MKL Library: AVX vs SSE
Animesh_J_
I want to measure the performance difference between SSE2 and AVX implementations for a neural network application. I am using Intel MKL to perform the BLAS calculations so that I have the most optimized implementation.
Is there anyway to instruct the MKL to release only SSE2 code even if machine supports AVX2. I know AVX2 will mostly perform better than SSE2. But I want to quantify that difference.
Animesh Jain
TimP
Mkl conditional numerical reproducibility offers options which should take care of this.  It has been discussed several times on mkl forum.
TimP
Animesh_J_
Thank you. I am able to dispatch code variants with different SIMD extensions by using the following environment variables - MKL_CBWR, MKL_NUM_THREADS.
