Intel PCM - When I press Ctrl+C, pcm.x is blocked.
GHui
I use PCM Version 1.7.
When the screen display "Alternatively you can try to reset PMU configuration at your own risk. Try to reset? (y/n)", unexpected, I press Ctrl+C, and then it block.
I tracked it. The reason is the function sem_wait(numInstancesSemaphore) (cpucounters.cpp:1269).
Roman_D_Intel
thanks for reporting this.
We did not expect users pressing Ctrl-C when asked for "y/n". To handle this situation please add these lines into cpucounters.cpp just above this sem_wait call:
[cpp]     }
         #else
+    int oldValue = -1;
+    sem_getvalue(numInstancesSemaphore, &oldValue);
+    if(oldValue == 0) return false;
     sem_wait(numInstancesSemaphore);
     int curValue = -1;
     sem_getvalue(numInstancesSemaphore, &curValue);
[/cpp]
Roman_D_Intel
ifpcm.x is already blocked, there is a method to restore to a normal state:
1. press Ctrl-Z to send pcm.x into background
2. killall -9 pcm.x
3. rm -rf /dev/shm/sem.Intel*
Roman
GHui
Ok,thanksforyour support.
