Win2012 Hyper-V
eda
Is the following software certified to run on Windows 2012 Hyper-V servers?
Intel IMSL
Intel Fortran Compiler
Intel Fortran Math Kernel Library (MLK)
SergeyKostrov
Valued Contributor II
>>Is the following software certified to run on Windows 2012 Hyper-V servers? >> >>Intel IMSL >>Intel Fortran Compiler >>Intel Fortran Math Kernel Library (MLK) I don't know if the software you've listed is "certified" but I'm sure that 32-bit and 64-bit versions should work on all versions of Windows 2012 Server.
Bernard
>>>Is the following software certified to run on Windows 2012 Hyper-V servers>>
Do you mean to run inside guest OS which in turn is installed on Hyper-V server?
