Load Latency PEBS
Mohamed_Husain
I was measuring the  load latencies in my core i5 2450 using PEBS + load latency feature of the PMU.  The document says , latency value is measured in core cycles from micro-operation (uop) dispatch to when data is globally observable (GO). I have the following queries
1.  What is meant by 'when data is globally observable' ?
2.  The L1 latency is around 4-5 cycles.  But when I measure it using the PEBS, I get L1 hit latency values of even >100 cycles also.  ( It is a hit in dtlb/stlvb)
Can some one give a clarification
Thank you.
Bernard
Valued Contributor I
1) I think that "Globally Observable" might be related to data beign seen and accessed by the software(registers and or memory location).
