Read Base Clock Frequency
Samuel_M_1
I understand that the frequency of the base clock varies between the nehalem and the sandy/ivy bridge architectures (133.33 MHz vs 100 MHz). Is there a way to read this number from an MSR or some other source?
Patrick_F_Intel1
If there is another way, I have not seen it.
In my tools I have to check the cpuid family and model to see on which cpu I'm running and then use the appropriate 100 or 133 MHz speed.
Sorry,
Pat
SergeyKostrov
Valued Contributor II
>>...In my tools I have to check the cpuid family and model to see on which cpu I'm running and then use the appropriate 100 or >>133 MHz speed. Patrick, Could you be more specific, please?
Bernard
IIRC I saw in the documentation that one of the MSR registers 0xCE reports base frequency.I need to check ISDM to verify this.
Patrick_F_Intel1
Hello Sergey,
It is just the standard, pain-in-the-rear code like:
if ( family == 0x6 && xmodel == 0x3e ) {
    bclock == 100 ;   // so cpu model is ivybridge, bclock is 100 MHz
} else if ( family == 0x6 && xmodel == 0x2a ) { // sandybridge...
the family and xmodel (extended model) is based on the CPUID app note http://www.intel.com/content/www/us/en/processors/processor-identification-cpuid-instruction-note.html
There is a discussion of using cpuid to ID cpu type at http://software.intel.com/en-us/articles/intel-architecture-and-processor-identification-with-cpuid-model-and-family-numbers
Pat
SergeyKostrov
>>...the family and xmodel (extended model) is based on the CPUID app note... Thanks for the note, Patrick. I didn't see processor-identification-cpuid-instruction-note.pdf document before.
PONRAM
hope you may interested in the following link
software.intel.com/en-us/platform-monitoring
SergeyKostrov
>>hope you may interested in the following link >> >>software.intel.com/en-us/platform-monitoring Thanks for the link.
Samuel_M_1
Great link PONRAM.
My conclusion for the original question is that Patrick's method using cpuid is the only viable option, and I have implemented that in my code. Thank you all for your responses.
Bernard
Thank you PONRAM for the link.It contains a great amount of information.
