Question about the Intel Performance Counter Monitor
Yen-Yu_C_
Hello
I want to  use PCM to monitor the performance of the program.
I follow the instructions described in the document and have built PCM.exe and got msr.sys.
Howerver, when I run the PCM.exe, it shows messages as follows
Intel(r) Performance Counter Monitor V2.8 (2014-12-18 12:52:39 +0100 ID=ba39a89)
 Copyright (c) 2009-2014 Intel Corporation
Starting MSR service failed with error 1275 This driver has been blocked from loading
Trying to load winring0.dll/winring0.sys driver...
Failed to load winring0.dll/winring0.sys driver.
Cannot access CPU counters
You must have signed msr.sys driver in your current directory and have administrator rights to run this program
Access to Intel(r) Performance Counter Monitor has denied (no MSR or PCI CFG space access).
Can anyone tell me how to deal with it?
Thomas_W_Intel
Thank you for using Intel PCM.
Did you sign your msr.sys driver and run pcm.exe as administrator? Otherwise, Windows will refuse to load the driver.
Microsoft also provides a way to disable this requirement, e.g. during driver development. The process is described on their website.
An alternative to building your own driver is using the signed third-party driver WinRing0.sys. Please refer to the Windows HowTo that is included in the PCM package.
Prasanna_Subburaj
Adding on to Thomas Reply,
You can download WinRing0.dll,WinRing0.sys,WinRing0x64.dll,WinRing0x64.sys from
http://www.techpowerup.com/realtemp/
and winpmem_64.sys from
https://code.google.com/p/volatility/source/browse/branches/scudette/tools/windows/winpmem/binaries/amd64/winpmem_64.sys?r=2615 ;
and paste them all in the place where you have your pcm.exe and run it as administrator to see the result
Vadim_K_2
Hi All
I write about winpmem_64.sys .
link from previous message is wrong =((( https://code.google.com/p/volatility/source/browse/branches/scudette/tools/windows/winpmem/binaries/amd64/winpmem_64.sys?r=2615
Where can I download this file to a different location?
Good wishes,Vadim
Erons_O_
Vadim K. wrote:
Hi All
link from previous message is wrong =((( https://code.google.com/p/volatility/source/browse/branches/scudette/too...
Good wishes,Vadim
Hey Vadim K,
This is the new location
https://github.com/google/rekall/tree/df4c820de7b3a21bd241336c99c12b3b9dde4015/tools/pmem/resources/winpmem
Change the name from winpmen_x64 to winpmen64.
EronsJ
