Use PEBS sampling inside a qemu-kvm VM
xalverti
Hello to all,
I would like to use PEBS sampling from within a VM. I was under the impression that since linux kernel 6.3 the kvm module virtualizes PEBS counters.
However, If I run foe example " perf record -d -e cpu/event=0xd1,umask=0x20/ppu -c 1 ls"
inside a qemu-kvm guest I get back: "PMU Hardware doesn't support sampling/overflow-interrupts"
I am running my experiments in a Sapphire Rapid cpu server and both guest and host run a 6.6 linux kernel.
In the host I can run perf + PEBS correctly (i.e. the above command runs successfully and I get meaningful output from subsequent perf script command).
My questions are: a) is it possible to use PEBS sampling/monitoring from within a VM and b) if yes do I need a dedicated qemu version or parameter?
Chloe
