Intel fast number generator isn't works as expected
Pavel_K_
I am trying to use Intel fast number generator. I added GetRandom(unsigned int low, unsigned int high) method - to get next random number and and srand_sse() to set up seed value from time function. All else is the same as in article. You will see implimentation below. There is one big mystery for me.
Why
__declspec(align(16)) static __m128i cur_seed;
isn't static and changes it value in unpredictable way when the program current execution point moves to other method(i seed this from vs debugger). As you see from code i seted up starting seed value with srand_sse() from time function, but it isn't working(random sequences are the same) if i call GetRandom(..) out of scope were i called srand_sse(), and works if i call it both in one scope... i can't undestand what is going here and how to make seed value works for every place. Does it changes because __m128i refers registers valus? But how can it be static in that case?
//FastRandom.h
#pragma once
#include "emmintrin.h"
#include <time.h>
//define this if you wish to return values similar to the standard rand();
//#define COMPATABILITY
namespace Brans
        static unsigned short curRandIndex = 4;
        static unsigned int randoms[4];
        // uncoment this if you are using intel compiler
        // for MS CL the vectorizer is on by default and jumps in if you
        // compile with /O2 ...
        //#pragma intel optimization_parameter target_arch=avx
        //__declspec(cpu_dispatch(core_2nd_gen_avx, core_i7_sse4_2, core_2_duo_ssse3, generic )
        inline void rand_sse(unsigned int* result)
            __declspec(align(16)) __m128i cur_seed_split;
            __declspec(align(16)) __m128i multiplier;
            __declspec(align(16)) __m128i adder;
            __declspec(align(16)) __m128i mod_mask;
            __declspec(align(16)) __m128i sra_mask;
            __declspec(align(16)) __m128i sseresult;
            __declspec(align(16)) static const unsigned int mult[4] =
            { 214013, 17405, 214013, 69069 };
            __declspec(align(16)) static const unsigned int gadd[4] =
            { 2531011, 10395331, 13737667, 1 };
            __declspec(align(16)) static const unsigned int mask[4] =
            { 0xFFFFFFFF, 0, 0xFFFFFFFF, 0 };
            __declspec(align(16)) static const unsigned int masklo[4] =
            { 0x00007FFF, 0x00007FFF, 0x00007FFF, 0x00007FFF };
            adder = _mm_load_si128((__m128i*) gadd);
            multiplier = _mm_load_si128((__m128i*) mult);
            mod_mask = _mm_load_si128((__m128i*) mask);
            sra_mask = _mm_load_si128((__m128i*) masklo);
            cur_seed_split = _mm_shuffle_epi32(cur_seed, _MM_SHUFFLE(2, 3, 0, 1));
            cur_seed = _mm_mul_epu32(cur_seed, multiplier);
            multiplier = _mm_shuffle_epi32(multiplier, _MM_SHUFFLE(2, 3, 0, 1));
            cur_seed_split = _mm_mul_epu32(cur_seed_split, multiplier);
            cur_seed = _mm_and_si128(cur_seed, mod_mask);
            cur_seed_split = _mm_and_si128(cur_seed_split, mod_mask);
            cur_seed_split = _mm_shuffle_epi32(cur_seed_split, _MM_SHUFFLE(2, 3, 0, 1));
            cur_seed = _mm_or_si128(cur_seed, cur_seed_split);
            cur_seed = _mm_add_epi32(cur_seed, adder);
#ifdef COMPATABILITY
            // Add the lines below if you wish to reduce your results to 16-bit vals...
            sseresult = _mm_srai_epi32(cur_seed, 16);
            sseresult = _mm_and_si128(sseresult, sra_mask);
            _mm_storeu_si128((__m128i*) result, sseresult);
            return;
#endif
            _mm_storeu_si128((__m128i*) result, cur_seed);
            return;
        inline void srand_sse(unsigned int seed)
            cur_seed = _mm_set_epi32(seed, seed + 1, seed, seed + 1);
        inline void srand_sse()
            unsigned int seed = (unsigned int)time(0);
        inline unsigned int GetRandom(unsigned int low, unsigned int high)
            if (curRandIndex < 4)
                unsigned int res = randoms[curRandIndex];
                curRandIndex++;
                return res % (high - low + 1) + low;
            else
                curRandIndex = 0;
                rand_sse(randoms);
                return GetRandom(low, high);
//RandomProvider.h
#pragma once
#include <random>
#include "FastRandom.h"
namespace Brans
    using namespace std;
    class RandomValuesProvider //: public RandomProviderBase
    public:
        RandomValuesProvider(int upperLimit);
        int GetNextValue();
    private:
        int _upperLimit;
//RandomProvider.cpp:
#include "stdafx.h"
#include "RandomProvider.h"
namespace Brans
    int RandomValuesProvider::GetNextValue()
        int tmp = GetRandom(1, _upperLimit);
        return tmp;
    RandomValuesProvider::RandomValuesProvider(int upperLimit) : _upperLimit(upperLimit)
// Runner.cpp : Defines the entry point for the console application.
#include "stdafx.h"
#include <iostream>
using namespace Brans;
    int _tmain(int argc, _TCHAR* argv[])
        srand_sse(); //Setting up starting seed value
        RandomValuesProvider _conProvider(29);
        int theSameValue = _conProvider.GetNextValue();
        cout << "Bad random value is :" << theSameValue << endl;
        /*uncomment this to have not just correct theDifferentValue, but also to fix theSameValue and make it each time different(with random seed). Fantastic!
        int theDifferentValue = GetRandom(1, 29);
        cout << "Good random value is :" << theDifferentValue << endl;*/
        return 0;
[VS 2013 Solution download link(very small])2
Patrick_F_Intel1
Can you provide details?
Patrick_F_Intel1
Sorry but your comment is not showing up.
pat
Bernard
Valued Contributor I
>>>Does it changes because __m128i refers registers valus>>>
IIRC __m128i is of type union and its loaded into XMM registers.If I am not wrong when declared this way _m128i curr_seed at the compile time the address of the variable curr_seed is obtained by using LEA instruction.Following the access pattern to the content of register which holds the address of curr_seed variable could maybe shed some light on what could have probably gone wrong during the program execution.
Patrick_F_Intel1
Hello Pavel,
When you run the code from the sample article, does it work properly?
Pat
