pat
SergeyKostrov
Contribuidor valorado II
1.597 Visualizações
I think that comparison is not valid because it is hard to reproduce / replicate IOmeter's algorithm for measuring I/O performance.
Is IOmeter an Open Source project? If Yes,you can look what it does and how it calculates values.
Sergey
Responder
