PCM: Unsupported processor error
Joe_Mario
Hi:
I'm running on Fedora17 on an Ivy Bridge.  When I downloaded PCM, built it and tried to run it, I get the following error.
Any thoughts?
Joe
# ./pcm-memory.x
 Intel(r) Performance Counter Monitor: Memory Bandwidth Monitoring Utility
 Copyright (c) 2009-2012 Intel Corporation
 This utility measures memory bandwidth per channel in real-time
Num (logical) cores: 8
Num sockets: 1
Threads per core: 2
Core PMU (perfmon) version: 3
Number of core PMU generic (programmable) counters: 4
Width of generic (programmable) counters: 48 bits
Number of core PMU fixed counters: 3
Width of fixed counters: 48 bits
Nominal core frequency: 3400000000 Hz
Package thermal spec power: 77 Watt; Package minimum power: 60 Watt; Package maximum power: 0 Watt;
Detected Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz "Intel(r) microarchitecture codename Ivy Bridge"
Jaketown CPU is required for this tool! Program aborted
Cleaning up
Roman_D_Intel
Joe, PCM memory bandwidth metrics (displayed in the pcm-memory utility) are not supported for Intel(R) Core(TM) i7-3770 processor. We are looking into ways how it can be supported in PCM in future if possible. However, many other processor metrics are still supported and can be already displayed with pcm.x utility. Best regards, Roman
Joe_Mario
Thanks Roman for the quick reply. I'll stay with pcm.x for now. Joe
CQ
I'm also not seeing memory bandwidth metrics on Core i7-2860QM and Core i7-3517U.  Are these also not supported?  Is there a list of the supported metrics for each of the chips?
Roman_D_Intel
Hi [email protected],
The recent Intel PCM 2.4 should support memory bandwidth monitoring on 2nd and 3rd generation Intel® Core™ processors (including Intel(r) Core(tm) i7-2860QM, Core(tm) i7-3517U, Core(TM) i7-3770) with Linux pcm.x utility.
Roman
CQ
Linux only?  No Windows?
Roman_D_Intel
Intel PCM V2.8 now supports memory bandwidth metrics on your processor also in Windows (via winpmem driver).
Roman
