1858 Discussions
Intel PCM: Set environment variables for programs being profiled
Irshad_P_
I'm trying to get stats for an OpenMP program using `pcm.x "path/to/executable"` after setting OMP_NUM_THEADS environment variable to `1`. PCM doesn't seem to respect that. It runs the program on all the available cores. Tried `pcm.x "export OMP_NUM_THREADS=1 && path/to/executable"` and also `pcm.x "OMP_NUM_THEADS=1 path/to/executable"`. Both doesn't work.
Any help on how to get this done is much appreciated.
Roman_D_Intel
you can try to put the two lines
path/to/executable
into "run.sh" script
and then execute pcm.x "sh run.sh"
Roman
Irshad_P_
Hi Roman,
Thanks for the reply. But, wouldn't that pollute the numbers obtained ?
Roman_D_Intel
If your program runs > 1 second I would say no.
Irshad_P_
