Intercept calls to pthread_mutex_lock
Umesh__Deepthi
Hi All,
I would want to profile multithreaded program and find out if threre was a contention for mutex by threads.
If a thread is going to operate on some mutex, the thread needs to call corresponding pthread functions, like pthread_mutex_lock.  I should be able to redirect the execution of these functions, as in wrap before and after the execution of these functions, where I can get the parameters and return values.
 how to intercept calls to pthread_mutex_lock. doing something like  #define pthread_mutex_lock my_pthread_mutex_lock?
Kindly throw some light on this.I request you to help me out.
Thank you in advance.
Deepthi
Travis_D_
New Contributor II
This doesn't have much to do with Intel, but you can Google for "symbol interposition" or something like that. One way is to use LD_LIBRARY_PRELOAD on Unix-like with a library that redefines the symbols. You can also look at uprobes and similar.
