PCM 2.5.1 - cleanup after execution?
Rolf_Andersson
when running pcm-tsx.x multiple times I stumbled on something that looks like a cleanup prob.
This may already be known but I post a brief log anyway.
Best,
Rolf
Rolfs-MacBook-Air:IntelPerformanceCounterMonitorV2.5.1 ran$ ./pcm-tsx.x 2
Intel(r) Performance Counter Monitor: Intel(r) Transactional Synchronization Extensions Monitoring Utility
Copyright (c) 2013 Intel Corporation
Num logical cores: 4
Num sockets: 1
Threads per core: 2
Core PMU (perfmon) version: 3
Number of core PMU generic (programmable) counters: 4
Width of generic (programmable) counters: 48 bits
Number of core PMU fixed counters: 3
Width of fixed counters: 48 bits
Nominal core frequency: 3066666659 Hz
Detected Intel(R) Core(TM) i7-4650U CPU @ 1.70GHz "Intel(r) microarchitecture codename unknown"
Update every 2 seconds
Time elapsed: 1501 ms
Core | IPC | Instructions | Cycles | Transactional Cycles | Aborted Cycles | #RTM | #HLE | Cycles/Transaction
0 0.44 96 M 217 M 0 ( 0.00%) 0 ( 0.00%) 0 0 N/A
1 0.25 8611 K 35 M 0 ( 0.00%) 0 ( 0.00%) 0 0 N/A
2 0.38 69 M 182 M 0 ( 0.00%) 0 ( 0.00%) 0 0 N/A
3 0.26 9312 K 35 M 0 ( 0.00%) 0 ( 0.00%) 0 0 N/A
* 0.39 184 M 471 M 0 ( 0.00%) 0 ( 0.00%) 0 0 N/A
Time elapsed: 1502 ms
0 0.42 128 M 305 M 0 ( 0.00%) 0 ( 0.00%) 0 0 N/A
1 0.32 21 M 65 M 0 ( 0.00%) 0 ( 0.00%) 0 0 N/A
2 0.36 92 M 259 M 0 ( 0.00%) 0 ( 0.00%) 0 0 N/A
3 0.60 85 M 142 M 0 ( 0.00%) 0 ( 0.00%) 0 0 N/A
* 0.42 327 M 774 M 0 ( 0.00%) 0 ( 0.00%) 0 0 N/A
^CCleaning up
Num sockets: 1
Threads per core: 2
WARNING: Core 0 IA32_PERFEVTSEL0_ADDR are not zeroed 4391369
Access to Intel(r) Performance Counter Monitor has denied (Performance Monitoring Unit is occupied by other application). Try to stop the application that uses PMU.
Alternatively you can try to reset PMU configuration at your own risk. Try to reset? (y/n)
y
PMU configuration has been reset. Try to rerun the program again.
Num sockets: 1
Threads per core: 2
0 0.41 92 M 224 M 0 ( 0.00%) 0 ( 0.00%) 0 0 N/A
1 0.49 25 M 52 M 0 ( 0.00%) 0 ( 0.00%) 0 0 N/A
2 0.38 88 M 233 M 0 ( 0.00%) 0 ( 0.00%) 0 0 N/A
3 0.41 27 M 68 M 0 ( 0.00%) 0 ( 0.00%) 0 0 N/A
* 0.40 234 M 578 M 0 ( 0.00%) 0 ( 0.00%) 0 0 N/A
^CCleaning up
Roman_D_Intel
it is not a bug it is a feature :-)
