Software Tuning, Performance Optimization & Platform Monitoring
Discussion regarding monitoring and software tuning methodologies, Performance Monitoring Unit (PMU) of Intel microprocessors, and platform updating.
Question about get Gflops and AVX performance
GHui
초보자
2,424 조회수
I want to get Gflops and AVX performance. The PCM tools seems not support. What else I can do, in order to get Gflops and AVX?
Any help will be appreciated.
0 포인트
9 응답
Bernard
소중한 기여자 I
2,424 조회수
Do you want to measure program performance?
0 포인트
McCalpinJohn
명예로운 기여자 III
2,424 조회수
If you want to measure actual floating point arithmetic execution rate you are mostly out of luck.  The performance counters that measure floating-point arithmetic instructions (scalar, 128-bit vector, and 256-bit vector) on Sandy Bridge, Ivy Bridge, and Haswell are known to "over-count".
The degree of over-counting depends primarily on average latency between issuing the instruction and the availability of the data that the instruction uses (either register arguments or memory arguments).    If all the data is in the L1 cache, then there is almost no over-counting. If the data is in the L2 cache then you can get slight over-counting (10%-20%, but variable), and if all the data is in memory the counts can be as much as 6x to 10x higher than the actual number of completed floating-point arithmetic instructions.
See more discussion at https://software.intel.com/en-us/forums/topic/499193 and https://software.intel.com/en-us/forums/topic/531796
0 포인트
GHui
초보자
2,424 조회수
Yes, is there some way to do that?
0 포인트
GHui
초보자
2,424 조회수
I have measure it on Sandy Bridge and Ivy Bridge, but not Haswell. I can accept slight over-counting. I have check the documents from http://www.intel.com/content/www/us/en/processors/architectures-software-developer-manuals.html. But it not list events about flops and vector on Haswell.
0 포인트
GHui
초보자
2,424 조회수
0 포인트
GHui
초보자
2,424 조회수
0 포인트
GHui
초보자
2,424 조회수
Sorry, because of slow internet, I clicked submit button one more times.
0 포인트
Bernard
소중한 기여자 I
2,424 조회수
GHui wrote:
You can use VTune for do that. Start measurement  by choosing Lightweight Hotspots and move deeper by choosing more advanced analysis types .
0 포인트
Bernard
소중한 기여자 I
2,424 조회수
>>>I have measure it on Sandy Bridge and Ivy Bridge, but not Haswell. I can accept slight over-counting. I have check the documents from http://www.intel.com/content/www/us/en/processors/architectures-software.... But it not list events about flops and vector on Haswell.>>>
Check following paper about FP performance analysis https://software.intel.com/en-us/articles/estimating-flops-using-event-based-sampling-ebs
0 포인트
응답
