Performance Monitoring Event tables
Michael_G_11
Hi there,
Does Intel make this information (for example, 0x03, 0x01, "LD_BLOCKS.DATA_UNKNOWN", "blocked loads due to store buffer blocks with unknown data.") available in a machine readable format so that I don't have to cut & paste from a PDF, re-align, remove line-breaks and add quotes manually?
Michael
SHIH_K_Intel
There is one workaround that you don't have to wait. the same data pieces should already be available if you have VTune installed, look for the bin32 directory.
