Wireless
8851 Discussions
无法安装ICM和ICPS驱动
YShi_LMu
无法安装此驱动:https://www.intel.com/content/www/cn/zh/download/738623/intel-connectivity-performance-suite-icps-for-intel-wireless-products-and-intel-connectivity-manager-icm.html
安装时,提示 an invalid condition was encountered:Error 0x80004005
https://www.intel.cn/content/www/cn/zh/support/intel-driver-support-assistant.html    这个页面中的“安装历史记录”中,显示安装失败,错误代码为 0x8004070F (-2147219697)
cpu为185h,网卡是ax211,系统为win11 22h2 22621.2134,我个人对系统有所精简,因此没升级到24h2
Mike_Intel
Hello YShi_LMu,
请注意,我只能用英语为您提供支持。我使用了网络翻译工具来翻译此回复,因此,可能会有一些不准确的翻译。
  1. What is the brand and model of your laptop/system?
  2. Did you upgrade the wireless controller of your system or this is the embedded wireless controller of the system?
  3. Can you tell me why are you trying to update? Are you having issues with the card?
Michael L.
YShi_LMu
1.The information of my computer is as follows:
HUAWEI VGHH-XX
Bios
Version
1.25
Date
2024-10-11
Motherboard
Manufacturer
HUAWEI
Model
VGHH-XX-PCB
Version
M1010
Operating System
Edition
Microsoft Windows 11 Professional version (64 位)
Version (Build)
22H2 (10.0.22621)
2.i dont upgrade the wireless controller.
3.There was nothing wrong with my computer, but it kept prompting me to update in the taskbar, so I did the update.
Mike_Intel
Hello YShi_LMu,
Thank you for the update.
Can you try to manually download and install the generic driver below:
https://www.intel.com/content/www/us/en/download/19351/intel-wireless-wi-fi-drivers-for-windows-10-and-windows-11.html
Michael L.
YShi_LMu
I can install this driver successfully, but Intel still prompts me to update the ICPS and ICM drivers in the taskbar. Will it affect functions such as wireless and Bluetooth if it is not updated? If it doesn't affect, I won't care anymore.
Mike_Intel
Hello YShi_LMu,
Thank you for the clarification.
Can you try to follow these steps in installing ICPS and ICM:
  1. Uninstall the current driver version
  2. Download the OEM driver from HUAWEI's website
  3. Install the OEM driver
Contact your Original Equipment Manufacturer (OEM) to install the Intel® Connectivity Performance Suite (ICPS) for Intel® Wireless Products, and Intel® Connectivity Manager (ICM) OEM drivers.  Drivers provided by the OEM can contain specific customizations that impact a device's functionality. Therefore, using a generic driver from Intel could potentially cause issues.
Michael L.
YShi_LMu
According to US policy, Intel has stopped cooperating with Huawei. In Huawei's driver software, there is no requirement for me to update this driver. So, what exactly does this driver affect? Is it necessary to update this driver?
Mike_Intel
Hello YShi_LMu,
Let me share this link:
https://www.intel.com/content/www/us/en/support/articles/000091942/wireless/wireless-software.html
In the link above, you can see the overview of ICPS and ICM and also their usage.
If the system is asking for you to update these drivers, that means the system needs these application to function properly.
You may contact the laptop manufacturer for the full details of its functionality with your laptop since they are the one who configured it.
Michael L.
YShi_LMu
In Huawei's software, I checked the driver update column and found that Huawei did not require an update. I'm not quite sure what this driver affects either,and my daily use is fine. Is it okay not to update it?
ajklasdg
I have the same problem, but i'm the EVO laptop equipment with win11-24h2,CPU: i9-13905h ,NVIDIA 4060 laptop version.
I found it on the Intel® Driver & Support Assistant website(英特尔® 驱动程序和支持助理) that the driver could be upgraded, which proves that my hardware supports ICPS. So I chose to install and upgrade. However, the following error occurred during the installation process. May I ask how I can solve it?
Is it because my computer lacks some necessary software or drivers? I haven't found any other available updates on the Intel-Support website(https://www.intel.cn/content/www/cn/zh/support/intel-driver-support-assistant.html). Moreover, during the installation process, only the CMD window popped up and there was no error display. When the progress bar reached 100%, a pop-up window told me that the installation had failed. The following is my device configuration:
Snipaste_2025-05-29_14-15-13.pngSnipaste_2025-05-29_14-17-04.pngSnipaste_2025-05-29_14-34-46.png微信图片_20250529141601.jpg微信图片_20250529141606.jpg
Mike_Intel
Hello YShi_LMu,
By the way, let me check. Are you using an EVO laptop?
Can you take a photo of the laptop focusing on the EVO badge?
Michael L.
RandyT_Intel
Hi @YShi_LMu,
I wanted to reach out to you following an internal review of your case, which we conducted yesterday. I appreciate your patience and understanding as we work to provide you with the best possible support.
Firstly, I would like to sincerely apologize for any confusion caused by our earlier responses. We are committed to ensuring clarity and accuracy in our communications with you.
After consulting with the Huawei PC Manager, we have determined that no system update is necessary at this time. We recommend keeping your system as it is for now to maintain optimal performance.
You may have noticed a prompt from the Intel Driver and Support Assistant suggesting an update due to the recent release of ICM and ICPS. Please be assured that these drivers are generic and apply to all systems using ICPS and ICM. However, since the Huawei PC Manager indicates that your laptop does not require this driver update, we advise you to hide the update for ICM and ICPS.
Here are some important reasons why it's best to use the official drivers provided by the manufacturer of your device:
  1. Manufacturer-provided drivers are specifically tailored to work seamlessly with their hardware models, ensuring optimal performance and minimizing potential issues.
  2. These drivers undergo extensive testing by the manufacturer to ensure they function well with the hardware and supported operating systems.
  3. Generic or third-party drivers may not support all the features of your device. Manufacturer drivers often include utilities or enhancements that unlock the full potential of your hardware.
For further assistance and inquiry, please contact your system manufacturer.
Randy T.
