SIMD for calculating checksum
zoolii
Hi Experts,
Can we optimize following checksum calculation using SIMD somehow ?
for(int i = 0 ; i < buffSize_ ; i++) {
hashVal = (hashVal<<5) + hashVal + pBuffer_;
Thank you
Zooli
SergeyKostrov
Valued Contributor II
Quoting zoolii
Hi Experts,
Thank you
Zooli
Yes, with and without SSE. Also, you didn't specifytypes of'hashVal' and'pBuffer_'variables.
Sergey
zoolii
Hi Sergy,
Thanks for the reply. hashVal can be an unsigned int or long . pBuffer_ is an unsigned char array.
Zooli
SergeyKostrov
You need to consider a set of SSE3 instructions for a horizontal addition.
Sergey
SergeyKostrov
TimP
If the array is at all large, the vector sum reductions implemented by the compilers (nearly any compiler other than MSVC) may be superior.
